Thanks Thanks:  3
Likes Likes:  2
Results 1 to 12 of 12
Thread: Breeze PS Hose Kit Fitting Leaks
Threaded View
  1. #5
    Jul 2024
    BC, Canada
    I thought you were supposed to use one or the other, but not both, depending on whether you had a chamfer or not. It's been a while so can't recall. I didn't have any issues with the Breeze kit. In fact, those fittings were much easier to work with than some of the others I tried. I think they may be Aeroquip fittings, but not sure. High quality stuff.
    Per the instructions and confirmed with Mark, you stack two in a specific order when there is no chamfer. I thought it was odd stacking seals so confirmed with Mark.
    When I said mine has a small chamfer, compared to other racks I’ve seen, mine has next to none. Regardless I tried it both ways without success.
    I’ve seen the FFR supplied racks and they seem to have a much larger chamfer with a better chamfer quality. Perhaps that’s why the sealing method works at times?
    My stock rack has threads running much closer to the top of the opening which I think impacts the sealing method
