Results 1 to 5 of 5
Thread: Shock orientation
    Mar 2024
    Shock orientation
    I am trying to understand the proper shock orientation. I am building a MK4 with IRS and red KONI shocks. From the manual, I've determined that the body of the shock goes up in the front and down in the rear. But why? Is this to make ride height adjustment easier?
    MK4 Roadster complete kit delivered 5/2/2025. Ford 390 FE engine with TKX and IRS.
    Engine build videos: https://www.youtube.com/playlist?lis...LfSTxcvVXT_BpP
    Roadster build videos: https://www.youtube.com/playlist?lis..._IjMh_XJLo0x29
    Red Koni's can be either body up or down. Doesn't matter to the shock. Typically oriented to provide the best clearance to other suspension components. Access to the ride height adjustment collars is a consideration too I guess. But I haven't noticed much difference whether at the top of bottom of the coilover assembly.
    Jan 2012
    Central OK
    My MkIV has the old T-bird based, pin-drive width (narrower), IRS. In my case, the spring hat would hit the lower control arm mounted body up, so I had to mount the shock body down. This gave additional clearance where the shock mounted to the LCA.
    -Kyle
    It's for clearance,not ease of adjustment.
    Mar 2024
    Got it. Thanks!
