Results 1 to 3 of 3
Thread: First Window Rock Chip-Dang!!!
    Aug 2022
    Portland, Oregon
    So I got my first rock chip, looks like it could be a crack in short order. Any experience with repairing using Rain-X type kit or professional? chances of success or plan for a new Window? I have a new window from when I thought I messed up the first window frame, so I can replace it but it has only been 2,000 miles.
    MK IV Delivered June 27, 2023 Build Thread-https://thefactoryfiveforum.com/showthread.php?46069-Lance-s-Roadster-Build-Thread-Starting-the-Al-panel-slog
    "Build a Car" They Said "It Will Be Fun "
    Dec 2017
    Quote Originally Posted by F500guy View Post
    If it's a chip, then most likely you can leave it. If it's a crack, it will just get worse. My last glass windshield had a ton of chips in it. I was worried that it would eventually crack, so had it wrapped with PPF. This time I have a Lexan.
    Edmonton Alberta
    I have used both pro and do it yourself repairs. Our local pro guys can even repair long cracks so they don't grow more. I have found the pro repairs often hide the chip better. You need good sun light to cure the resin on the home kits.
    David W
    Mkll 4874 built in 2004
