Hey Y'All,
I got motivated to finally cut out the hole for the shifter in the trans top panel after reading a recent post by Brew...
Here's the rough cut
followed by a confirmation measurement of the trim ring location so that I could mark/drill the holes for that
then I added the low-profile riv-nuts and oval head fasteners to lock it into place
which allowed me to get a final outline to trim up the hole better for the final upholstery work...which will occur later
The trans tunnel top panel will be covered in one piece of foam-backed leather. If I'm feeling "frisky", I might consider adding a French seam along the sides with red thread...but that decision is much later. The shifter and hand brake will get their own leather "boots" sewn together longitudinally and fastened under the trim ring
It's slowly coming together!
Craig C
