Results 1 to 17 of 17
Thread: Gen 3 frame changes makes mounting the battery tray require fabrication??
    Jul 2025
    I was following Papa's example in an upgraded battery tray and realized my frame is different from anyone else's ive seen in build threads! FFR seems to have redesigned the frame in the battery tray area, eliminating the cross bracing going under the area the battery tray mounts. I also have these tabs along the edge that seem to be missing on any other build ive seen. Has anyone else seen this, is there a solution for the battery tray other than adding bracing in that area to support the battery? I have the same battery tray everyone else has, it isnt large enough to span the gap and use the frame tabs that have replaced the previous bracing that I am missing.
    The frame is going to my fabricator this summer to install the ePowersteering under the dash, so I plan on having him add the bracing that seems to be missing from my chassis.
    Interesting. Looks like Factory Five made a similar change to the Gen 3 Coupe as they did on the Mk5 Roadster. You should have received a battery tray that spans the opening and fits to the tabs pictured. If you didn't ask FF. Shouldn't be necessary to do any fabrication of your own. This is a screenshot from the Mk5 manual in case it's not showing in the Coupe manual.
    Jul 2025
    I thought that may have been the case, im not sure im in love with those tabs soo far apart supporting the weight of a battery.. I'll shoot FFR an email today.
    I wish my frame had the update! Getting the battery out with a Coyote stuffed in the engine bay on my car will be a pain with the air intake and coolant lines congesting the area that the battery will need to come through. Those tabs will have absolutely no issue supporting the weight of the battery.
    Nov 2020
    Damascus OR USA
    I think I saw a post a while back from Jeff Kleiner regarding this update. If I remember correctly it allows for removal of the battery from underneath?
    Build 1 - 1969 Camaro Build Thread Here: https://www.camaros.net/threads/tims...y-getter.45926
    Build 2 - 1965 Daytona Coupe # 620 Build Thread Here: https://thefactoryfiveforum.com/show...-Type-65-Build
    Quote Originally Posted by PNWTim View Post
    Tim,
    That's correct. I believe the change was made based on feedback from the MK5 beta builders, including Jeff, based on the placement of the brake boost setup FFR is now offering that mounts where the battery would come out from above. By making it removeable from below, you won't have to disassemble a bunch of stuff to get the battery out.
    Jul 2025
    Well now I’m happy to be lucky enough to get the updated battery placement! Just gotta get the correct tray sent!
    Thanks for the insight!
    Nov 2021
    Toronto Ontario Canada
    I wonder when they made the change? I picked up my 30th anniversary coupe mid August last year and it's not like that?
    Jul 2025
    I picked mine up on Veterans Day last year, so sometime between your build and mine.
    Huntsville, Al
    Yes this was change likely from Us beta builders... if you retrofit power brakes, you will need to able to remove the battery from the bottom - without this the battery choices are limited to only a few.
    Jan 2024
    What's your car number?
    Sal Mennella
    Type 65 Daytona Coupe #692 - in progress!
    GTM #30 - sold
    Roadster #5132 - sold
    Huntsville, Al
    my roadster is Beta #2
    Quote Originally Posted by Erik W. Treves View Post
    No, I'm #2...I got mine a day before you But you did finish first
  14. Likes Erik W. Treves liked this post
  15. #14
    Jan 2024
    I meant the original poster LOL
    Sal Mennella
    GTM #30 - sold
  16. #15
    Jul 2025
    Chassis # 1000705DC, build date of 1 Nov 2025
  17. #16
    Jan 2024
    Quote Originally Posted by jemorgan3 View Post
    So you're coupe 705. I've got 692, and mine is the previous design. Wonder if they started at 700 with the new version.
    Sal Mennella
    GTM #30 - sold
  18. #17
    May 2024
    Puyallup, WA
    I wonder if the older design can be changed to the new design to make it easier to remove the battery?
    Coupe Complete Kit - Ordered 7/8/24 - Received 10/13/24
