Thanks Thanks:  2
Results 1 to 3 of 3
Thread: Coupe Bodywork - What Material Quantities are Needed?
    Sep 2021
    Emmaus, PA
    Hi all,
    I am getting ready to start spraying my coupe and curious what product quantities are needed. It seems there's a lot more surface to cover on the coupe vs the roadster. The list of products and quantities below was aggregated from the following thread and worked out well when I painted my Mk3 last summer: https://thefactoryfiveforum.com/show...Work-and-Paint . I found this to be a superb "primer" for anyone considering taking on bodywork and paint. As always, thanks for your help!
    Polyester High Build:
    • 2 gallons polyester high build
    • Slicksand
    • Three coats
    Primer/Surfacer
    • 1 gallon 2K urethane primer surfacer + catalyst + reducer
    • PPG JP202
    • Three coats
    Urethane Sealer
    • 2 quarts urethane sealer + catalyst + reducer
    • PPG JP33x (depending on color)
    • One full coat
    Basecoat
    • 1 gallon basecoat + reducer
    • if doing stripes you'll need a quart of that color - I don't have the guts to try stripes yet
    • PPG JBP
    • Three coats
    Clear
    • 1 gallon of clear + hardener and reducer as applicable
    • PPG DCU2021
    • Thee coats - I recall have a lot left over from my cobra, maybe I went too light? I think I used a bit more than half.
    Build 1: Type 65 Coupe:
    Album: Coupe Album | Delivered: February 24, 2022 | Legal: April 20, 2024 | Complete: TBD
    Build 2: Mk3 Roadster
    Build Thread: TTimmy’s MK3 Basket Case Build Thread | Album: Mk3 Album | Originally Delivered: 2004 | Acquired by me: August 2024 | Legal: 3/31/25
    Although it seems like there is a lot more surface area when you consider that you aren't shooting the underside of the hood and trunk like you would on a roadster the quantities are will be pretty close if you aren't doing anything under the clamshell hood or interior. When I've done Coupes I shoot the entire underside of the body and clamshell with Raptor (it'll take a 1 gallon kit).
  3. Thanks TTimmy thanked for this post
    Jul 2024
    Detroit Mi
    Your Roadster list and quantities are very close to my Coupe Tim.
    2 gallons of PPG VP2050 Polyester Primer
    3 initial cotes after body work was done, then we blocked it with 150
    3 more cotes and let sit to shrink over the summer.
    When all done, we used 1.5 gallons
    PPG ECS21 Sealer. I was fortunate to use a couple of cups from my brothers shop so I didn't have to buy it.
    1 Gallon of PPG DBC, it mixes 1 to 1 so 2 gallons sprayable.
    3 cotes plus a drop cote
    1/2 gallon left.
    1 Gallon PPG EC520 clear.
    2 cotes then we block sanded with 800 to get a nice flat surface for the Fine Line.
    Taped off and laid down the Stripes.
    1 quart PPG DBC for the Stripes
    4 more cotes of clear to bury the Stripes. 1/2 hour between cotes to let it gas out.
    A little over a quart left.
    Started block sanding the clear with 600 wet until it was flat, then 1000, 1500, 2000, finishing with 2500.
    First time for me stacking clear that high, but you end up block sanding a lot of it off. It comes out pretty flat doing it that way.
    Type 65 Daytona G3 Coupe #635 - Dart 363" SBF
    1970 Plymouth Road Runner 440 6-BBL Super Track Pack
  5. Thanks TTimmy thanked for this post
    Likes Power Surge liked this post
