Results 1 to 8 of 8
Thread: Source For Russ Thompson Pedal Grommets
    Hi all,
    I have been away from the forum for a while and just found out about Russ' passing a few years ago. I was wanting to find a source for the grommets he used for his pedals. The grommets he used have a square shoulder, as opposed to the typical round shoulder type. I thought I would ask here before popping one out of the pedal, measuring it and finding a source.
    Thanks all!
    Woodstock ,Illinois
    That's actually an insert for license plate mounting. Check the "help" section at your auto parts store.
    Nov 2022
    Baton Rouge, LA
    Steno, unfortunately it is not. Those are rubber grommets. I have a bunch of the plate mounts, not the same item, but thank you!
    Dash,
    I was looking at those last night, but would have to pop one out to measure. Thank you and thanks for the link!
    Nov 2022
    Baton Rouge, LA
    Already did that for you! I have the same pedals and the grommets were worn/non-existing. Put them in and worked perfect. That is the correct size.....
    Good luck!
    Dash,
    Really appreciate you providing this information, very much appreciated!
    Woodstock ,Illinois
    The mention of square shoulder messed me up! That's what is on mine!
