Scott Pregont
My Albums
I made sure the foam was proper for the application. It was closed cell and was reccomended. I followed the application (at least I thought I did) for the adhesive as to applying to both surfaces and letting it sit for a specific amount of time to tack up. It worked for the foam to the aluminum. That stuck like hell. It's what I'm removing now. The marine vinyl to the foam interface and any vinyl to aluminum is what is failing. Marine vinyl is what I had been told to use but it certinly didn't work for me.
Scott Pregont
My Albums
I could not find anything on "DKS Products Pro Grip". If it has a warning about it being flammable, then that may have caused the problem. Flammable adhesives contain hydrocarbons which can cause vinyls to fail while it out-gasses. I use either two part epoxies or urethane adhesive when gluing automotive materials. Rather than foam, for the dash, I use neoprene backing.
Consider using naugahyde, or sileather. Both are low maintenance and very resilient.
Scott Pregont
My Albums
FWIW, I powder coated the dash in my MK4, and pretty sure I'll do the same on my Coupe. I like the nod to the era with metal dashes, and it's a clean look IMHO. Virtually unlimited colors and textures available.
Coupe complete kit. Index. Delivered: 4/22/24. Build Thread. Coyote Gen 4X. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
8secDuster liked this post
With powder coating being so smooth, do you think there would be an issue with glare across the top of the dash even with a flat or satin color? The reason I was thinking about Raptor is that it is a flat black color and has a slight texture that would eliminate glare. I think!
Scott Pregont
My Albums
Great question, Scott, and not something I had to face with the MK4. I've read about the glare concern with the Coupe. I'm going with a low gloss and light texture. However, there are much heavier textures available. I suppose a test piece would be the safest way to know for sure. Did you get glare with the material you just removed?
Scott Pregont
My Albums
The weather in upstate NY is 50 degrees today so I took advantage and continued with the winter projects we all have with our cars at this time of the year. After putting the car on jack stands and removing the wheels to clean up the suspension and grease the chassis I noticed that the inside of the wheels were looking kind of crappie.
I had seen a add for Wheely Clean and decided to give it a try.
I was very impressed. I just sprayed it on the dry wheel, let it sit for 30 seconds then used a kitchen dish brush to scrub the surface followed by hosing off.
Worked great! Figured I share.
Scott Pregont
My Albums
Decided to use Raptor on my dash. Like the way it turned out.
Scott Pregont
My Albums
jbs72697 liked this post
Health update!
Had an appointment with my cancer doctor three monthe ago. My bloodwork, for the appointment, had spiked. I had an infected toe-nail at the time and he thought that might be a contributing factor. Had another appointment yesterday to check and my bloodwork took another spike. Toe is healed so that wasn't it. Recently (within the last four months) I have noticed a sore behind my ear that doesn't seem to heal. (Not good when you have cancer!!) I pointed it out to my cancer doctor and he said it might be skin cancer and may be the reason for the spike. The challenge now is to find an in network Dermatologist who I don't have to wait a long time to see.
Scott
Scott Pregont
My Albums
Thanks for the update Scott. I hope you're able to find someone who can see you quickly.
Gen 3 Coupe #654
Kit Delivered: 9.20.2025
Build Thread: Garcia Family Coupe
Blog: Garcia Family Coupe
Namrups thanked for this post
Build 1 MK4 #10008 - Delivered 03/03/21, Graduated 7/20/22 - Sold 6/6/24 Build Thread #1 https://shorturl.at/K9fuy
Build 2 MK4 #11061- Delivered 08/24/24 Build Thread #2 https://shorturl.at/OZowi
Build 3 35 Pickup #329 - Delivered 10/28/25 Build Thread #3 https://shorturl.at/Ty4QQ
Just kick its arse out the door and hang in there!
Namrups liked this post
Dang it! Stupid cancer! You've done a great job beating it so far. Hopefully, you're too ornery a guy to let it get the upper hand this time. Hang in there, man! Wishing you the best.
Keep fighting my friend! We'll drive fast this summer....
Mark III 4630RD Explorer 302, Holley SA570, FRPP B-cam, 4 to 4's, 3 Link, Bullitt wheels, Baer Brakes, 3.73 gears, HD T-5
Mark II Rebuilt into 1955 Jaguar D Type Replica Explorer 302, Holley SA670, Trick Flow Stage 1 cam, 3 Link 4.10 gears, Classic Gauges
PM me if you live in Upstate New York. Get added to the "Upstate Cobras" email list. 60+ members!
Scott Pregont
My Albums
Health Update 2
Found an in network Dermatologist that could get me right in.He confirmed it was skin cancer and took a biopsy sample. Called back with the results yesterday. Confirmed as Basal Cell Carcinoma. Basal Cell is the most common type of skin cancer and is the least likely to spread to other parts of the body. I have to go back to see him next week so he can scrape the rest of it out.Should end up with just a scab. Not to keen on the scraping part! I will then add him to the list of doctors to see on a regular basis.
Scott
Scott Pregont
My Albums
Sounds like the best possible scenario Scott. Keep on my friend!
