Results 1 to 2 of 2
Thread: Steering arm orientation
    May 2025
    I'm having trouble confirming the steering arm orientation for the mkiv 289.
    The manual seems to show up and out, but it's difficult to tell. Can someone confirm this setup? Photos are the driver side
    Feb 2023
    Mechanicville, NY
    Yes...pointing up and out.
    The steering arm hole is tapered to accept the tie rod end. Larger opening of the tapered hole points down to accept the tie rod end from underneath. It won't work the other way.
    Jen
    MK4 complete kit, IRS, Ford Strokers 347 (carb & mechanical fuel pump), TKX, PS, heater-defroster-wipers, firewall forward, 11.65 rear brakes, 17" Halibrands, #11124.
    Ordered: 9.8.2024
    Delivered: 10.31.2024
