Thanks Thanks:  77
Likes Likes:  148
Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 401 to 440 of 463
Thread: Angelina: Build Story of my 4-wheeled Motorcycle
  1. #401
    Jan 2019
    Mead Colorado
    Photos still aren’t loading Craig. Don’t know why—-everyone else’s are working for me
    I am seeing them Jeff.
    @craig: they say that envy is the thief of joy, but in this case I don’t think so. I envy your detailed skills and capability. I doubt I can ever match you but I really do enjoy seeing what you are doing. Well done sir! Well done indeed!
    Mk4 complete kit arrived 10 May 23
    Current BOM and Build Thread
  2. Thanks cc2Arider thanked for this post
  3. #402
    Sep 2022
    Hi Jeff,
    Thanks for checking!
    When I log back-in to check my thread, the pictures do not pop up for me, either (initially). I'm wondering since they are "large" format, they may need some time to load. After about 10~20 seconds, they do load up
    Craig C
  4. #403
    Sep 2022
    Quote Originally Posted by danmas View Post
    Thanks for the kind words Dan! It's taking me longer for my build, but I'm trying to savor all the moments...plus it's been very cold here this weekend...not much else to do
    Craig C
  5. #404
    Jan 2019
    Mead Colorado
    Quote Originally Posted by cc2Arider View Post
    Craig C
    I have slowed down a bit on my build, partly because I have been so busy doing other things and partly because I have been enjoying thinking through issues and solutions. It’s a special process and the goal isn’t the end state but rather the journey, at least for me.
  6. Thanks cc2Arider thanked for this post
  7. #405
    Sep 2024
    Spencerport, NY - near Rochester
    Craig, that's some very impressive work making those trim rings largely by hand. They look great. A ton of work but turning out super nice and very unique. Anxious to see the finished product.
    Pat
    MK4 complete kit Nov 2024, Blueprint 347, TKX, Hyd clutch, IRS, 3.55, touring shocks, 17" wheels, 11.65 brakes, Build Thread
  8. Thanks cc2Arider thanked for this post
  9. #406
    Sep 2022
    I totally agree and understand your process
  10. #407
    Sep 2022
    Quote Originally Posted by PMD24 View Post
    Pat
    Thanks Pat
    Part of my journey is to see what I can do and try it...after thinking thru lots of options
    I still paint myself into a corner on occasion, but just like Dan mentioned, part of the process is to think thru solutions...and when you see the "other side" that's really rewarding!
    Craig C
  11. Likes danmas liked this post
  12. #408
    Sep 2022
    Dash panel and Console color and material choices
    Hey Y'All,
    I got my Dash Panel inserts and Console door back from the Powder Coater
    He had a textured black finish that I was hoping would mimic the "crinkle" black painted look. Here's a couple of pictures in bright sunlight. I'm hoping the glare is not much when it's in the car... ... if so, then I'll just have to re-do them...
    Dash Gauge pod and Glovebox door with my choice of leather for the Dash. This is the same leather that John Ibele used for his build...
    Console Door with my choice of a different leather for the console and the trans tunnel top. This leather texture most closely matches the leather inserts of the seats...
    Craig C
  13. #409
    Sep 2022
    More detailed fitting of the Dash Panel now that I've chosen my leather
    Hey Y'All,
    Not much to show in this post...just lots of detailed fitting now that I've chosen my leather. The Dash leather is about 0.040" thick, whereas the Console and Trans tunnel top leather is closer to 0.055" thick.
    I decided to change my mind on the interface between the Dash and Console. It'll be a T-shaped extrusion that I'll have powder-coated black crinkle finish. It'll serve as a decorative piece which "breaks up" the visual appearance a little without being a focal point. I have enough of those . I'm hoping it will also protect the glued leather edge on the front of the dash panel's lower mounting flange. I got the extrusion from McMaster-Carr and I had to trim down the edge since it came as a 1" deep x 1.5" tall piece.
    Here I used my router technique with some 1/8" plus 1/4" rectangular stock as spacers: one side is trimmed to 3/8" and the other is 1/4". I may decide to reduce that 1/4" down to 1/8"...we'll see...
    and here's a mockup on the car...after more fitting to keep it level with the back cockpit 3/4" frame tube
    I know that no one would notice on the finished car since there are so many curves, but I'd remember that I didn't do a good job...and it would eat at me everytime...so I got the details to my liking
    This may be my last post of the year, and while I was hoping to get my engine started by now, I'm looking forward to spending time with family for the Holidays
    Merry Christmas and Happy New Year!
    Craig C
  14. #410
    Sep 2022
    Locking the Dash Panel down in 3D space
    Happy New Year Everyone! I hope your 2026 is healthy and fulfilling
    I was back in the garage and finally got to finish up my Dash Panel's fastening strategy. I'll use the Dash Panel frame hoop tube, the bottom edge of the Dash (where it interfaces with my Console), and the outer flanges (near the doors) as my "lock-down" fastening points.
    My Dash Panel "trim rings" will camouflage the fasteners there...or maybe I should say that they'll perform double-duty This meant precision drilling for me and it was somewhat stressful...but it worked out well. Most of the top fasteners will be riv-nuts, but 2 of them are too close to the edge of the hoop frame tube for riv-nuts, so they'll be plain sheet metal screws (like the Build Manual example).
    Here's the mock-up at the Dash frame hoop: glovebox glovebox fastener strategy.jpg
    Then, I needed to add the riv-nuts to my Dash Panel "extensions"
    and then fastened
    and here it is installed (mostly)...and still where I wanted it
    This was a big milestone for me I'll just need to get some more low-profile riv-nuts to finish it out...
    Next Post: Under Dash access panels (finally)
    Craig C
  15. Likes RobHartley liked this post
  16. #411
    Sep 2022
    Under Dash Access Panels
    Hey Y'All,
    In this last post of the weekend, I create my under dash access panels. I had previously made them "rough", but now that the Dash Panel is "locked down", I can finish the details (such as making room for the heater ducts and vents and making the whole thing "presentable" These are hinged at the back (near the large square cross cockpit frame tube) and the front can be unfastened quickly with Phillip's head screwdriver (if the need ever arises)...
    Here's more detail work done with the help of "CAD" cardboard-aided-design
    I purposefully did not get out the hammer and shot bag to keep the panels simple-to-build to show you that you can approximate interesting shapes without getting expensive tools and learning high-skill techniques. I hope this is an inspiration to you to get creative!
    And then 2 views of it fastened into place
    Driver's side under dash access panel1.jpg Driver's side under dash access panel2.jpg
    similar work was done on the Passenger-side
    Passenger side under dash access panel1.jpg Passenger side under dash access panel2.jpg
    Now that these panels are formed, they can go to the Powder-coater for more black-crinkle finish
    Until next time, Happy Building!
    Craig C
  17. #412
    Sep 2022
    Checking for fuel leaks
    Hey Y'All,
    Now that I'm almost ready to send more Dash panels off to the Powder-Coater, I wanted to revert my attention back to the wiring so that I can pressurize the fuel system and check for leaks. This was a milestone I really wanted to cross off...
    I was able to re-do my behind-dash wiring again (after a couple of months of it being apart) pretty easily, then I re-wired the key-switch, hooked up the battery and fuel pump relay again, got my Edelbrock Pro-Flo app ready, then added a couple of gallons of gas to the tank.
    Here's a simple restraining bracket I made to keep the fuel neck from flopping over simple restraining bracket for fuel filler neck.jpg
    It took a couple of priming periods (key cycles) to fill the fuel filter canister and purge the system. I checked for leaks each time. So far...so good.
    Once I saw a non-zero pressure at the regulator gauge, I checked all the joints again, and the good news is that all my hand-made joints were leak free! The bad news is that the NPT joint appeared to be leaking at the pressure sensor itself
    I was thinking the 1st thing to try would be to tighten it a little, so I looked at the Edelbrock website as well as the Summit website, and I didn't see any specialized wrench for the sensor. Here's a picture
    Does anyone know what size wrench this needs? It appears to be about 1 & 1/16" or 27mm between the flats...
    I figured it might take a "standard" sensor wrench...however specialized they might be, but couldn't find any.
    Helpful suggestions welcomed
    Craig C
  18. #413
    Dec 2021
    Flower Mound TX
  19. Thanks cc2Arider thanked for this post
  20. #414
    Sep 2022
    Thanks Mike
    I can try an adjustable wrench, but was hoping for something else since I'll have to remove that junction from the fuel line just to get that large of a wrench in on it...
    Craig C
  21. #415
    Sep 2024
    Craig, when you pull that apart and confirm that it's tapered pipe thread, be sure to apply thread sealant and stay a thread or two back from the end of the fitting. And no teflon tape.
    Pat
  22. Thanks cc2Arider thanked for this post
  23. #416
    Sep 2022
    Thanks Pat! I'll try to tighten a little, then if more of a solution is needed, that was my plan, too
    Craig C
  24. #417
    Sep 2022
    Hey Y'All,
    Good news about my fuel pressure sensor leak. It was the joint at the sensor that was leaking I ended up carefully removing that junction block to put it into aluminum vise jaws to unscrew the sensor. It was on there tight (by force)...apparently the old thread sealer did a good job of gluing it, but not of sealing it I cleaned it up and put some fresh Earl's sealant on it, tightened back up, refastened, and checked for leaks...all good now! Thanks for the tips
    Craig C
  25. #418
    Sep 2022
    More work on my Driver's side gauge pod
    Hey Y'All,
    This past weekend, I worked on the final details of my Driver's side gauge pod...
    In hindsight, I should've done more custom work before sending off for powder-coating...nonetheless, I made reliefs for the turn signal switch wires and the keyswitch. First though, I added low-profile nut-serts for the remaining fastening holes. Here's a couple of pictures with fasteners attached for mock-up
    and here's the refinement of the gauge pod with relief cuts and indicator lights mounted. For those interested, the indicator lights are 10mm diameter, high intensity(more on that later) LEDs...you can also see the low-profile nut-serts.
    Craig C
  26. #419
    Sep 2022
    More wire tailoring and tests of the indicator lights!
    Hey Y'All,
    In this last post of the weekend, I wanted to share that the dash switch wires got tailored to my layout needs (i.e., they got shortened ). The light switch wires simply got shortened with splices because I didn't want to go to the trouble of getting new female spades with restraining barbs to fit into the stock plastic connector. The keyswitch was easier since those are simple ring terminals -- I just made new ones. The remaining light-duty switches got new terminals on shortened leads...
    Here's a rough picture
    Then a couple of pictures I am really excited about -- images of what the indicator lights look like when illuminated. I wanted them to be bright so that I could see them clearly in direct sunlight. I think I succeeded -- these should remind me to not act like an old man and leave my blinkers on ... unaware for miles
    High Beams
    Turn signals
    For those wondering...yes, I used the emergency flasher switch and relay for this test ... and you can see the intensity difference of the left front indicator light just above the Driver's side front tire(park lights versus turn or flasher lights)
    Until next post, Happy Building!
    Craig C
  27. #420
    I had LED indicators like that on my first roadster… great to be able to see them on a sunny day but they sear your retinas when driving at night. I had to kill the intensity by blacking them out with a Sharpie.
  28. Thanks cc2Arider thanked for this post
  29. #421
    Sep 2022
    Thanks Jeff...your perspective is most helpful
    A backup plan is to add some Zener diodes "after the fact" in the harness. A much better plan would be to source the power from the variable intensity dash lighting...but that seems like too much trouble
    Craig C
  30. #422
    Sep 2022
    Driver's gauge pod wiring
    Hey Y'All,
    Winter weather here, so I'm happy to be working on "inside" projects and since I didn't want to be inhaling glue fumes, that meant more dash panel wiring...
    First I needed to confirm how much room I have behind the dash panel (again). I decided to move my Driver's side heater duct all the way closest to the firewall to provide maximum room for the harness design and layout. I used adhesive-backed zip-tie mounts...
    Here's a perspective
    moving the heater duct to the back provides more room for dash harness flexibility.jpg
    I also figured where I'd have the most room to add connectors and extra wiring for serviceability. Looks like between the Tachometer and the Speedometer is the compromise area since the heater and defroster ducts are taking up so much space...
    With that in mind, here's my Driver's side gauge pod wiring with connectors so that I can remove the "main" dash panel without removing the gauge pod (and steering wheel, turn signal assembly, etc)
    Installed and confirmed connector locations are still "in the zone".
    The wiring was good with the exception of the turn signal indicators...somehow I got them reversed...no worries...since I used weatherpacks, I just re-arranged 2 pins and fixed
    Feeling pretty good and wanting to reach a milestone for the weekend, I started on the "main" dash gauge wiring. Here's an initial wiring layout
    and confirming that there's still room back there. Just barely
    Getting the heater/defroster system fully functional and installed "with purpose" has been one of the bigger challenges of my build. Feels good to see it through
    One last note: The FFR-supplied light switch is "HUGE" compared to the other switches, so plan your layout around that. I mistakenly located my trip reset button right underneath the light switch and I think I may have to source another simple SPST push button switch because the molded strain-relief of the Speedhut-supplied switch harness is too tall...
    Craig C
  31. Likes RobHartley liked this post
  32. #423
    Sep 2022
    Initial electrical tests of the gauges...and some questions
    Hey Y'All,
    I couldn't resist the temptation to quickly wire up my Dash panel gauges with some twist-nuts "just to see" what they looked light illuminated and if they would measure the voltage accurately, keep clock time, and measure what meager fuel level I have in the tank...
    Here's the gauges illuminated -- looks good!
    Apologies if this is in a "sticky" post, but is it normal for the gauge "dimmer" function on the light switch to not affect the Speedhut gauge lighting at-all?
    It is either "on" or "off"...no dimming
    Next, I confirmed that the gauges "sweep" upon power-up, then I checked the values for "reasonableness". Seems good...however, upon power-down, I noticed that the volt meter still "held" the last value, as did the fuel gauge.
    Is that normal? I confirmed that I'm using the brown "gauge feed" wire and it is on the Accessory circuit. Furthermore, it has zero voltage with key off. Is this an artifact of the stepper motor gauge design, or is the power-down "park" function not working properly?
    Feedback welcomed...
    Craig C
  33. #424
    Yes, it’s normal for the Speedhut gauges to hold the last value when power is cut. So once you have it running you’ll find that the tach, oil pressure, temp, volts, etc. will all show what you had when you shut it off.
  34. Likes cc2Arider liked this post
  35. #425
    Sep 2022
    Thanks Jeff for confirming the gauge behavior
    I checked again, and if I key cycle "just right", I can get the needles to go back to the park positions.
    I'm also going to check my dimmer voltages...maybe an artifact of using an incandescent circuit on an LED system...
    Craig C
  36. #426
    Sep 2022
    More Dash details -- center gauges, zip-ties, and more
    Hey Y'All,
    Since I got confirmation that the gauges seem to be powered and illuminated correctly, I got busy finalizing the center gauge wiring details.
    First up, making sure I package the gauge wiring so that I can attempt to service them in the future: with a little extra wire length, dedicated connectors, and zip-ties
    Next, customizing the gauge switches to make them fit better for my dash layout (since there's so much competing for the same space behind the dash)
    motivation:
    then re-soldering similar switches (they might actually be the same sourced switches) to reduce the installed height
    then taking advantage of adhesive-backed zip-tie mounts to keep the main harness where I want it on the firewall panel (behind the dash)
    Next, checking the fit. Geez it was tedious, fiddly work to make sure I wasn't forcing it or pinching wires...I sure hope this extra effort pays dividends down-the-road...when I might have to remove the dash.
    Next post, getting the dash more ready for 1st engine start
    Craig C
  37. Likes RobHartley liked this post
  38. #427
    Sep 2022
    Trying to get things ready for 1st engine start
    Hey Y'All,
    I'm a little behind in my goals for this Winter...I really wanted to get to 1st engine start back in December...so, trying to make good progress while it is frigid outside As an aside, I'm really happy I got my garage more usable at the start of this endeavor a couple of years ago. Negative temperatures outside this past week...reasonable temperatures in the garage with a small space heater
    While trying to get the dash panel installed with all the "stuff" attached to it, I found that my "vintage" cigarette lighter is interfering with my behind dash ductwork
    I think I'll attempt to bend or otherwise reshape the connection terminals this week. Wish me luck that I don't have to re-design anything else!
    The overall package with vintage knobs I like it!!!
    I still need to upholster the dash and console, but that involves using contact cement, and I'm not willing to do that job while it's cold outside (vapors plus space heater in the garage...no), so that job will wait until after engine start...
    Then I got REALLY motivated to unpackage my "engine start" sidepipes and mock them into place. I'll save my Gas-N pipes for the "real" installation later...
    I copied other Builders and simply swapped the pipes side-to-side so that the mounting tab pointed up. Then used the supplied mounting bracket mounted to the door hinge bolt hole.
    mounting details with rubber washers for crude vibration "dampers"
    driver's side side pipe mockup detail.jpg the passenger side required spacers, so I just used some extra washerspassenger side pipe mockup detail.jpg
    Observation:
    Adding the sidepipes really makes the car wider than before. I hit my shins several times already
    Getting closer to 1st start...maybe next post
    Until then, Happy Building!
    Craig C
  39. #428
    Sep 2022
    Designing my Courtesy Lighting system
    Hey Y'All,
    Today I put together my Courtesy lighting system. I used high intensity LED panel lights so that they'd be the same vendor/source that I used for the dash indicator lights.
    I got them delivered this past week, so I spent the AM making a harness fixture. I never made one before, but have seen them in Aviation manufacturing. I already had a multi-purpose 24"x24" plywood work surface, so I just layed-out the dimensions and screwed temporary zip-tie mounts at the desired lamp locations. I gave some extra length so that the installed harness would be tidy against the mounting panels and went to work...
    Here's the fixture serving its purpose
    A few crimps for the Weatherpack 2-way connectors and it was time to test it on the car. Here's a picture (dark garage, but bright sunlight coming thru the small garage door windows )
    Then, I located and mounted the door sill lights and here are the results
    driver's door sill courtesy light.jpg passenger door sill courtesy light.jpg
    There will be additional lights on either side of the console pointing down at the sides of the transmission tunnel near the inner footbox panel edges, but that will have to wait for me to take out my console reinforcement panel and drill the holes...
    Lastly, here's an image of the approximate lighting for the inside of the console (using one high intensity LED)
    Next post: First engine start!
    Craig C
  40. #429
    Sep 2022
    First engine start!!
    Hey Y'All,
    I couldn't wait to post this...it's been a long time coming
    https://rumble.com/v75g302-angelina-first-start.html
    The setup:
    I took out all the spark plugs and turned over the engine with the starter to verify that I could see oil pressure values on the dash gauge.
    Then I reinstalled the plugs and did a nut-and-bolt of the engine bay and exhaust (and cleaned off the smudges from the headers).
    Then I got 2 fire extinguishers at-the-ready.
    Then I got the Edelbrock Pro-Flo4 ready on my smart phone and hit the record button on my old smart phone camera on a tripod...
    Good news: no drastic leaks; the solid engine mounts didn't seem noticeable at all; nothing fell off
    The not-so-good news: the alternator doesn't seem to be charging the battery; the Passenger-side headers got a lot hotter than the Driver's side. I hope my wiz-bang fuel line design isn't the reason...we'll see
    Also for the record, I didn't mess with the Pro-Flo4 settings at-all -- I used what Mike Forte' had programmed in when he tested it on the dyno a couple of years ago...so I may "store" the Forte' tune, and attempt to load in a fresh set-up "wizard" tune for next time...
    All-in-all, I'm very pleased...can't wait to keep working on Angelina some more!
    Happy Building,
    Craig C
  41. Likes Stangrob, AndrewIdaho, Railroad liked this post
  42. #430
    Sep 2024
    Congrats man! BIG milestone.
    Pat
  43. Thanks cc2Arider thanked for this post
  44. #431
    Jun 2023
    Texas Hill Country
    Brings a smile….congrats
    BUDFIVE
    Complete kit order 8/28/2023, Delivery 11/28/2023
    347 Ford Dyno 10/12/2023
    First Start 7/4/2024
    Go Cart 8/31/2024
    Licensed, Registered 6/17/2025
  45. Thanks cc2Arider thanked for this post
  46. #432
    Big congrats on the milestone Craig!
  47. Thanks cc2Arider thanked for this post
  48. #433
    Dec 2017
    Congrats Craig! Sounds great!
  49. Thanks cc2Arider thanked for this post
  50. #434
    Sep 2022
    Thanks Pat, BudFive, Jeff, and Chad for the well wishes! This forum is GREAT
    Craig C
  51. #435
    Sep 2022
    Indicator light dimmer
    Hey Y'All,
    I'm back down to earth now that I got the engine started. I plan to follow-up Tues or Wed this week for some more fun since the temperatures are gonna be in the upper 30s to mid 40s -- I can leave the garage door open for extended idling and tuning
    So...to round out my weekend, I got back to some dash wiring. Special thanks to Jeff for providing feedback on my "bright" indicator lights. I got to thinking, and I decided to make a simple dimmer circuit for both the indicator lights as well as the gauge lights.
    I sourced a 2-gang 10k Ohm pot (typically used for electric guitars) so that I could dim both independent circuits at the same time. Then I made a simple bracket out of some left-over 0.040" Al sheet and mounted it below the steering column in the two unused bolt holes. The potentiometer was small enough to fit into the space that was cut-out from the factory bracket
    I can reach under the steering column to make adjustments (as needed) while driving. Here's a few pictures...
    Normal "bright" setting
    and "Dim" setting
    Sometime next week, I plan to disassemble my dash and console to get access for the gauge wiring, and add my dimmer circuit for that...
    Craig C
  52. #436
    Sep 2022
    Cooling system side-job
    Hey Y'All,
    I was planning to work on my instrumentation dimmer circuit, but I got sidetracked with another job. I noticed that when the cooling system got up to operating temperature, that the heater lines would get soft and sag a little due to the unsupported weight of my heater valve
    I'd like to keep that valve from bouncing on top of the Passenger footbox panel, so I made a bracket Better to get this out-of-the-way now while I can get to everything...
    I had some polished Stainless sheet in a left-over, odd-ball shape, so I trimmed it up, drilled some holes, and bent it. Then I used some spare RAM mount handlebar mounting hardware (u-bolt, plus plastic tubing spacer, and plastic bolt nubs) to create this:
    Not too bad for some spare parts lying around
    Next post: more Cooling system finishing
    Craig C
  53. #437
    Sep 2022
    Deliberations on my Coolant Tank
    Hey Y'All,
    Late post from this past weekend due to my account being accessed inappropriately or ???
    As some of you have also gone thru deliberations on which Coolant Tank to use, I'll outline my thoughts and decision...then show you what I did.
    I liked FMan's choice of a Canton 2qt unit, and this is reflected in many other builds...special thanks goes to Greg for getting me some measurements for his installation
    I went so far as to make a cardboard model and mocked it up in the engine bay...I just wasn't "feeling it". I then thought again about the FFR-supplied 1qt unit, and how to make it work for my build...
    Rightly or wrongly, I believe I don't need a large tank since I'm using the Evans waterless coolant...and therefore don't expect it to expand much under high heating conditions. Then, I remembered some had used a Mishimoto tank, so I looked into it. It is only 1qt size, but has options to configure it and it appeared to be well-made. I checked Summit, and it was less expensive, too...so I bought it as a "let's try it" experiment.
    Here, I've mocked it into place:
    I liked what I was seeing...then deliberated for a long time about "how" to mount it. Then, I took the advice of others who say not to overthink things (which is a hard habit for me to break )... so, instead of making a new bracket for it, I decided (like many other Builders) to just mount it to the F-panel...so that's what I did. I drilled out the holes to 3/8" and used some rubber grommets with 1/4-20 bolts. I also used rubber-backed washers for the tank tabs. Here's the results:
    The biggest surprise was that the panel "warp" wasn't that bad...it was only about 1/4" where I chose my mounting holes. Also, the panel relieves the warp at the lower front bolt hole and there is enough distance to the nearest rivet so that it is not a big deal.
    Now for the "bad" news: The lower sight window fitting leaked...it was a real "dribbler", so I'll ask how well the Lifetime warranty is on Tuesday As a backup, those fittings seem very commonly used for air suspensions, and Summit has some
    Happy Building!
    Craig C
  54. #438
    Sep 2022
    Follow-up on Mishimoto warranty parts replacement
    Hey Y'All,
    Here's a follow-up on my warranty replacement parts from Mishimoto: No hassle, and delivered within days
    This time, it appears the NPT threads have some sealant on the threads ready-to-go, and I made sure the sight tube was fully inserted into the "press to fit" fittings by feeling for the second "seat" pressure on the o-ring inside. Then, I tested by attempting to pull it apart -- good-n-solid!
    Here's a picture:
    I still may swap the fill & overflow fittings with the sight tube (side-to-side)...and it is easy with this unit since the screw holes are identical This means, I'll need to get a 90deg 1/8NPT to 3/8" barb for the filler neck "T"...choices, choices.
    Then, I'll replace the Evans Prep fluid with the "real" stuff...
    Craig C
  55. #439
    Sep 2022
    Messin' around with pedal ergonomics
    Hey Y'All,
    This past weekend was spent on other critical things, but I managed to get into the Garage for some things that needed "doin' " there, too
    It's kinda interesting how Jeff posted about how these cars need to be respected, and I had independently double-checked my Accelerator Pedal linkage to confirm if I had a "soft" tip-in from idle as well as confirming how different pivot points and angles can impact what the engine "sees" when you depress the Accelerator pedal...
    Here's my measurement setup (yes, pretty crude) Reminder that this is a RT-tribute styled AccPed with Forte' pivoting linkage...
    and here's the results (as measured with Pro-Flo4 system feedback)
    A few points to make: 1) measurement error is not too bad considering the crude setup. 2) my mockup well before-hand seems to have paid off in a very linear response. Note the 2nd-order curve-fit coefficient is VERY small. You can expect non-linear responses with all of the travel "arcs" at each pivot. I was hoping for a more "soft" tip-in, but a linear pedal response is very good, too. 3) a simple change of pivot point makes a lot of difference. The reduced "gain" for the longer-travel pedal is what I'll try to use. This was my initial design, anyway (but had doubts about effective heel-n-toeing). Now that I can measure what the Pro-Flo4 "sees", I think the heel-n-toe action is going to be fine...
    For those interested in mimicking my set-up, the RT-style pivot assembly (made by Mountain Metal Works) is installed upside-down with the allen set screws accessible from the top of the footbox access panel (instead of through the footwell area).
    Lastly, I started the mock-up of a "dead" pedal. This is VERY preliminary...but might give you inspiration to make something similar
    Craig C
  56. #440
    Oct 2020
    Albany, NY
    Incredibly clean build Craig. Congrats on the first start and I love the dash.
    Build 1 MK4 #10008 - Delivered 03/03/21, Graduated 7/20/22 - Sold 6/6/24 Build Thread #1 https://shorturl.at/K9fuy
    Build 2 MK4 #11061- Delivered 08/24/24 Build Thread #2 https://shorturl.at/OZowi
    Build 3 35 Pickup #329 - Delivered 10/28/25 Build Thread #3 https://shorturl.at/Ty4QQ
  57. Thanks cc2Arider thanked for this post
