Quote Originally Posted by orangemonkey65 View Post
Just subscribed to your build thread and gonna be fun to watch yours - I see you've also got the kids involved for sure!
Those metal tabs you mentioned earlier, I didn't see anyone reply about them, but they are the mounts for the sensors on the pedal box for the brake and clutch switch. You have to drill out the back side of the tabs on the pedal box and then those are bolted on.
Right. Except for a Coyote build you don't mount that tab or standard switch there. The Coyote has its own clutch switch. The switch comes with the Coyote control pack. The wiring is in the Coyote harness. If you bought the FF Coyote install kit, it includes a bracket to mount the switch.
