Thanks Thanks:  76
Likes Likes:  189
Page 10 of 12 FirstFirst ... 89101112 LastLast
Results 361 to 400 of 457
Thread: Project Deimos: An LS '65 Coupe Build: Engine no longer overheating!
  1. #361
    Nov 2022
    Niles, MI
    It's a good thing I'm building a car instead of a boat, because I've had so many leaks lately that this thing would have sunk by now.
    The massive coolant leak from the poorly assembled water pump has been fixed. I was able to successfully pressure test the system to 20 psi (4 psi over what my radiator cap is rated).
    Next, I tried bleeding the power steering system but could not get the air out. I realized I had a small leak at one of the steel fittings on the high pressure hose. I did make that hose, but I don't think it was my fault because it was leaking from one of the fitting's tube/body and not from the hose end part that I assembled. I still had the hose from the FFR power steering kit. It was about a foot too long but I made it work. Put some basalt fiber sleeve over it to match some of my other hoses
    The next leak is completely my fault, and I'm still sick to my stomach over. I did what I've been warned a million times not to. I was tightening down the nut on the positive battery lead when my wrench grazed a nearby stainless brake line (and yes, I stupidly had the neg cable already hooked up). There was a spark and immediate deluge of brake fluid everywhere.
    I'm going to try to repair it in place without taking the whole line out. But I honestly don't even want to think about it right now. Very disappointing
    There has been some good news though.
    I finished my heat shields made of dimpled aluminum stretched over 0.09 inch aluminum sheet, thern I cerakoted them with high temp V-series, and installed with spacers to give a 3/8 inch air pocket behind.
    I also Cerakoted the headers and side pipes
    I decided the heat shields were necessary after learning more about aluminum panel heat/sound insulation, and realizing I had probably made a mistake with my footbox linings. I had lined them with foil covered butyl as the first layer against the panel. Then closed cell foam, mass loaded vinyl, another thin foam, then vinyl upholstery.
    Well, I learned butyl has a relatively low melting point (~250 F) but will start to droop at even lower temp, around 150 F. Thus the heat shields. Hopefully they work.
    [Continued next post]
    Blueprint LS3 427, T56, IRS
    Received: 5/24/2024
    First Start: 2/7/2026
  2. #362
    Nov 2022
    Niles, MI
    [Continued]
    I filled the engine with oil (no leaks!) and made some good priming, no-spark pulls with the starter. It was great to see oil pressure on the gauge.
    The spark plug wires on the LS nearly touch the headers, so I wanted heat shield sleeves. But I wasn't happy with what I found online. I ordered some pre-made ones on amazon but was disappointed by how stiff they were and didn't like the look.
    I made my own by first putting a silicone coated fiberglass sleeve over the wire, then covering that in basalt fiber sleeving. It's much more flexible and looks good
    I'm darn close to starting this engine (finally!)
    I think I only need to get the front wiring harness hooked back up (for the fan), put the side pipes on, do the initial setup on the Terminator X Max, and get some gas.
    First start on MLK Day???
    Received: 5/24/2024
  3. Likes 460.465USMC liked this post
  4. #363
    Nov 2020
    Damascus OR USA
    Jim - your spark plug covers look really nice and I am sure they will work but keep an eye on the boots. In the future, if needed, you can also purchase hi temp spark plug wires with ceramic boots. I have these on my LS and they work great.
    https://www.holley.com/products/igni...rk_plug_wires/
  5. Likes AaronR liked this post
  6. #364
    Nov 2022
    Niles, MI
    Quote Originally Posted by PNWTim View Post
    Thanks Tim. I wasn't aware of those type of wires/boots. Mine are what was shipped from Blueprint, which I'm sure are "just okay" quality
    Received: 5/24/2024
  7. #365
    Western Mass
    That's quite the update Jim! I'm impressed with your persistence in working through all these detours and details. We'll be certain to share our leaks when we have them
    Gen 3 Coupe #654
    Kit Delivered: 9.20.2025
    Build Thread: Garcia Family Coupe
    Blog: Garcia Family Coupe
  8. Thanks JimStone thanked for this post
  9. #366
    Aug 2019
    Spokane, WA
    Those backsteps can feel defeating. Ask me how I know. But first start will be all the sweeter as you solve them one by one. Keep up the great work, Jim! We're cheering for you, and looking forward to hearing that beast wake up and rumble!
  10. Thanks JimStone thanked for this post
  11. #367
    Nov 2022
    Niles, MI
    Thanks for the encouragement on the leaks, guys
    So, no First Start on MLK day. New plan is for this Saturday
    Put some fuel in the tank and ran the fuel pump. Had a leak at the fuel regulator where I had a stainless hard-line connection to the firewall bulkhead fitting. I didn't feel like remaking the hard-line, so quickly put together a PTFE AN fuel line with leftover parts
    Leak fixed, I set the regulator to 58 psi and it held pressure fine.
    I used the 87+ Ford fuel tank sender setting on the Speedhut gauge, which was the best match to my pre-installation measured Ohms of 12-142. I put 5 gal of gas in and it's showing only just past 1/8 tank, so I may need to adjust that later
    Put the side pipes on and installed the hangers. I had Cerakoted them earlier. Turned out okay, but I had some scuffs around the collector flanges, so I may try to touch that up with an airbrush later.
    Installed a fuel pump push bottom switch on the trans tunnel cover. Was getting tired of the fuel pump running when testing other electrics and needing to take in/out the fuse.
    Also did the basic initial settings for the Terminator X on the handheld device.. I've been learning a lot from ChatGPT about some additional settings to input before First Start to get a better idle, based on my cam specs. Need to hook up a laptop for that, and download the Holley software
    You can also see where I made a hole in the trans cover panel for a cup holder. I can't leave anything well enough alone, so I put blue LEDs around the bottom
    That's it for now. Next update: hopefully after a successful fire up of this engine
    Received: 5/24/2024
  12. Likes jbs72697, AaronR liked this post
  13. #368
    Nov 2020
    Damascus OR USA
    Looks to me like you are getting pretty close. Just a couple of comments. First, I think you need at least three or four more wires behind your dash to even out the look . Second, I like the additional lighting anywhere you can put it. It's one of the great things about LEDs in my opinion.
    On a side note, I am surprised your fuel pump was on continuous run. I don't have any familiarity with the Terminator X but I know with the GM PCM it's similar to the Coyote setup. It primes the fuel system for 1-2 seconds and shuts off unless the engine starts. Either way, looking forward to the video this weekend. Good luck!
  14. #369
    Jan 2018
    San Diego, CA
    Get that thing started!!!
  15. #370
    Nov 2022
    Niles, MI
    You're not suppose to look at the wires! So embarrassing. I need to censor out that rats nest in future posts
    You're right about the Terminator X being able to control the fuel pump. I had already wired the pump according to the FFR manual, so when I installed the Terminator X a year later I naively thought "what's the difference?" Now I know.
    I could have switched it over, but I like the button now. More things to press in the ignition sequence, like a racecar, or a fighter jet.
    On it Mark!!
    Received: 5/24/2024
  16. Likes PNWTim liked this post
  17. #371
    Jul 2025
    does the terminator x not need a fuel pump speed controller? Im planning on running a Aeromotive 525lph in tank pump with an Aeromotive fuel pump speed controller to modulate the pump. would be nice if the terminator x ecu does that for me!
  18. #372
    Nov 2022
    Niles, MI
    Quote Originally Posted by jemorgan3 View Post
    Whoa, what are planning that needs that big of fuel pump?
    So, your question about fuel pump modulation opened a can of worms. I had never read in the forum of someone using a fuel pump speed controller. However, most builds on here have smaller pumps than you. I did some research and there does seem to be an ability for the Terminator X to act like a PWM, but the discussion went way over my head.
    For my size fuel pump (340lph), it doesn't seem needed.
    And Tim,
    After reading more, I am going to switch over to the Terminator X handling the on/off of the Fuel pump, like you suggested. It's a safety thing. If the car crashes, the way I have it the fuel would keep pumping, perhaps spraying from broken lines onto hot headers and pipes.
    My push button fuel pump switch is simply in the ground trigger loop for the relay. So I'll just hook up the Terminator X green wire to my push button and all will be well
    Received: 5/24/2024
  19. #373
    Jul 2025
    My previous fun car was a 5th gen ZL1 Camaro, 18lbs of boost from the OEM LSA blower... that blower can go from a vacuum to 18lbs at very low rpm with a high load, so having enough fuel instantly is pretty crucial. From owning that car, I have a paranoia about fuel pressure and supply. With injectors, you absolutely want something that isnt to small, but also not oversized either. With a pump, however... There isnt a reason not to go a bit overboard with it!
    From the research ive done, the terminator system can command a pump on/off, but cannot modulate its duty cycle. Running a fuel pump at its maximum capacity 100%W of the time will work, but will also reduce its lifespan. A true PWM fuel controller will match the duty cycle of the pump with the demand. Just makes it a more efficient system. I would argue that any aftermarket fuel pump will benefit from a fuel controller. will it run without one, yes. Will if fail earlier, also yes.
    To answer your question, my coupe is getting a forged LS3 based 416 with a focus on RPM. But when the 525lph pump is only $100 more than the 340lph, why not buy the insurance (or enable the addition of an LT4 blower later).
  20. #374
    Nov 2022
    Niles, MI
    The LSAs in those ZL1's are quite the engine. 59 lb injectors with boost, so yeah, need a lot of fuel. I think you'll be perfectly happy with a NA LS3 416 in a car nearly half the weight!
    This is where I got the idea you could use the Terminator X for fuel pump modulation: https://www.corral.net/threads/how-t...tor-x.2505786/
    But honestly, my eyes glazed over halfway through reading
    Good luck your build!
    Received: 5/24/2024
  21. #375
    Nov 2020
    Damascus OR USA
    Quote Originally Posted by JimStone View Post
    And Tim,
    Probably wise Jim. Your rollover module should also manage that situation if wired correctly but double safe is good. For what it's worth, the Terminator X probably has built in PWM control for your fuel pump if your pump is capable of supporting it. It's not particularly necessary but still a nice feature.
  22. #376
    Nov 2022
    Niles, MI
    No first start yet. I've been all ready to go for a week, but finding the right time when my family is all together and not rushing to/from sports games/practices or school events has been a challenge lately.
    In the meantime, I've been messing around with some other things.
    I posted this in the recent thread about Coupe LED taillights, but I'll post it here for posterity:
    I've long been searching for LED halo taillights for the back of the coupe. I love that look and find the taillights sent with the kit to be very mediocre, at best.
    GRP makes some really nice looking ones that have been used successfully by a few folks on this board. https://www.gregsraceparts.com/produ...print-3-eleven
    My beef with the GRP halos are the large size that takes over the back of the car. Those are 4.75" diameter. I found some that are about an inch smaller, which doesn't sound like much but actually is 38% less surface area.
    They are also $500 less than the GRPs
    I found them at CarbonMiata.com, a retailer focused on custom parts for the Miata community.
    https://www.carbonmiata.com/shop/hal...1105#attr=5147
    I was skeptical of the quality at $70 apiece, but they seem to be legit. Supposedly hand made, but they don't look or feel DIY
    They have integral lights in the middle that can be either back-up or turn signals.
    The white LEDs that came with them were underwhelming, so I got replacements that are much brighter (not as noticeable in pics as in person). https://www.amazon.com/LASFIT-Upgrad..._rpt_ba_s_2_sc
    There is also a function to use the actual ring LED as the turn signal, which I'm leaning towards
    The halos are dual brightness (brake and driving lights). Both are very bright. The brakes are almost blindingly bright (a good thing). The driving lights are maybe a tad too bright, so I've ordered some resistors to see if I can take them down a little. Not a deal breaker if that doesn't work.
    They come with LED drivers/wiring harnesses
    I am going to ghost the center lens so it matches my blacked out theme
    They have mounting studs so I'll figure out some way to mount them. Will need to be recessed slightly into th body. I don't know if I'll do the whole fiberglass "tub" thing that others have done. Probably will just cut a close fitting hole and make a thin bezel on Send-Cut-Send or my 3D printer.
    You might tell I'm pretty excited about these. I think they're exactly what I was looking for.
    Received: 5/24/2024
  23. Likes Higgybulin, 460.465USMC liked this post
  24. #377
    Jul 2024
    SE Michigan
    I've been waiting for this post since you first announced that you'd ordered them, they look great! Can you share some details on why it took 3 months for them to arrive?
    Dan
    Type 65 Coupe #614: Delivered 1/26/2025 - Gen 4X Coyote - T56 - IRS - Wilwoods from Levy - PS - AC
  25. #378
    Nov 2022
    Niles, MI
    Quote Originally Posted by bishes View Post
    Dan,
    I think I did get unlucky with the shipping and don't think 3 months is typical.
    I expected it to take a while since they're "hand made" and coming from China. The first shipment took about 6 weeks, but inexplicably only contained the drivers/wiring harnesses. My contact at CarbonMiata, Marc (who manages the info@carbonmiata.com account) , was very apologetic and got another shipment going. I was following the tracking and noticed the 2nd package got held up at a Chinese package sorting facility for over a week. Marc was somehow able to get that sorted after I let him know.
    The reviews from CarbonMiata are generally good and they do business globally. Marc was great about answering questions and sent me additional photos before I bought. I have a 24 email exchange with him.
    I wouldn't let my experience scare you away. Just know it will take about 6 weeks to get them.
    Received: 5/24/2024
  26. #379
    Jul 2024
    SE Michigan
    Thanks for the info, that's very helpful!
    Dan
  27. Likes JimStone liked this post
  28. #380
    May 2021
    Fort Worth, Texas
    Nice! It's always fun to read about others approach to making their car their own.
  29. Likes JimStone liked this post
  30. #381
    Jul 2025
    Very cool taillights!
    Was wondering how much clearance you gained with the LS2/C6 oil pan? It seems the best choice for ground clearance, but not so much for oil capacity.. Melling suggests at a minimum, a 6 quart pan when using the HV/HP pump, which my engine builder highly recommended for my bearing/ring tolerance. Is the LS2 pan above the frame? How much?
    Thanks!!
  31. #382
    Nov 2022
    Niles, MI
    Thanks!!
    With the C6 pan, it is exactly flush with the bottom of the frame. My lowest point is the bell housing lip, which is about 1/2 inch below.
    Improved Racing has a nice comparison page:
    https://www.improvedracing.com/gm-ls...Jiiv6XZFwRuKxJ
    Blueprint sends the engine with a 4th gen F-body pan
    You can see it's 3/4" deeper than the C6
    There may be something out there that has more oil capacity and still 4.85 in deep, but I couldn't find one that also would clear the rods on a stroked LS.
    One alternative to a short pan would be to add spacers to the motor mounts to lift the engine up. I didn't want to mess with that
    Received: 5/24/2024
  32. Thanks AaronR thanked for this post
  33. #383
    Aug 2019
    Spokane, WA
    Thumbs up on the tail lights, Jim. Saweeeet!
  34. #384
    Nov 2022
    Niles, MI
    Thanks Chris!
    One more thing regarding the taillights, then I'll put them away until body fitment time:
    I was messing around with them today and figured out a way to easily make the center light recessed into the halo. That's something I really liked about the GRP Evora lights.
    The center light can be detached by taking out the steel "pinch" triangle that locks (sorta) the center housing in place. Then it's just a press fit
    Then rotate the triangular base to the next notch and use the pre-existing halo lens mounts, with longer screws, to secure the center housing. This keeps it perfectly centered
    It's only maybe 1/2 inch, but I think will look great with a smoked center lens
    Received: 5/24/2024
  35. #385
    May 2021
    Fort Worth, Texas
    The recess does look better. Nice work.
  36. Likes JimStone liked this post
  37. #386
    I like the look of those!
  38. Likes JimStone liked this post
  39. #387
    Nov 2020
    Damascus OR USA
    I think it's the little details that really add up. Those are going to look great.
  40. Thanks JimStone thanked for this post
  41. #388
    Nov 2022
    Niles, MI
    First Start
    Finally got around to doing the deed:
    [/url]
    A happy event. It almost didn't happen though. At first we got violent backfiring and roughness from the right cylinder bank. Eventually, we figured out the right coil harness was reversed. So it was basically trying to ignite on the exhaust stroke.
    How did that happen? No idea. Clearly user error when reassembling the engine.
    Thanks to my Dad and brother-in-law for helping me figure it out.
    Thanks to my son for being standby firefighter. Fortunately, not needed.
    Lewma will be proud - got that engine started!
    Received: 5/24/2024
  42. #389
    Southern Ontario/Cape Coral FL
    Great job man!! I was thinking the video was going to show the violent backfiring! You probably didnt want to see that again though!!
    Congrats!!!!
    Higgy
    MK4 #11354 picked up 10/06/25
    MK4 #11173 picked up 01/20/25
    MK4 #11012 picked up 04/16/24 SOLD
    MK4 #10616 picked up 4/10/23 SOLD
    MK4 #9759 picked up 4/3/19 SOLD
  43. Thanks JimStone thanked for this post
  44. #390
    Jul 2025
    Folkston,Georgia
    Well all right congratulations….. now ……DO A BURNOUT …. sorry Jim I couldn’t resist….. btw the taillights look awesome !
  45. Thanks JimStone thanked for this post
  46. #391
    Congratulations on the huge milestone!
  47. Thanks JimStone thanked for this post
  48. #392
    Jul 2024
    Detroit Mi
    Congratulations Jim !
    Type 65 Daytona G3 Coupe #635 - Dart 363" SBF
    1970 Plymouth Road Runner 440 6-BBL Super Track Pack
  49. Thanks JimStone thanked for this post
  50. #393
    Jan 2018
    San Diego, CA
    Congrats Jim!!
  51. Thanks JimStone thanked for this post
  52. #394
    Western Mass
    Congrats Jim, that has to feel so good!!
  53. Thanks JimStone thanked for this post
  54. #395
    Nov 2020
    Damascus OR USA
    Purrs like a kitten Jim. A little more throttle and the lion will appear. That's a great moment and you're fortunate to have the family in attendance.
  55. Thanks JimStone thanked for this post
  56. #396
    Congratulations Jim! Big milestone
    Is that you in the seat? Methinks your noggin is gonna' bump the roof!
  57. Thanks JimStone thanked for this post
  58. #397
    Sep 2022
    Awesome moment Jim...and I agree, it is good to have your Family there to appreciate your milestone
    Craig C
  59. Thanks JimStone thanked for this post
  60. #398
    Aug 2019
    Spokane, WA
    Wahoo! Sounds mean! Congrats! I don't recall, are those Gas-N pipes?
  61. Thanks JimStone thanked for this post
  62. #399
    Nov 2022
    Niles, MI
    Thank you everyone for the comments!
    I fit in there when I test mounting the seats with the body on over a year ago... Maybe I grew? Might need to incorporate a Gurney Bubble
    Those are FFR pipes that I Cerakoted
    Received: 5/24/2024
  63. #400
    Aug 2025
    Wow, your engine sounds like it's running great. That's a beautiful purr! I think we have the same engine. I also got the BP 427 LS engine for mine. Good to know I will need the C6 oil pan. I'll just go ahead and buy that now which will make the 3rd oil pan I bought for this... ha. What windage tray and pickup tube did you use for yours? Were you able to reuse from the pan supplied by FFR?
    I'll be using an 8HP75 transmission with mine instead of the T56. I just picked that up last week. Hopefully I won't have any clearance issues with the bellhousing since it's rather large on the Ram version I have (it's from a 2024 Ram 1500 2wd).
    I'm really enjoying seeing your progress and hopefully learning from some of the hard-earned experience you're sharing. Thanks!
