This was one of those weeks I just needed to get through.
Rear brakes - *finally* got the right hardware / spacer setup. Background - 11.6" rear brakes / mix of Saturn / Ford I think. There's a bracket from FF to bolt to the IRS hubs. You need to center the caliper over the rotor, which you do with spacers. Unless you run out of room on the bolt, then you change the bolt. This was a 3x problem. First, replacement bolt was hex, not 12 point. Wrong, cable interference. Then, get 12 point bolt from Mcmaster. Wrong, it's 14mm, not 12mm, interference. Bel-metric was able to the me the right bolt. I don't know how many days this was, but too many.
Then, the emergency brake cable comes almost directly downwards, and needs something to keep the axle from getting it wrapped up. I made a small bracket from some 3"x.125 AL,bolted to the lower control arm. Needed new bolt here so that the nylon engaged in the locknut. AN lines - used Fragola PTFE lined hose. -4 for reservoirs. Which is more of a pain to assemble than the upcoming -6 for fuel.
Brake plumbing - AN lines for reservoirs to the non-standard Tilton MCs. That was mostly fine. It's tight. Very tight. If I was doing it from scratch, I'd do it a bit differently and give myself more room. Double-flared lines - ditched the FF lines (green coated steel for NiCopp). I wanted correct length, no unions, and I didn't mine flaring the lines. Used the Eastwood $$$ kit, after the first few practice tries, I was good. Getting the 2 lines from the MCs to the brake booster as one piece was more than difficult for my first time doing hard lines. 1/8" TIG rod helps for mockups and you get 36" to work with. More experienced folks would be better at how much the bend eats up, keeping things clocked better, etc.
Fuel lines - -6AN feed/return. It's overkill on my 347, but there's not a lot of options between 5/16 hard line / 1/4" return from FF and this. If I ever want more power, the fuel lines will handle it. I chose to run hard lines through the tunnel. I'll have a driveshaft safety loop, but there isn't any other place to put lines other than the tunnel. Otherwise the lines will hit ground first. I used some fancy adapters from Breeze Automotive to go from the 3/8" NiCopp to -6AN male. I need some AN fittings to move forward, I bought just a few so I wouldn't have a ton of unused ones. I want to 3d print custom width spacers/clamps for the hard lines front and rear to keep them oriented like I have them.
I need to read up to see what's next. I think....engine/trans, so that means the Mid-Shift kit needs done.
Plumbing reservoir by
Rick Shank, on Flickr
Pedal box plumbed by
Plumbing front by
Plumbing pass side by
Plumbing tunnel by
