Pat, I also saw the 1AWG recommendation on the engine ground to battery minus. In my case I had some 6 AWG on hand so used that. Rear mounted Battery to a bellhousing/engine bolt, flowing thru the tunnel. Easy to run and tie in at both ends. 1AWG sounds a bit crazy and only really comes into play during cranking IF the existing braided straps are compromised.
