It's tough to know where you're at without a bit more info. What is your static ride height? Taken at the 4 corners from the square side frame tubes.
I have 300#/400#, F/R springs and run at 4.5" ride height. I drag a bit here and there but that's with a 4" splitter.
Are the suspension components mounted to the S (as opposed to R) holes/attachment points.?
