Thanks Thanks:  11
Likes Likes:  232
Page 7 of 7 FirstFirst ... 567
Results 241 to 257 of 257
Thread: # 1115 resurrection
  1. #241
    Sep 2022
    Huntington, IN
    When I installed the Boyd's tank, I had to make a bracket holder for the filler since I have a Gen 2. I was not thrilled with it and definitely not thrilled with it being inside the trunk. So last night I got the hole saw out and moved it. Always fun cutting holes in your car... lol
    Tried to bevel the top edge to give it a little less of a sharp edge look but might still need some work. Thinking of ways to maybe recess it. Might look better painted to match the body, we shall see. 20241123_125021.jpg20241122_200110.jpg20241122_200123.jpg
  2. Likes JimLev, TxMike64, Ltfracing liked this post
  3. #242
    Sep 2022
    Huntington, IN
    playing with dead pedal ideas
  4. Likes Ltfracing liked this post
  5. #243
    Consummate Learner
    Kingsland, TX
    Quote Originally Posted by Just 1 More View Post
    I have a very similar plan! Looks Good!
  6. #244
    Sep 2022
    Huntington, IN
    A little more work on the hood contour to the body
  7. Likes Ltfracing liked this post
  8. #245
    Sep 2022
    Huntington, IN
    Took advantage of the warm day and Finished the rear swaybar today. made brackets for the rear axle housing and welded them on. Thanks to James Shaw for the suggestion of making the arms longer. I made adjustable length arm extensions for more adjustability. Ignore my welds, i'm not a welder and i'm even worse laying on my back.
  9. Likes Ltfracing, JimLev liked this post
  10. #246
    Sep 2022
    Huntington, IN
    I made a couple e-brake cable holders out of some 1st Gen Camaro cable holders
  11. Likes Ltfracing liked this post
  12. #247
    Sep 2022
    Huntington, IN
    Bump steer kit done. Had to take 3/4" off the inner tie rod, probably should have taken a full inch but I can always revisit it if needed.
  13. Likes Ltfracing, JimLev liked this post
  14. #248
    Sep 2022
    Huntington, IN
    Got the hood hinge sorted out and now have a functional hood. I need to figure out how I want to "latch" it at the back. I'm not a big fan of the FFR supplied latch and cable. Also going to need a big hole for an air cleaner or scoop, it just clears the carb
  15. Likes Ltfracing liked this post
  16. #249
    Nov 2020
    Damascus OR USA
    Looks good Frank. Looking at that hood when it's up like that makes me think you could use it as an auxiliary propulsion device with an appropriate tailwind. You could peek through the hole you're going to cut for your scoop.
    Build 1 - 1969 Camaro Build Thread Here: https://www.camaros.net/threads/tims...y-getter.45926
    Build 2 - 1965 Daytona Coupe # 620 Build Thread Here: https://thefactoryfiveforum.com/show...-Type-65-Build
  17. Likes Just 1 More liked this post
  18. #250
    Sep 2022
    Huntington, IN
  19. Likes Ltfracing liked this post
  20. #251
    Sep 2022
    Huntington, IN
    Getting it looking like a Hot Rod again
  21. Likes Ltfracing liked this post
  22. #252
    Consummate Learner
    Kingsland, TX
    Who makes that gas pedal?
    I had to stand on my head to figure out what was going on... =-)
  23. #253
    Sep 2022
    Huntington, IN
    https://www.summitracing.com/parts/SUM-460006
  24. Thanks TxMike64 thanked for this post
  25. #254
    Sep 2022
    Huntington, IN
    Finally got around to attacking the power window install. Wasn't bad overall but making that first cut is a little nerve wrecking. Also had to make some brackets to move the door latch cable out of the way. My top aluminum "trim" pieces were horrible, very rough and had indented lines from the bending. Started with a 220 DA sander, then wet sand 320 and finished with a wet sand 1000. 20251031_195458.jpg20251030_192432.jpg 20251202_101351.jpg20251202_101332.jpg
  26. Likes Ltfracing liked this post
  27. #255
    Wisconsin
    I had an upholstery shop make the beading up to fit between the body work and the fenders. My paint shop guys painted it matching the body. Very 'old school' but looks great on the car. I did this in 2009, and it's held up quite well.
    Best wishes,
    Tom Veale
  28. #256
    Apr 2023
    Looking great! Just wondering, have you put many miles on it yet now that it's titled? If so, how's she ride with the 315's in the rear? Any issues with rubbing the inner fenders? To get the clearance you have in one of your pics, did you change from the stock 8" springs to 10" long ones and by any chance did you change from the 300lb rating to anything different? I'm getting ready to go thru the registration process myself and I want to fix my slight rubbing issue in the rear (also running 315's) but only have about 1" left on the threads of the Koni's for adjustment.
  29. #257
    Sep 2022
    Huntington, IN
    Quote Originally Posted by cvacca View Post
    I've got a little over 1,000 miles on it now. It rides like a brick. Yes I still get some rubbing on the outer lip of the fender, not the inner but that's due to my wheel backspace and tire width vs the fender. If I had 7" backspace I don't think i'd rub. I replaced the Koni's with QA1's. I've dropped my compression and rebound adjustments down to 1 & 1 for the softest ride possible on the street, still pretty stiff but better. Rear shocks DD701 / 12" 250# springs, Front Shocks QA1 DD403 / 9" 400# springs Screenshot 2024-12-22 184142.jpg
  30. Likes TxMike64 liked this post
