Thanks Thanks:  2
Thread: Raptor Bed Liner on a MK4 Roadster
    Dec 2024
    I'm getting ready to coat the underside of my MK4 body with U-Pol Raptor bedliner. I've scuffed the fiberglass with 120 grit, and I'll clean it all good with acetone. Is that sufficient? The U-Pol website seems to indicate it is. They only mention the "adhesion promoter" for hard to sand places. Have any of you found the adhesion promoter is necessary?
    You’re good. Go ahead and shoot it!
    Jan 2024
    Ditto what Jeff said. When I did mine I just used red scotch bright and cleaned with acetone. I used the tintable version tinted with grey primer.
    Aug 2025
    Saint Augustine, FL
    Looks like it comes in kits of 4 or 8 quarts, is the 4 enough?
    Josh (aka - MakoGT350)
    MK5 Complete Kit - Picked up July 2025 - Power Steering and Power Brakes, Wilwoods front and rear, SS side pipes, BluePrint 347 - fully dressed with Holley Sniper 2, Tremec TKO
    The gallon kit (which includes a Schutz gun) will do the entire underside of the body and allow you to spray a second coat in the areas above the wheels plus do the tire side of the splash panels.
  6. Thanks StangRacer, MakoGT350 thanked for this post
    Dec 2024
    Looks good. I'm using the roll on version and sticking with the black.
    Aug 2025
    Saint Augustine, FL
    Thank you Jeff - much appreciated!
