Thanks Thanks:  48
Likes Likes:  178
Page 24 of 25 FirstFirst ... 1422232425 LastLast
Results 921 to 960 of 965
Thread: Making progress on my build...
  1. #921
    Indiana
    The beauty of 3D printing? Symmetry! I'm pretty happy with my analog hood fabrication, it wasn't very far off from symmetry to the driver side, as the printed fascia makes evident. Just a little trim will make it perfect!
    GTM #304 LPE 525hp LS3
  2. #922
    Indiana
    Started making a cubby for phone, Etc
  3. Likes Geoff H, VRaptor SpeedWorks, LLC liked this post
  4. #923
    Indiana
    Tweaked the air inlet, 30mm bigger, which matches the hood line better and will allow more direct air to the radiator.
  5. #924
    Very cool progress! Those door latches look like they should work great!
    Shane Vacek
    www.vraptorspeedworks.com
  6. #925
    Indiana
    Cubby with cupholder (designed specifically for a 16.9oz plastic water bottle only) and Magsafe phone charger mount. Ditching the tablet, navigation and entertainment will be phone-based.
  7. Likes VRaptor SpeedWorks, LLC liked this post
  8. #926
    Indiana
    Let me know if anyone wants my scans of the passenger and driver side intakes (STL files). Gen-1, but probably same as Gen-2? Threw this together this afternoon, it's on the printer now.
  9. Likes Shoeless liked this post
  10. #927
    Indiana
  11. Likes VRaptor SpeedWorks, LLC, Geoff H liked this post
  12. #928
    May 2016
    Curious. Are you going to be scanning the rear quarter windows. Not the door glass but the window (potential engine vent) just behind the doors?
  13. #929
    Indiana
    Quote Originally Posted by doug_porsche View Post
    This?
    https://thefactoryfiveforum.com/show...l=1#post574366
  14. #930
    San Diego
    The side vents look great. Definitely an area that makes the car look unfinished or like a kit car if done wrong.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
  15. Likes VRaptor SpeedWorks, LLC liked this post
  16. #931
    Feb 2019
    Houston, TX
    Quote Originally Posted by beeman View Post
    I do like these. Very similar to my plans.
  17. #932
    Yes.....Gen I and Gen II side scoop areas are the same.....or at least enough the same that I can't tell the difference when installing my louvers there.
    Shane Vacek
  18. #933
    Indiana
    GTM has side intake similar to McLaren, may throw together a scoop type intake an see how it looks...
    OEM-Style-Carbon-Fiber-Side-Air-Intake-Body-Kit-Suitable-for-Mclaren-650s-Side-Vents.jpg
  19. #934
    San Diego
    Actually the GTM is almost identical to a Porsche GT side intake...DSC_3854-64503-scaled-1.jpg
    I saw one in person and it struck me how identical the GT is to the GTM. I guess if it's good enough for a $2M Porsche it should be good enough for the GTM.
    I do like your louvers though.
    www.myraceshop.com
    GTM solution kits
  20. Thanks beeman thanked for this post
  21. #935
    Indiana
  22. Likes Shoeless liked this post
  23. #936
    I designed and made the mould.....shipped the mould out to the place who was making all of my CF parts.....and the business switched owners, went bankrupt and the moulds are gone.....
    Shane Vacek
  24. #937
    Indiana
    Shane I forgot you had those, they look perfect for a scoop style. Are you still seeing a market for selling GTM body parts? Not sure how many GTMs are still being built.
  25. Likes VRaptor SpeedWorks, LLC liked this post
  26. #938
    I still sell some GTM parts every once in a while.....but no where near like 10 years ago.....of course.
    Shane Vacek
  27. Likes beeman liked this post
  28. #939
    Indiana
    Relatively shallow frunk makes it difficult to find a pair of hood struts that are long enough to give plenty of hood lift for frunk access, yet collapses enough to fit under the closed hood. Then you have to figure out the lift pressure needed (20N to 200+N...my hood is light but it's hard to find tall gas springs that aren't high N). Then the packaging issues through the range of motion of the gas spring,especially with targa roof storage in the frunk.
    So I designed a twin strut around 8mm carbon fiber tubes. Fairly straightforward CAD design of pivoting mounts on the 1.5" chassis round tube, T's to connect the parallel tubes, and "sockets" that capture the rods on the under surface of the hood. The entire unit is weighed in grams, I'd wager this system weighs less than 1/10 what a pair of gas springs with associated hardware would weigh.
  29. #940
    Indiana
    One benefit of 3D modeling is that Fusion can give you a cross section of any part of your model. Will be making a 3-part mould of the bumper, simple to print the parting flanges, which fit the bumper perfectly.
    Front wheel well liners made from 050 aluminum, minimum 1/2" clearance at full lock.
    Of course, the never ending side projects...or is the GTM the side project
  30. Likes VRaptor SpeedWorks, LLC liked this post
  31. #941
    Cool Stuff!
    Shane Vacek
  32. Thanks beeman thanked for this post
  33. #942
    Jul 2014
    Some cool progress!!!
  34. Thanks beeman thanked for this post
  35. #943
    Indiana
    Threw together a glove box to replace the hole where the passenger side airbag was removed from the donor dashboard.
  36. Likes VRaptor SpeedWorks, LLC liked this post
  37. #944
    Indiana
  38. #945
    Feb 2019
    Houston, TX
    comning along nicely. I'm jealous of your 3D scanner.
  39. Thanks beeman thanked for this post
  40. #946
    Jul 2014
    I am totally digging that front end look!!! This is really coming together nicely!!!
  41. Thanks beeman thanked for this post
  42. #947
    Indiana
    Radiator ducting on the printer now, it is simply a sacrificial buck (205g of PLA filament, maybe $2 worth) that the fiberglass will be laid over, then peeled off the inside leaving the fiberglass duct.
    Going to make a mould of the front fascia, which required laying up a thin layer of fiberglass over the print, will sand/fill/spray epoxy the pull a mould.
  43. Likes VRaptor SpeedWorks, LLC liked this post
  44. #948
    Indiana
    Finished the other side of the rear trunk. Between 2 rear trunks and a frunk, way too much baggage area in this particular GTM...
    The C5 trunk latch mechanism was too nice to throw in the junk pile. Power release, built-in "unlatched" indicator light circuit for dash warning LED, and cable backup if solenoid fails. Glassed in the precut areas of the rear hatch for trunk coverage, open central area to allow heat off the exhaust. I'm going to draw up louvers over the exhaust for Shane @vraptor to custom plasma cut for me. Getting spoiler positioned for bonding to rear hatch.
  45. Likes VRaptor SpeedWorks, LLC liked this post
  46. #949
    Indiana
    Divided rear hatch into 2 parts previously. With re-routing the exhaust for central exit, no good place for a latch on the larger engine hatch. Glassed a flange that sits under the trunk hatch, trunk hatch now holds the engine hatch closed so no 2nd latch needed. Worked out well.
  47. Likes VRaptor SpeedWorks, LLC liked this post
  48. #950
    San Diego
    Just to maybe give a recommendation for a couple of things on the moulds...
    If you are planning on vacuum bagging it is quite helpful to extend a lip all the way around the outside of the part so the mould has a place for the vacuum bag to fasten to. Also, if it were me, I would build up the mould quite a bit with layers of FG and maybe even some ribbing to make sure the shape stays correct when making parts from the moulds.
    Did you use gel coat before laying down the FG or just straight FG onto the plug?
    Great to see your progress. Thanks for sharing.
    www.myraceshop.com
    GTM solution kits
  49. Thanks beeman thanked for this post
  50. #951
    Indiana
    I'm on the same page with your recommendations. Up to this point, wanted to give a better preparation surface to the 3D printed fascia, basically reinforcing the 3D printed plastic fascia with a little bit of fiberglass to give it more strength and a better surface to prepare for pulling a mould, then pull a mould off of this using traditional techniques. Not sure if I will vacuum bag, I've never done that before.
  51. Likes VRaptor SpeedWorks, LLC liked this post
  52. #952
    Nice progress!!
    Shane Vacek
  53. Thanks beeman thanked for this post
  54. #953
    Indiana
    It is pretty cool that you can three-dimensionally design this on a computer based on a 3D scan, print it, and it fits like you were right there designing it on the vehicle. But you can't really design a duct like this on the car, because you need to know where the duct meets both the radiator and the duct opening in the fascia. With the CAD software, you can show and hide both the radiator and the fascia, working with both of these in their anatomic positions in the car.
  55. Likes VRaptor SpeedWorks, LLC liked this post
  56. #954
    Indiana
    The further down the rabbit hole you go, the tighter things get! Installing the Aerocatch hood locks. Not much space between the stored targa roof, hood prop base, radiator, and headlight but it's barely going to work!
    Finalizing fitment of the front fascia with the radiator ducting.
  57. #955
    San Diego
    I got a set of those and looked into using them on the FFR PDG GTM race car, but they just didn't work out for a number of reasons. The front pins we leave long so we can remove the splitter and then prop the hood up on the long pins to get ground clearance when loading the car into the trailer, and on the rear deck the pins don't interface the deck perpendicular. Then there is the space issue you mentioned. I think the Aerocatch latches are cleaner once installed, but they are not an easy retrofit to a GTM...or at least our race GTM as it sits.
    www.myraceshop.com
    GTM solution kits
  58. Likes beeman liked this post
  59. #956
    Indiana
    Makes sense. You probably did not have the hood hinged on the race car? I went with Aerocatch for a couple of reasons. I wanted more fixation of the front of this hood (at speed) than a single latch in the middle. Secondly, I did not have a good way of initially lifting the hood /getting my fingers under the edge of the hood to start lifting it, the pair of Aerocatch's lets me use the latches to lift to start opening the hood.
    What's the latest with the PDG GTM? I miss the race updates.
  60. #957
    I've had the same issues as Crash on those latches. I'd say they are meant to be used on something where there's no hinge and the hood can be lifted straight up off the vehicle. Once you try to use them with anything hinged....where the latched area doesn't move straight/vertical away from the latch, they're a real PITA.
    Another issue I've had with almost all of them is that they work on a cam-action that pushes that pin thru the hole in the "striker".....and the way they're designed, they get jammed up to where that sliding cam action won't work.....and you have to reach down in there with some needle-nose pliers or some thing in order to get the pin to begin to move before you can get the latch handle to finish the job.
    Shane Vacek
  61. Thanks beeman thanked for this post
  62. #958
    San Diego
    We had an incident a year or so ago where a driver that had rented the car found a tire wall. I then had a couple of family issues to deal with and the car has not been out of the trailer since that incident.
    Good news is that Dave Smith and crew at FFR are helping with some of the body work/graphix/etc. and I am building a new engine/gearbox/brake package with ABS to run a 12 hour race this year in September. Lots of work going on, and we are going to derate the horsepower a bit and try some new stuff in the transaxle. I wanted to get a Gleason into the transaxle, but doesn't look like that will happen, but we are looking at alternatives.
    I have been upgrading the trailer and communications for the race team so all the crew can have radios and know what is going on.
    It really doesn't seem like the crash damage was that bad as the car drove into the trailer under it's own power and did not have any fluid leaks. Will have to measure everything though to make sure.
    I'll get a thread going here soon about the rebuild project.
    www.myraceshop.com
    GTM solution kits
  63. Likes Geoff H, beeman liked this post
  64. #959
    Indiana
    Quote Originally Posted by VRaptor SpeedWorks, LLC View Post
    I've only drilled a guide hole so far... is there a better option? I like that this captures/sandwiches the hood fiberglass within the devise, seems stouter than bonding a catch to the underside of the fiberglass that could delaminate at speed
  65. #960
    Indiana
    Looking forward this! Sorry about the mishap...
