Quote Originally Posted by Guardm16 View Post
Looking good, you may want to consider the Upper mounting position on the rear shocks, not the hole on the chassis, but the black threaded sleeve on the shock itself can be moved to a higher position on the shock. This was the only way I could get a level stance. Before that, my truck looked like a dog taking a dump. Sorry for that visual. LOL
You can see the shock on the far left of this picture, the adjusting sleeve is in the higher position. There is a snap ring that can be moved up to secure the sleeve
Thank you.
That is great advice, I will look into it. Question, was it obvious right away the back was too low or was it something that snuck up on you. Did you take any pictures when it was out of level? Low and level is 100% the goal on this build.
