Finally have confidence that my rear brake leak is fixed so I went ahead and installed all the trunk aluminum including the separator wall for the rear cockpit cubby. Laid down the silicone bead first, then tacked the panels in place with clecos, then riveted. Went pretty smooth. I did drill a 1" hole near the PS roll bar rear leg for the trunk license plate electrical harness. Here are some pics.
NEXT UP:
- sound/heat mat install (cockpit & trunk)
- carpet install (cockpit and trunk)
- body mount
- seat fitment (w/ Breeze seat mounts)
- safety harness install
- go kart
