Jim, just google T-56 shifter leak. It's all over the web. ( and oil is all over my transmission mount )
I'm going to give this product a try from TickPerformance.com
https://www.tickperformance.com/6-bo...xlyPnUTxYOeaEh
Here's a video. No idea if it actually works or not yet https://www.youtube.com/watch?v=QBRGixXDn3w
JimStone thanked for this post
I wasn't aware of this leak issue, so thanks for allerting me to it. I went ahead and got the Tick Performance shroud. Way easier to do that now than later
Thanks again
Blueprint LS3 427, T56, IRS
Received: 5/24/2024
First Start: 2/7/2026
Jim, I had the same issue on mine. I ended up molding custom bushings for mine. Now it points up at 0.5 degs from the ground. If you are interested I can see what it would take to make another set. I had some help from the shop at the office.
Received: 5/24/2024
It is a common issue with the T56. There is a rubber seal under the shift plate. It is easily damaged which allows fluid to come up the shifter shaft around the shifter ball. Aftermarket shifters are more prone to the problem due to the tolerances being a bit different than the Tremec supplied shifter.
As a rule, I always pull the shifter cover to check the seal before installing the transmission.
Well, you guys sent me down the Internet rabbit hole with this T56 shifter leak stuff.
It's a real shame this hasn't been fixed by Tremec.
I'll be checking the seal when I pull the shifter to install the Tick Performance shroud, but it has me wondering if I should prophylactically replace the shifter altogether
The Bowler "Nightstick" gets rid of the rubber seal and uses a press fit ball-in-cup type seal
Of course it's $473
Hate to spend that kind of money, but I also don't want to deal with what Mark is dealing with
Received: 5/24/2024
I'm going to try the $50 fix first.
Jim, did I mention your CV boots are going to leak too ??![]()
Received: 5/24/2024
Where do the boots start leaking and failing?
More often than not it is due to too much grease in the boot expanding and promoting tearing/rupturing of the boot. Next up would be damage from exterior forces (rocks, road debris, and so on). Then we have general wear from high temperatures and the oils and salts from the roads causing the rubber to dry and crack.
I have tried to come up with a hard design, but am not happy with any of them, yet. The best I have, so far, is just a protective shell.
Hey Mark,
Any luck getting the Tick Performance shroud in without removing the transmission?
Received: 5/24/2024
JimStone liked this post
I used the gas pedal that came with the BluePrint GM427LS package. The mounting plate and pedal did need some trimming to get it to fit correctly. There should be pics in the link in my signature that show what I did.
The Holley DBW works well too. I only had to trim a small part so it didn't bind with the steering shaft. It's less bulky so it fits down in better than the GM pedal, in my opinion. I ended up returning the GM pedal that I had bought first
Received: 5/24/2024
thanks Mark. My kit did not come with the pedal. I'll have to see what they have. I bought a GM pedal from Summit, but will need lots of work to make it fit.
thanks Jim - do you have a pic to see what you did?
Here's a few pics:
I think only 2 or 3 of the button head screws actually go thru the pedal bracket. The others are just there to fill holes and make it look nice
Honesty, it's like a the Holley pedal is made for this car
I swapped the actual pedal to a Breeze one that mimics the Wilwood brake and clutch pedals that come with the complete kit. I posted about it in post 79 of my build thread
Received: 5/24/2024
Thanks Jim - appreciate the pics. I am building a MK4 and the pedal bracket looks a little different, but this gives me a good idea of what to do next. I may have to go the breeze route as well. That looks great.
