Thanks Thanks:  148
Likes Likes:  265
Page 14 of 18 FirstFirst ... 41213141516 ... LastLast
Results 521 to 560 of 705
Thread: Jesse builds another Cobra #11,061 - First body work shots
  1. #521
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Looking good!
    Scott Pregont
    My Albums
  2. Likes Blitzboy54 liked this post
  3. #522
    Oct 2020
    Albany, NY
    Powder coated gas cap PSA
    As you may or may not yet know the Leman's gas cap comes with 2 different style of screws. All but one are a #8 machine screws that thread directly into the fiberglass body. one of them has the same style head but is a bolt with a nylon lock nut. This is so you can attach the ground strap that comes with the kit. The reason the cap is grounded is so when you fill your car any static electricity runs to ground instead of creating a spark just like your daily driver. Modern cars have a number of other safety features that these do not so grounding them is important. Having said all that I was completing assembly and realized with the cap and screw coated there was no path to ground because I covered them in powder coat. It was not something that occurred to me before hand.
    To fix this I pulled the powder coated bolt and replaced it with an uncoated one. I painted the top of it and left the bottom naked metal. I then cleaned the power coat out of the holed it sits in (in the pic the one in the back by the hinge). I ran the ground strap to one of the bolts holding my vent filter to the chassis. Once re assembled I checked resistance to ground to the chassis and filler neck. From the inside of the cap where the nozzle goes there is less than 1 ohm.
    Just something to think about if you chose to coat your cap as many of us do.
    The rest
    I then re attached my rear quick jacks and also took the opportunity to "center" my backup camera. I had originally placed it based on the measured center of the car. Don't do that.
    I got the front splash guards in. I am hoping to put 1000 miles on before paint so I am going to need them.
    Last is the exhaust hangers. Again since I am driving in gel coat I need them on. One thing that has bee weird about this build has been the exhaust fitment. I used headers with cats so there is no adjustment like the open ones with the ball flange. My pipes both sit wide at the point of connection and were splayed out away from the body like a V. I needed to use wedges to bring them in parallel to the body which brought them out a little wider still.
    I am using the single point of attachment method as my last pipes tore a bit over time. That way it hinges and creates forgiveness.
    BUT because my pipes sit a bit wider the stock setup doesn't quite fit. My solution for now was to move the hole on the bracket back. I needed this modification on both sides. I may fabricate my own custom bracket in the future but this is what I am doing for now.
    Build 1 MK4 #10008 - Delivered 03/03/21, Graduated 7/20/22 - Sold 6/6/24 Build Thread #1 https://shorturl.at/K9fuy
    Build 2 MK4 #11061- Delivered 08/24/24 Build Thread #2 https://shorturl.at/OZowi
    Build 3 35 Pickup #329 - Delivered 10/28/25 Build Thread #3 https://shorturl.at/Ty4QQ
  4. #523
    Sep 2024
    Louisville, KY
    I like the final look of your backup camera, and thanks for the tip on the Lemans cap. Mine is PC’ed already and would have probably missed that detail
  5. Likes Blitzboy54 liked this post
  6. #524
    Feb 2023
    Mechanicville, NY
    What did you use for the rear backup lights? Nice and clean.
    Jen
    MK4 complete kit, IRS, Ford Strokers 347 (carb & mechanical fuel pump), TKX, PS, heater-defroster-wipers, firewall forward, 11.65 rear brakes, 17" Halibrands, #11124.
    Ordered: 9.8.2024
    Delivered: 10.31.2024
  7. Likes Blitzboy54 liked this post
  8. #525
    Oct 2020
    Albany, NY
    Quote Originally Posted by jengum View Post
    Hi Jen, the link is here.
    https://a.co/d/gufnYem
    They are cheap but if you want I have plenty if extras if you want a few. Feel free to stop by I would be happy to send you home with a couple.
  9. #526
    Aug 2025
    Sweet Car Jesse! Do you build these for other people by chance?
  10. #527
    Oct 2020
    Albany, NY
    Quote Originally Posted by CalNaughton Jr View Post
    I sent you a DM
  11. #528
    Oct 2020
    Albany, NY
    Windshield take 2
    When I got my windshield frame back. He did a great job. Blew out the inside channel and then fogged the edge before curing. Really looks good. Best part is everything fits together correctly. While I was trying to make it fit before I figured what the problem was one of the brass corner brackets broke (doh). It's a fragile little bugger. I purchased a piece of galvanized steal and fabricated a new one.
    It ended up being a touch too thick so I "planned" it down with a die grinder. SS would be the better move if I was to do it again.
    It worked well and it came back together correctly
    Re installed and added the visors, wind wings and the Breeze masterpiece of a rear view mirror. I have some plans when I break her back down for paint. I am definitely going to tint the wind wings to match the visors. I will also clean up the rest of the hardware so it matches. Just waiting to hear back from the state for my salvage inspection and she's basically ready to go (need to finish the passenger exhaust hanger).
    Lookin like a Hot Rod now.
  12. Likes tnt_motorsports, 460.465USMC, Fman liked this post
  13. #529
    Houston, TX
    Looking real good Jesse!
    Build 2: Mk5 Complete kit | Coyote Gen 4X | TKX | IRS | Brake Booster | Traction Control | Ordered: 3/18/2026 | Build Thread
    Build 1: Mk4 Roadster | Coyote Gen 4X | Ordered: 1/31/2024 | Delivered: 4/11/2024 | First Start: 8/9/2025 | Legal: 11/5/2025 | Crashed: 2/16/2026 Build Thread
  14. Thanks Blitzboy54 thanked for this post
  15. #530
    Aug 2025
    Love the details!! getting me amped up for my build. this is the premier build thread on here!! good stuff!
  16. Thanks Blitzboy54 thanked for this post
  17. #531
    Oct 2020
    Albany, NY
    I appreciate the feedback. Welcome to the forum. I sent you a direct message. Let me know if you have any questions.
  18. #532
    Feb 2023
    Mechanicville, NY
    Please save me a couple...thanks for sharing.
    Jen
    Ordered: 9.8.2024
  19. Likes Blitzboy54 liked this post
  20. #533
    Dec 2017
    And....It's.....DONE! Nice work Jessie. As soon as you have Mr. Kleiner work his magic, you can go have fun with it until you get the itch to sell and build an MKV. The FFR vortex might be a real thing.
  21. Likes Blitzboy54, 460.465USMC liked this post
  22. #534
    Oct 2020
    Albany, NY
    It might be honestly. Wouldn’t mind building a MK5 or a 35 pickup. We will see.
  23. #535
    Sep 2024
    Spencerport, NY - near Rochester
    Hey Jesse. I'm in the Rochester area and will be facing the NYS gauntlet in the distant future. Quick question on those backup lights... the Amazon info made reference to DOT but didn't call out any detail and I couldn't see any markings on the lenses in the ad. Do they have everything thatNY will require?
    Pat
    MK4 complete kit Nov 2024, Blueprint 347, TKX, Hyd clutch, IRS, 3.55, touring shocks, 17" wheels, 11.65 brakes, Build Thread
  24. #536
    Oct 2020
    Albany, NY
    Quote Originally Posted by PMD24 View Post
    Pat
    Yes, I can get a close up but there is both an SAE and DOT marking. DM me before you file your paperwork with your phone number. Happy to talk you through the process. It’s as easy or difficult as you make it. It’s my second time through and it was a breeze.
  25. #537
    Sep 2024
    Will do Jesse. Thank you. Waterman (Anthony), suggested that I speak with you also and I planned on doing that as I get closer. Appreciate you offering to share your experience.
    Pat
  26. #538
    Oct 2020
    Albany, NY
    Quick registration update, I sent my packet off to the Salvage Division. They do the physical inspection on my "home made vehicle". Once complete they assign a VIN and I can then register the car. Unfortunately my date isn't until Sept 23rd. I called today to see if I could slide into an earlier opening but because the way this process works they need time for my application paperwork to physically make it's way to the inspection station. Because of this I just have to wait.
    Bummer
    I have been taking some liberty's with driving it. Probably more than I should but it runs really smooth. After mounting the side pipe hangers I get quit a bit more metallic popping with the heat cycles than I did on my last build. Nothing serious, just pops a little during the heat up and again on cool down. I am guessing the one piece rigid headers are the difference. The Coyote is a marvel compared to my Sniper controlled SBF. It putters around at parade speed with ease but just pulls like crazy when I ask it too. The best part being it so easily finds idle after. Just immediately finds 800 RPMs. The speedo is pretty far off. I don't want to drive it more than around the block so it will have to wait to calibrate it but it thinks I am going 110 mph when I am doing 40 so the miles are adding up. lol
    The body definitely has settled bit. The drivers door sticks a little after a few runs. I am not going to touch a thing unless I absolutely have to. I want to leave as much material on the body as possible for Jeff to work with. I am hoping to get her out regularly through the end of the month till mid November. Once Thanksgiving hits that will be it.
    At that point it will be winter again. Hoping to have her off to paint. I have a few house projects to get checked off the honey do list as well as another potential car project. Will just have to see how it goes.
    I took delivery right about a year ago. I lost about 6 weeks this winter with my engine woes and I should have gotten my paperwork in earlier. So that is to say if you have an unhealthy obsession with being in the garage and an angelically tolerant wife you can bang one of these out in a calendar year.
  27. Likes TXeverydayDad, PNWTim, 460.465USMC liked this post
  28. #539
    Aug 2019
    Spokane, WA
    I thought you might like the Coyote.
    I hope you finish the registration process so you can really put some miles on before winter sets in.
    Coupe complete kit. Index. Delivered: 4/22/24. Build Thread. Coyote Gen 4X. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
  29. Thanks Blitzboy54 thanked for this post
  30. #540
    Aug 2025
    Any more progress pics? Do you plan to race this car in autocross??? WICKEDDD
  31. #541
    Oct 2020
    Albany, NY
    No unfortunately it's just sitting in the garage under a cover. I have 2 more weeks until my appointment so there is just nothing for me to do. I can't legally drive it and there really isn't anything to work on. I am watching it get slowly cooler every day. lol
    I have no plans to auto cross it right now but you never know
  32. #542
    Sep 2024
    Hey Jess, Can't recall where you ended up on your color selections but thought you might have an interest in looking at a blue and orange combo on BaT.
    https://bringatrailer.com/listing/20...mpaign_2648441
    Pat
  33. #543
    Oct 2020
    Albany, NY
    Pat
    Thank you for sharing that! It helps validate my thinking. The LS in that thing sounds amazing. I’ll bet it’s almost un drivable with that super charger. Blueprints LS3 comes “stock” with 520 HP. Guessing that’s why the current owner only put 800 miles in it.
    I have an LS itch I’m going to need to scratch at some point.
    For the record I have finalized my color scheme. I want to wait until I get a little closer before I share but I’m very excited about it.
  34. Likes PMD24 liked this post
  35. #544
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    If you want a hand on your inspection day, let me know! You have to try out the New York Safety Track with me at least once!!
    Scott
    Scott Pregont
    My Albums
  36. #545
    Oct 2020
    Albany, NY
    Quote Originally Posted by Namrups View Post
    Scott
    I will 100% do that.
  37. #546
    Oct 2020
    Albany, NY
    I did a thing
    I still have a couple weeks still until I get my inspection ("mom, are we there yet?"), the VIN and can register the car.
    Before I pulled the trigger on the second MK4 I was considering all my options. My first thought was to build a GT40. I came pretty close but it's a significant upgrade in budget and I am just not ready for that investment yet. I thought about the coupe but that is not for me. I also came pretty close to building a 35 hotrod pickup. I had put a concept together and a build plan. I dry ran the order and when push came to shove I really wanted another roadster, so the idea was shelved.
    As it turns out I have been keeping in touch with the gentlemen that bought my MK4. We have been talking on and off for several months about me building a hotrod pickup for him. Things have accelerated and as of a few days ago a kit and engine has been ordered. He gave me express permission to start a build thread and share the basic details of the arrangement. I am VERY excited for the opportunity and look forward to the prospect of continuing to create new things.
    I will start a build thread over there but the basics are an LS based power plant with a TKX and big open wheel concept. If all goes well it will be outrageous.
  38. Likes PNWTim liked this post
  39. #547
    Dec 2017
    I did a thing
    As it turns out I have been keeping in touch with the gentlemen that bought my MK4. We have been talking on and off for several months about me building a hotrod pickup for him. Things have accelerated and as of a few days ago a kit and engine has been ordered. He gave me express permission to start a build thread and share the basic details of the arrangement. I am VERY excited for the opportunity and look forward to the prospect to keep creating new things.
    That's awesome!
  40. Thanks Blitzboy54 thanked for this post
  41. #548
    Jul 2021
    Tonganoxie, KS
    Make sure you cover yourself legally. I'd love to build cars for people, but the liability scares me a bit. I'd talk to Kleiner and Everson about how they protect themselves when they build for people.
    For example, let's say you use Wilwood MCs, and one fails after he takes delivery, and gets hurt. He's likely going after they guy who built the car, AND Wilwood. Maybe open an LLC and sell the car to him through it, and not through you personally.
    Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, ReplicaParts
    MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, First start 3/15/25. Legal 6/13/25. Boss 427W, Edelbrock Pro Flo 4, TKX (.68 5th), IRS, Wilwood Brakes, 18" Halibrands, Toyo R888R Tires, Custom Speedhut Gauges
  42. Likes Blitzboy54 liked this post
  43. #549
    Oct 2020
    Albany, NY
    Quote Originally Posted by gbranham View Post
    All due diligence has been performed. Those issues have been well researched and both party's are protected. I appreciate it.
  44. #550
    Oct 2020
    Albany, NY
    That's awesome!
    Thanks man!
  45. #551
    Aug 2019
    Spokane, WA
    I did a thing
    Not only are you a skilled builder, but a master of understatement! Congrats, sir! That sounds like a lot of fun. You have the skills and building speed to pull it off. And, make some mad money to boot. I'm a little jealous. Please let us know once you start the build thread. I would love to follow along.
  46. #552
    Now you’re going to turn it into a job
  47. Likes Blitzboy54 liked this post
  48. #553
    Jul 2021
    Tonganoxie, KS
    Awesome! Looking forward to following the build thread!
    Greg
  49. Thanks Blitzboy54 thanked for this post
  50. #554
    Dec 2021
    Flower Mound TX
    I've done work for other people before, I built one of the first Jr Dragsters way back. But TBH, I really struggle with motivation when it's someone else's car. To me cars are a fun hobby, it's why I never worked in the industry. If I worked in it I know it wouldn't be fun for me anymore. That's just me. Instead I've always worked in the salty snack food industry and get to eat hot fresh potato chips
    Good luck to you, I'll be following along!
  51. Thanks Blitzboy54 thanked for this post
    Likes Joel Hauser liked this post
  52. #555
    Oct 2020
    Albany, NY
    Quote Originally Posted by 460.465USMC View Post
    Thank you. I really appreciate the kind words Chris. I've been checking on your coupe regularly
    Well, I found one, lets see how this goes. Certainly worse ways to spend your time.
    Mike, I have had the same thoughts. Either this feels like a job then I would then be duty bound to finish her up because I made a commitment but would at the end feel like I wouldn't want to do it again. Or I get the same joy out of the build process but it does not put downward pressure on our family budget. I am really hoping for the latter. The end of this build completely snuck up on me. I was humming along and then BANG I was done. This came at a good time.
    I am elbows deep into the planning. I'm really pumped
    I still have some work to do on this car obviously. I purchased some black vinyl sheet and bulb seal. After paint I plan to put wheel well liners in. I like how it completes the look. It will be weird having two build threads going at the same time. It's a little bonkers.
  53. Likes Mike.Bray liked this post
  54. #556
    Houston, TX
    Congrats on the gig!
  55. Thanks Blitzboy54 thanked for this post
  56. #557
    Jan 2019
    Mead Colorado
    This is going to be fun to watch. I want to build a pickup and a hot rod, but we will see. Congrats! I’m sure it will be awesome!
    Mk4 complete kit arrived 10 May 23
    Current BOM and Build Thread
  57. Thanks Blitzboy54 thanked for this post
  58. #558
    Mar 2024
    Shawnee,KS
    Very cool Jesse !
    I'll be excited to see how the truck turns out.
    I'd love to build a truck eventually but I think my soon to be shipped MK5 will keep me busy for quite a while, lol.
  59. Thanks Blitzboy54 thanked for this post
  60. #559
    Oct 2020
    Albany, NY
    Quote Originally Posted by TrackDay17 View Post
    Very cool Jesse !
    I would jump at the chance to do a MK5. Just the body alone makes it appealing.
    I used to do several track days a year. I assume that's you in the avatar photo? Just the most fun I've ever had. I miss it.
  61. #560
    Feb 2022
    Granbury, TX
    Maybe a good way to write-off tools as business expenses?
  62. Likes Blitzboy54 liked this post
