Thanks Thanks:  90
Likes Likes:  209
Page 4 of 13 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 500
Thread: Papa's Retirement Type 65 Coupe Build - Index in first post
  1. #121
    Quote Originally Posted by 460.465USMC View Post
    It feels good to get the panels started, no? It looks like you're planning to rivet the "removable" HVAC access panel? I drilled mine like you did, but having second thoughts that I should have installed nut serts.
    I'm enjoying fitting the panels, but I guess I should pay a bit more attention to detail so I don't miss something like the A/C access panel. I'll likely just rivet it now that it's drilled. I've had mixed results using nut serts to join aluminum panels. As a matter of fact, I broke my #10-24 nut sert mandrel today while installing nut serts for the driver's foot box top panel. I need to look at the A/C instructions before pulling the panels to send to PC, as there are additional holes to drill.
  2. #122
    Today I worked on fitting the driver's foot box aluminum. These took a bit of work to get where they needed to be, but eventually came together nicely.
    I'm going to make the top removable, so I started installing nut serts. As I was installing #6, the mandrel snapped. I'm sure I was applying too much force. Thankfully, the replacements are cheap and I'll have two new ones delivered tomorrow from Amazon.
    The biggest issue is that I'll now have a nut sert rattling around inside the frame. I don't think there is any way to fish it out. If I can get it to where I can see it through the hole, I'll squirt a dab of silicone on it to try to hold it in place.
  3. Likes AaronR liked this post
  4. #123
    Today I focused on test fitting the A/C and heater unit to get the position of the holes located on the front of the foot box where the bulkheads go for the A/C and heater hoses. First step was to position the evaporator unit in the car and ensure that the A/C, heater, and drain lines would clear the frame.
    Next, I drilled and tapped #10-24 holes directly into the frame to mount the evaporator rather using the self-tapping screws provided.
    I found that to get clearance for the drain fitting, I needed to hang the evaporator a little below the frame, and used a stack of stainless steel washers on the front mount to take of the space.
    Now on to a more complex step; locating the bulkhead fitting. To do this, I screwed in the #10 fitting on the evaporator and cut a piece of hose long enough the allow me to locate the spot on the footbox that the fitting aligned with. After marking the location, I drilled a small hole in the location (center of the #10 fitting) and then located the template on the outside of the footbox.
    I had to order a 7/8" hole saw, but will drill the holes once that arrives.
  5. #124
    Nov 2020
    Damascus OR USA
    Looks good Dave. Be aware, the spacing the bracket dictates for the two hoses is wider (taller) than that of the block the male ends thread into. It makes for an awkward fit at best but it will fit. I essentially lined mine up just like you did and made sure the big, less flexible #10 hose was as straight a shot as I could make it.
    Build 1 - 1969 Camaro Build Thread Here: https://www.camaros.net/threads/tims...y-getter.45926
    Build 2 - 1965 Daytona Coupe # 620 Build Thread Here: https://thefactoryfiveforum.com/show...-Type-65-Build
  6. Thanks Papa thanked for this post
    Likes Papa liked this post
  7. #125
    Mar 2021
    Ohio
    Dave, these are also good for attaching sheet metal pieces together if you have an arbor press. The hole size needs to be as specified for them to work.
    https://www.mcmaster.com/product/95185A350
  8. Thanks Papa thanked for this post
  9. #126
    I picked up a set of cheap Mustang wheels and tires for rollers.
    They are pretty rough condition, but will do the trick. The backspacing on the rears was way too big and I ended up having to put some cheap 1.5" spacers on to allow the wheels to clear the shocks.
    I also received my Breeze and Snakebite Motorworks orders and everything looks fantastic. More to come on this.
  10. #127
    Nov 2020
    Damascus OR USA
    Although I think the shop dog is a girl, she looked like she wanted to lift a leg and break in those tires.
  11. #128
    Quote Originally Posted by PNWTim View Post
    That's my little Lady. She would never lift a leg, but she might squat and leave her mark.
  12. Likes PNWTim liked this post
  13. #129
    Mar 2021
    Ohio
    Looks like she might be investigating a new napping spot.
  14. #130
    Quote Originally Posted by burchfieldb View Post
    That's a lot more likely!
  15. #131
    Aug 2019
    Spokane, WA
    Congrats on hitting the roller stage! Will you be moving her over to the lift for some back-saving goodness?
    Coupe complete kit. Index. Delivered: 4/22/24. Build Thread. Coyote Gen 4X. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
  16. #132
    Jul 2025
    Folkston,Georgia
    Looks good Dave … just out of curiosity what lugs are you using for roller purposes ?
  17. #133
    Chris,
    She's not quite a roller yet. I still need so install the steering shaft and brake lines. I'd been on the lookout for a set of wheels/tires I could use for rollers, and found this set for $300. The rear tires are burned down to slicks, but they hold air and I won't be driving on any public roads with them.
  18. #134
    Quote Originally Posted by Lugnut Mark View Post
    Mark,
    I picked up a set of open lug nuts (1/2-20) for under $20 on Amazon.
    https://a.co/d/hrUZms1
  19. Thanks Lugnut Mark thanked for this post
    Likes Lugnut Mark liked this post
  20. #135
    After seeing the quality of Brent's products (Snakebite Motorworks) with the drop trunk kit, I placed another order for several more items, including a glove box kit, horn mounting brackets, triple reservoir mounting bracket and polished bezel, and several aluminum panels.
    I'll be placing another order in the future for some additional items Brent is working on.
  21. #136
    Today, I was excited to assemble the glove box kit. It went together perfectly.
    Now for the fun part; cutting the big hole in the dash! For this, Brent provides a scale template, but first, I located the assembled box on the back side of the dash and marked some of the mounting holes to help locate the template.
    Once the dash was properly marked, I used a 2" hole saw on my drill press to cut the radiused parts of the opening and simply finished by marking and cutting the lines tangent to the holes on all four sides. From there, it was just test fitting the box and getting the gap needed to accommodate the material that I'll be using to wrap the dash later on.
    And what it looks like mounted in the car.
    I plan to use the same trunk liner material I used to do the trunk in my MK4 to line the glove box.
  22. Likes 8secDuster, F500guy, Higgybulin liked this post
  23. #137
    Nov 2020
    Damascus OR USA
    Looks great! I was hoping to use the same thing but my dash layout doesn't accommodate it. Brent makes quality stuff for sure.
  24. #138
    Jul 2025
    Folkston,Georgia
    Thank you sir .. that’s just what I needed to know !
  25. #139
    Thanks, Tim. I have a 2" sanding drum ordered to clean up the corners, but not too bad for a start using a round file.
  26. #140
    Papa Dave,
    How do you feel doing this build compared to your first?
    Papa Dave,
    Steve,
    I feel more relaxed on my second build. The Coupe has a lot in common with the MK4, but still enough diffences to keep me challenged. I also don't feel like I have to get it done as fast as I can, and in fact, don't want to get it done quickly.
  28. Thanks GoDadGo thanked for this post
    Likes GoDadGo liked this post
  29. #142
    Today I spent some more time cleaning up the opening in the dash for the glove box. I got a 2" sanding drum that I could put on a drill and got the opening looking much better.
    I also tested the 3-D wrap material thickness in the opening to be sure nothing rubbed.
    Finally, I wanted to see if the trunk liner material I used on the MK4 trunk would look okay in the glove box. I'm not convinced yet and may want to look at something else.
  30. #143
    Next up was the triple reservoir bracket and bezel from Snakebite Motorworks. First step was to assemble the bracket. This requires tapping 5/16-18 threads into the FFR brackets and then mounting them to the Snakebite Motorworks bracket.
    Next step is to mount the bracket to the frame rail. This requires pulling some pretty stout 3/16" stainless steel rivets. I had to increase the air pressure to 90 psi on my pneumatic riveter to pull them. I tried by hand first, but that wasn't going to happen.
    Once in position, I marked and drilled the engine bay frame rail panel, also from Snakebite Motorworks. This required some patience and accuracy, but it worked out perfectly.
    And finally, drilling the bezel bolt holes and attaching the bezel to the panel. You have to do this with the panel removed, so if you plan to use these parts, keep that in mind.
    I really like how Brent's setup makes this look finished.
  31. #144
    Mar 2021
    Ohio
    Dave, you could potentially flock the inside of it. I have not tried it but I am thinking about testing it on the door pockets. I used this underfelt for my door pockets and it worked well.
    https://a.co/d/dK4Ybnj
    I glued it with the Landua Top and Trim
    https://a.co/d/6mwrCnA
    Your build is looking really good! If you decide to do the felt, I can walk through how I did the door pocket.
  32. #145
    Thanks, Brent. I'll take a look at the links. I've looked at the flocking kits and a couple of videos. My only concern is durability.
  33. #146
    Mar 2021
    Ohio
    Mine as well. It is not something that I have tried. The underfelt worked really well on the door pockets and was not too thick.
  34. #147
    May 2021
    Fort Worth, Texas
    Neoprene material is a good option for the glovebox.
  35. #148
    Making some progress on getting all the holes drilled in the engine bay aluminum. I bought a 7/8" hole saw bit for my drill that did a great job with the heater and A/C holes for the bulkhead fittings that FFR provides. The bit has a spring that pops out the plug when you drill the panel so that you don't have to dig it out of the bit.
    The bulkhead fittings in place:
    More fitting and drilling:
    I still have a bit more to figure out in the engine bay before I mark the panels ready for powder coating.
  36. #149
    Next up ... figuring out how I want to run the brake reservoir hoses between the master cylinders and the reservoirs. I initially thought I'd run all three hoses through the clutch cable opening, but that puts them in an awkward position at the reservoirs and leaves me with trying to seal up the gaps created on that opening.
    I think a cleaner approach will be to plug that hole and use three 90-degree bulkhead fittings that allow me to keep gentle curves/bends in the hoses inside the footbox as well as outside.
  37. #150
    Jul 2025
    Folkston,Georgia
    Sorry Dave …I’m just making sure I know how to attach pics to posts … anyway if this works here’s a pic of the race car I sold to build my coupe!IMG_0300.jpgIMG_0289.jpg
  38. Likes Papa liked this post
  39. #151
    Jul 2024
    Detroit Mi
    Dang Mark.
    That's Nice!
    Type 65 Daytona G3 Coupe #635 - Dart 363" SBF
    1970 Plymouth Road Runner 440 6-BBL Super Track Pack
  40. Likes Lugnut Mark liked this post
  41. #152
    Jul 2025
    Folkston,Georgia
    Thank you sir … she was fast as well
  42. #153
    Beautiful!
  43. Likes Lugnut Mark liked this post
  44. #154
    Jul 2024
    Detroit Mi
    I bet.
    How fast?
  45. #155
    Jul 2024
    Detroit Mi
    Sorry Papa... don't mean to hijack
  46. #156
    Today, I spent some time pondering the routing of my reservoir to MC hoses. I looked at using some 90 degree bulkhead fittings inboard of the clutch cable hole at the top of the footboard, but now I'm second guessing that. I ran the hoses back through the clutch cable hole and can easily connect to the reservoirs. I did some digging and found a few ways to use that location and still seal off any heat getting into the footbox. I'm making a patch panel that will fit three bulkhead fittings in the 1-1/2" opening. I think I have something that will work mocked up. Once I get it cleaned up, I'll post some pictures.
  47. #157
    Nov 2020
    Damascus OR USA
    I have sidestepped doing this for quite a while as I was waiting on a bracket from Snakebite. While waiting, I purchased 90 degree AN fittings for the reservoirs, -3 hose with fittings to make custom hoses, straight bulkhead fittings for the passthrough and the Wilwood AN hats for the MCs.
    I still am not sure I will go this route and I know Paul made a sort of "clover leaf" cover for that clutch hole for his Coupe build that probably sealed it up pretty well. I will be interested to see what you come up with since I am finally ready to install as well.
  48. #158
    Aug 2019
    Spokane, WA
    Hi Dave. FWIW I also routed my hoses through the clutch hole. I made this little panel with holes to route the hoses from the reservoirs. I traced the contour around the chassis, which allowed me to close up the gaps as well.
    Here's what it looks like in place. Not the best angle, but you can get the idea.
  49. Likes PNWTim, AaronR liked this post
  50. #159
    Chris,
    I'm doing something similar, but using bulkhead connectors. I'd be concerned about the hoses being in direct contact with the panel since vibration could cause the panel to wear a cut into them over time.
  51. #160
    I spent a bit of time waiting for parts to arrive to try my idea of fitting three bulkhead barbed passthrough fittings into the space of the clutch opening.
    The good news is that they fit, but the bad news is that with my reservoirs mounted, there isn't any space to get one of the hoses and a clamp into the barb.
    So, back to the Internet to see if I could find some 90-degree barbed bulkhead fittings. The ones I got through Amazon that were listed as 1/4" barbs are more like 3/16" and don't fit the hose well. In my searching for different parts, I came across a different solution that I am going to try. I found some brass bulkhead fittings with 1/8" NPT threads that will allow me to attach barbed fittings with 1/8" NPT threads on one end and 1/4" barb on the other.
    I'll follow-up once these arrive and if I decide to use them or not.
