Lessons learned. The condenser should probably be mounted on the bottom instead of the top. It hits the body. I’ll probably try to just lower mine a bit so I don’t need to remake the AC lines.
The call in the AC port lines was correct. There would be no way to get to them with the body on. I think there will be plenty of clearance for the reservoir. They are 5 inches below the hood.
