Results 1 to 11 of 11
Thread: Aluminum panels - pre drilling?
    Jun 2025
    Hi All
    New builder here, I am building an MK5 - and general question about the aluminum panels. I plan on having them powder coated - and it seems that the consensus is to pre-drill the panels prior to sending them out. My plan is to pre-drill the points where it will be riveted into the frame, but how do you handle where they overlap? I am not sure how the holes will line up, without drilling while they overlap and into the frame.
    Any suggestions on how you all have done the pre-drilling on your builds would be appreciated. Do I mock them up on the frame, drill through the panels while on the frame and use clecos? Or do I drill the panels off frame? And as mentioned, if off frame - how do I handle the panels that overlap?
    Thanks all!
    Eric
    Use clecos to hold the panels for mock up and drilling all prior to coating.
    Jun 2025
    So, drill into frame using clecos to hold it - disassemble, send to paint - then once back, line up to the holes made in frame and rivet? Appreciate the feedback!
    Quote Originally Posted by ericd View Post
    Yes, drill into frame or overlapping panels.
    Dec 2023
    Eddyville, KY
    That's how I did it on about 90% of my panels. I can tell you for sure I REALLY appreciated having everything predrilled when I got back to that part of the car. Being able to compare having it predrilled vs. not. Predrill wins 100 of 100 times.
    Jim
    Aug 2021
    Linden, CA
    If I remember correctly there are spots on some panels it’s better to use bolts and not rivets when assembly happens. Think one is DS footbox top panel
    Mar 2024
    Any guess on how many Cleos a guy should have? I own a couple dozen 1/8” size.
    Apr 2024
    St. Charles, MO
    Quote Originally Posted by Shamilton289 View Post
    Like weapons and cars…just a few more…
    Jan 2024
    I have over 100 clecos (I'm a retired aircraft mech). When I did my panels as discribed above I had ALL of them installed. NOTE: when you finaly get them rivited on carefully paint the rivit heads. Its a small detail you'll be glad you spent the time on.
    good luck
    Jun 2020
    Rising Sun , Md.
    Rebostar, I like your choice of color for your panels as well as the frame. I think it brightens up the engine compartment. I wish I had done that instead of the flat black I used.
    FFR 9883 MKIV ,427 Windsor engine
    TKX 5 speed, Three Link 3.55 gears
    Power Steering, Leather Seats
    18" Wheels and Tires, Drop Trunk
    Fun Package
  11. Thanks Rebostar thanked for this post
  12. #11
    Jul 2021
    Big Canoe, GA
    Quote Originally Posted by Rebostar View Post
    ... when you finally get them riveted on carefully paint the rivet heads. It's a small detail you'll be glad you spent the time on.
    Yes indeed- paint the heads. Also- I like the e-power steering you have there. I have the same; love it!
    Art Shand, Big Canoe GA
    BPE 347 FI, Hydraulic Tremec TKX, Wilwood front & rear, GAS-N Headers/Touring Pipes, many functional upgrades.
