I'm looking for some advice on what kind of battery charger I can use for the Odyssey AGM battery. I have a Battery Tender charger. It says it's a "smart" charger compared to a trickle charger, and is compatible with AGM. I supposed that should be a good enough recommendation, but the Odyssey battery itself mentions minimum 2.7A charging rate. But my charger only outputs 1.25A. Am I okay to use it? I'd rather not have to buy another charger unless necessary.
Specifications.
