It is indeed a ground according to the Edelbrock manual. Should work fine. I just don't understand why the ignition and sender wires are reversed compared to how FF wires the relay. My novice best guess is you have to have power to one side and ground to the other to complete the circuit and for the relay to actuate. Technically it doesn't matter which side is which.
