Results 1 to 10 of 10
Thread: 818 axle shaft specs
    Calgary
    Needing help as I cannot find the part or the engineering specs for my broken axle shaft. I am trying to replace a broken axle shaft for the 2005 Subaru Impreza 2.5 RS with no luck so far. Factory Five no longer makes the part, and I do not believe that they will share the engineering drawings. Anyone know where I could source axles or the .STL or .STEP engineering specs for the axle? Reverse engineering the part could get pricey.
    Thanks in advance.
    TriguyDave
    818 noobie builder
    First start: Sept 28, 2014
    Go-carted: Oct 4, 2014
    Registered and Street legal Sept 30, 2015
    Calgary, Alberta
    May 2020
    I believe people on this forum have had success using the The Driveshaft Shop to get custom axles made. You would need to specify the different splines on the inner and outer to match based on your rear outer CVs and what transmission you have. This shop is familiar with Subaru should they should know the spline counts.
    https://driveshaftshop.com/product-c...007-wrx-axles/
    Woodruff, SC
    I got mine at DSS. Was able to spec both ends and the length. Worked perfectly.
    Nov 2021
    Chicagoland
    I have spare FFR supplied axles if you need them.
    Apr 2022
    Kansas, USA
    Are these more or less guaranteed to eventually break? I've seen quite a few reports. I'm still rocking the ones that came with my 2014 kit and have quite a few autocrosses on them. Wondering if I should go ahead and get a set of spares made.
    Mar 2021
    SE WI Kettle Moraine
    TADave,
    I have altered my 818 project to Acura V6 powertrain and will not use my 818 reworked axles or my aftermarket suspension bits.
    My axle splines are outer (M) 24 count and inner (FM) 25 count.
    jim
    Jun 2020
    Danville CA
    My experience is the FFR axles are stronger than the 5 speed third gear and pinion gear.
    I twisted and sheared off a couple of axle shafts that came with my early kit.
    FFR sent me a set of pre-assembled half shafts that have held up fine. Not doing any wheel-hopping launches anymore.
    Here are my notes on that FFR assembly.
    Inner Joint: 3 rollers, 23.6mm male spline, 29 teeth, snap ring holds 3 lobe carrier
    Outer Joint: 8 balls, 23.6mm male spline, 29 teeth, spring clip for 8 ball carrier
    Boot clamp to clamp distance: 335mm
    FFR axles are 20.875" long
  9. Likes driveslikejehu liked this post
  10. #9
    Yes, I love Technology
    aquillen's Avatar
    NW Indiana
    I posted the pic just above while I had both in hand from FFR.
  11. #10
    Apr 2020
    TriguyDave,
    FFR sent me 2 bare axles, their part number 80237, for my 2006 Impreza non-turbo donor build, even though I ordered and received 2 fully assembled axles. Is that the number stamped on your broken axle, or listed in your parts list? They are probably no stronger than yours, but I might be able to help you get back on the road a little quicker while ordering a stronger one.
    RPG
