0
I believe people on this forum have had success using the The Driveshaft Shop to get custom axles made. You would need to specify the different splines on the inner and outer to match based on your rear outer CVs and what transmission you have. This shop is familiar with Subaru should they should know the spline counts.
https://driveshaftshop.com/product-c...007-wrx-axles/
