Thread: Water pump selection
    Sep 2022
    Ogden utah
    So my question is what water pump oreantion to use on Windsor motor, driver side intake or passenger side intake that best fits. I'm using this belt drive from summit https://www.summitracing.com/parts/t...93bk/make/ford with a 1:1 ratio. I would think the driver side intake would be better but you know what happens when you assume 🤣. Open to any opinions or suggestions.
    Dec 2021
    Flower Mound TX
    Sep 2022
    Ogden utah
    Thanks Mike, a visual always helps to get your mind around it.
    Jul 2021
    Tonganoxie, KS
    I used that same Flowkooler. Great product.
    Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, ReplicaParts
    MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, First start 3/15/25. Legal 6/13/25. Boss 427W, Edelbrock Pro Flo 4, TKX (.68 5th), IRS, Wilwood Brakes, 18" Halibrands, Toyo R888R Tires, Custom Speedhut Gauges
    Jun 2024
    I just installed an Edelbrock Victor #8840 water pump on a clients small block. He is using a reverse flow pulley setup and has no hvac system. It's a bit more expensive but it uses pipe plug fittings for the small outlets for a cleaner look installed, instead of a capped outlet.
    Ottawa Ontario
    FlowKooler has a very nice billet impeller, pumps more water at low speed and less at high speed.
    FFR #3870 MK II, Spectra Blue/Arctic White, 1974 414W, 10:1, Eagle 4340 crank and rods, KB Pistons, Ported Performer RPM 2.02 heads & intake, QFT SS-650, Comp XR282HR, Quality Roadsters pan, Crane ignition, TKO600, 3.55 gears, 3 link, SA QA1's, Breeze LCA's, Heim joints & VPM F/R bars, Power steering with Hiedts valve, Power brakes, Fortes bump steer kit, 5 bolt axels, SSBC rear brakes, Oil cooler, Pusher fans, Halibrand Cobra III's with Nitto NT555 G2 245/285/17
