Likes Likes:  5
Thread: Graduate (Mostly) '35 Truck F5R1000039TR !!
    Swapping out hot wheels:)
    Raleigh, NC
    Please graduate (less final body work and paint) my '35 Truck build. Some key features:
    • Stacks! - dual exhaust system with cut-outs for undercarrage or stacks
    • Blueprint 306 with Holley Sniper EFI
    • Electric power brake assist
    • Power steering
    • Tremec TKO600
    • Wood bed with removable panels for access
    • Tow hitch
    • Extended cab 3.5"
    • Bike front fenders and modified rear
    I just sold it to Steve M out in SD. He's going to finish it up while I go onto my next build - an MK5! It will be my 5th Factory Five build - just love building these things!
    2025 May: MK5 Complete kit, Blueprint 347 EFI, 4R70W (current build)
    2019 Nov: '35 Hot-rod Truck, 306, EFI, 3-link (screwed by NC DMV)
    2015 Mar: MK4 Complete kit #8617, 302 create, carb, 3-link
    2014 Sep: MKII Kit #4215, 302 create, carb, IRS, Sold as roller
    2011 Mar: MK3 Base Kit #5400, 4.6L Fuel Injection, Daily driver
    Dec 2018
    SW Calgary, AB
    I absolutely dig the stacks!!!
    Nice build! 👍🏼👍🏼
    Once again with an 88 mm Turbo, Big Block Chevy powered, ‘35 Hot Rod Pickup
  3. Likes GoDadGo liked this post
    Quote Originally Posted by Pat Landymore View Post
    Nice build! ��������
    Ditto On The Stacks!
    Prescott, AZ
    Nice, enjoy that build. Can you do me a favor? It looks like you may have the same accessory drive as I do, or at least one very similar.
    Can you take a picture of the passenger side of your accessory drive......Was there interference with the diagonal frame member? Please see my picture below.
    Oct 2020
    Albany, NY
    Man!! those pipes are so great. I can't believe how much it sets off the build. If I ever build a truck I am shamelessly going to do the same thing.
    Oct 2023
    Thanks for the pictures. I've been thinking about creating a storage box in the dead space above gas tank on the drivers side, so it's great to see how you executed that idea (size, access, etc.)
    May 2021
    hi
    Your bed solution is the answer for What I have been searching. The wood surface looks quite thin and glued to the stainless steel panel. Did you have to shorten the with of the SS panel.
    Thank you
    Cam
