Likes Likes:  4
Thread: Door Space between body and chasis
    Dec 2023
    What are people doing with their interiors. Specifically, the little gap in the door well that has a small gap between the chasis and the body.
    I put a light by the left rear tire to get a better shot of it.
    Mk IV, IRS, 302 w/EFI & T5, 15" wheels
    Southern Ontario/Cape Coral FL
    Quote Originally Posted by Legendary View Post
    I put a light by the right rear tire to get a better shot of it.
    You need a piece in the wheel well.
    Higgy
    MK4 #11354 picked up 10/06/25
    MK4 #11173 picked up 01/20/25
    MK4 #11012 picked up 04/16/24 SOLD
    MK4 #10616 picked up 4/10/23 SOLD
    MK4 #9759 picked up 4/3/19 SOLD
  3. Likes Legendary liked this post
    Dublin, OH
    yup, also fabbed a piece to block this off from some spare aluminum I had. If not, expect to get your outside arm soaked if you drive through water.
  5. Likes Legendary liked this post
  6. #4
    Aug 2022
    Portland, Oregon
    I added some bulb seal as well.
  7. Likes Legendary liked this post
  8. #5
  9. Likes Legendary liked this post
  10. #6
    I use the foam that is supposed go down the outside of the foot boxes(that everyone usually throws away) on the underside of the aluminum instead of the bulb seal on the side. A little cleaner look, same solution.
    Higgy
  11. #7
    Dec 2023
    Thanks for the good tips. Will have to fab something up next weekend to take care of it.
