Results 1 to 17 of 17
Thread: Wheel Size Choices, Mk5
    Looking for guidance on wheel sizes. Originally focused on Halibrand style in 17". Will use Wilwood 12.88 brakes. Vintage Wheels and other wheel vendors warned about clearance issues with these brakes. These 17" wheels were all matching FFR specs for backspace/offset. They suggested 18" wheels for better clearance and to "better fill" the wheel wells. What is the experience of others with these Wilwood brakes and 17" wheels, FFR offered wheels vs others, and 17" vs 18" wheels. Focused on a Halibrand style, but open to other classic style wheels. Appreciate all opinions.
    These have great offsets and offered in 17's and 18's.
    Hexcentric rings would be needed to properly center them since the centers bores are tad large.
    https://circuitperformance.com/categ...asic%5Bgray%5D
    Wilwoods clear with FFR 17" rims.
    Rim diameter has ABSOLUTELY NOTHING to do with "filling the wheelwells"...that is totally dependent on tire diameter. A 26" tall tire on a 15, 17 or 18 rim will fill the wheelwells exactly the same.
  4. Likes J R Jones liked this post
    Thanks. In general, are folks pleased with the FFR wheels? If the Wilwood 12..88 brakes will fit without issues, my original thoughts were 17" FFR wheels with Nitto NT555 G2, 315/35/ZR17 (25.6" diameter) and 255/40/ZR17 (25.04"). They are slightly smaller in diameter than the rear, but seem to fill the 9" width wheel better. Thoughts of others?
    Quote Originally Posted by Ejzajac View Post
    Go with the Factory-5 wheels if you want that Classic Cobra Look.
    Just know that you'll have more tire choices if you go with the 18's.
    My original wheel and tire combination sported the following:
    245/45-17 Front & 285/40-17 Rear.
    25.67" & 25.98" Diameters
    17X9 & 17X10
    Nitto 555's
    https://youtu.be/9WEe6-wdNtA
    My current wheel and tire combination sports the following:
    255/40-17 Front & 294/35-17
    25.08" & 26.18" Diameters
    17X9 & 18X10
    Nitto NT-05's
    https://youtu.be/iwslgKJUaKc
    Hope This Helps & Good Luck!
    Jul 2021
    Tonganoxie, KS
    Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, ReplicaParts
    MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, First start 3/15/25. Legal 6/13/25. Boss 427W, Edelbrock Pro Flo 4, TKX (.68 5th), IRS, Wilwood Brakes, 18" Halibrands, Toyo R888R Tires, Custom Speedhut Gauges
    Dec 2017
    Southern Ontario/Cape Coral FL
    Quote Originally Posted by gbranham View Post
    Man, you need to dirty up that shop!!!
    Higgy
    MK4 #11354 picked up 10/06/25
    MK4 #11173 picked up 01/20/25
    MK4 #11012 picked up 04/16/24 SOLD
    Those 18's Look Really Good!
  10. #9
    Massachusetts
    I have the 18" Halibrand wheels for my MK5. I liked the classic look of the 15" but being in the auto industry, I did my research on tire availability for the 15" and 17" with my wholesale suppliers, and found that it wasn't to my liking. The 18" option had more choices on tire brands as opposed to the other sizes. I'm running the Continental ExtremeContact Sport02 on my MK5, just to give you an idea of what is out there.
  11. #10
    Quote Originally Posted by Takis31gk View Post
    Second this. According to all my autocross buddies, 18s have the best tire selection.
  12. #11
    ...I'm running the Continental ExtremeContact Sport02 on my MK5, just to give you an idea of what is out there.
    They don't offer a 315/30-18. What size are you using?
    Massachusetts
    245/40R18 Front
    295/35R18 Rear
  14. #13
    Stevensville, MD
    Go here and get wheels and tires all at once. https://www.performanceplustire.com/...Wheels%20ACIII
  15. #14
    Thanks to all who have responded with education and options! Is it more important to have the final diameters be identical front to back OR hit the sweet spot on filling the diameter of the rim. My understanding is the tire diameter of 26" is reasonable for a typical ride height. Thanks again.
  16. #15
    Jun 2024
    Those wheels are great. Pretty much exactly what I'm looking for. The backspacing and offset throws me a bit though.
    The fronts 18x9.5 have a 6.63" backspacing and a 35mm offset
    The rear 18x11 have a 6.79" backspacing and a 20mm offset
    Wouldn't the backspacing and offsets be too much ?
    The FFR wheel specs
    18x9 with 6 inch backspace 24 mm offset.
    18x11 with 6.46 backspace 12 mm offset.
  17. #16
    Quote Originally Posted by CW_MI View Post
    The FFR wheel specs
    With those specs when compared to the FFR wheels the fronts will have .67" less inside clearance and the outer edge will be .18" farther inward. In the rear they will have .31" less inside clearance than the FFR wheels and the outer edge will be .31" farther inward.
    Jun 2024
    Thanks Jeff. I've got a wheel offset gauge at home, but haven't spent any time messing around with it.
    Inward doesn't seem like the way to go. Might not be an issue on the front, but i want the rear wheel to be further outboard, and more even with the wheel lip. I'd still have to run a spacer, which I really didn't want to do .
