Likes Likes:  4
Thread: Registration in British Columbia (BC) Canada
    Harley818's Avatar
    Vancouver BC
    Got my car registered and plated on Monday, so now I can share the process for those of you still to get here.
    Mine is the #1 818S to be registered in BC. (this process would also apply to registering an FFR GTM in BC)
    1 - go to the ICBC (insurance company) website and download the form "application form for a BC assigned VIN".
    The link is.....
    http://www.icbc.com/vehicle-registra...ber-(VIN).aspx
    2 - Follow the application instructions, which are fairly straightforward, but register for a "Ubilt", and make sure you include the photos per the application.
    You will need to designate an inspection facility for your car. DO NOT take it to any inspection facility. Contact Al Beix from Western Cobras - he is a vendor on this forum, or myself for a recommended inspection facility that is favourable to hot rods. I went to KR Auto Clinic in Langley. 604 533-3376.
    ICBC will not accept an application for a replikit or a kit car. Those only apply to vehicles which are replications of cars 40 years old or more (like the FFR cobras).
    It took about 3 - 4 weeks for them to process my application.
    3 - ICBC will send the VIN Plate to the inspection facility and they will install it on your car if it passes. ICBC will also send you a letter stating that your VIN is approved, and it outlines your next steps in writing, and has instructions for the Autoplan agent. You have 30 days to get it inspected, but they told me they aren't to strict on the 30 days.
    4 - Go to an Autoplan agent and ask for a temporary permit to drive your car from point A (home) to point B (the inspection facility) and back. I had to show them the ICBC letter, and then it was no problem to get the permit for an "unregistered" vehicle.
    5 - get your car inspected.
    Prior to the inspection, I called to ask them what they check.
    There is a form online with requirements.....
    They are looking for all safety related items, lights, signals, mirrors, seat belts, secure steering linkage and suspension connections, good tires and wheels etc. I specifically asked if I needed a catalytic converter.... not required, and they don't check. Also, they don't check for "check engine" lights on the instrument panel. The inspection took an hour. Cost - $125.
    6 - take your car to a weigh station. I took mine to the North Shore Transfer station (recycling depot), and paid $15 for the weigh and weigh slip with permit number referenced.
    7 - take the original VIN application information & GST & provincial sales tax receipts, the inspection report, and weigh slip to an Autoplan agent, who will register your car, plate and insure it.
    Good luck
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
  2. Thanks 818 Dreamer thanked for this post
    Likes Terry D, CptMorgan, driveslikejehu liked this post
    May 2023
    I registered and plated my Roadster build today.
    All of Harley's points and steps above are still 100% valid and correct. Do use his guide above.
    Here are a few new tips based on my experience:
    -It took nearly three months for ICBC to respond to my VIN application and another week to approve it.
    -The ICBC "Vehicle Registration Support Representative" who reviewed the VIN application was very professional.
    -He will need zero-dollar owing receipts. Invoices for motor, wheels and tires must be stamped "paid" or show zero balance owing to prove all the taxes have been paid.
    -I was able to apply for the VIN before the car went into the bodyshop.
    -The VIN should be riveted under the driver's side dash, next to the FFR serial number. ICBC would not allow the VIN to be installed under the hood.
    -Getting the car registered and plated can require patience. Even the most senior Autoplan brokers and the ICBC supervisors may insist a "FORM 1" is required. (FORM 1 is irrelevant and impossible to acquire for a part kit). The ICBC rep who supplied the VIN can sort this out and direct the broker to register the car without a FORM 1.
    -The broker asked for a weight scale slip, but did not insist. This may be up to the broker's discretion.
    -Insurance was relatively cheap for ICBC, even with a significant declared value. (A nice surprise at the end!)
  4. Likes FF33rod liked this post
  5. #3
    Jun 2018
    North Vancouver, BC, Canada
    For the '33, the VIN plate was riveted to the driver's side door jamb...
    Gen 1 '33 Hot Rod #1104
  6. #4
    Back in 2010 when I went through this process, I was required to swear an affidavit, that all major components used in the construction were legally purchased and paid for. I had to bring receipts to the notary, along with serial numbers for engine, tranny, and the rear end.
    Once inspected and passed and I went to the Autoplan broker to register and insure it, there was some question about Provincial sales tax. I explained that all the taxes were paid at the time of the purchase of all the components, both PST and GST, so I owed nothing. They agreed, rather than to look through my shoe box full of receipts..
    Thank goodness as there were a lot of them, for every single odd screw, nut, bolt, wire, even fluids used in the build. To this day I never have added them all up.
  7. #5
    Feb 2020
    The site asks for proof of the original parts such as brakes etc the donar parts. Did you have anything to show that? I have lost all my paperwork including the original sale of the donar car. (Moved house). I am adding an extra fly in the ointment in that I’ve made mine electric. I do have copies of those sales receipts as it was all online. But looking at that application I’m concerned about not having anything about the donar car. ICBC should have a record of it.
  8. #6
    Sep 2025
    Quote Originally Posted by CptMorgan View Post
    Hey have a quick question for you - I'm in the middle of purchasing a roadster that was built and registered in PEI - where did you get the car safety inspected? I just called a local shop and they were thinking that because the car was built in 2021 it needed airbags?
  9. #7
    Sep 2025
    Just an update, finally have my car registered and insured. Apparently "Factory five racing" is not on their system so they've used a temporary premium that they will review, and hipefully adjust down.
    For the inspection i used KR auto clinic out in Langley. Chill and super easy to deal with. Helped me find a broken driveshaft bolt while they were at it and got it taken care of. Can't recommend them enough. Charge hr rate of $135 for the inspection.
    Look forward to a BC meet up soon!!
