Results 1 to 3 of 3
Thread: Slick sand/feather fill on inside doors, under hood/trunk
    Apr 2024
    Does anyone put slick sand on the inside of the doors or under the trunk/hood? The gelcoat is pretty smooth after some sanding and the doors will have door cards covering most of it. Didnt know if it was worth the time/material or just go to primer/sealer on those parts.
    Thanks!
    Mk4 Complete Kit 11037. Ordered 03/26/24 Delivered 05/29/24 Complete 1/7/25. Powdercoat, IRS, Gen 1 Coyote Donor, North Racecar AC
    I do the inside of the doors hood and trunk exactly the same as the rest of the body; Polyester (Slick Sand), Urethane primer surfacer, base and clear.
  3. Thanks bartock thanked for this post
    Apr 2024
    thanks for the feedback. Hopefully the temperature holds out tomorrow to shoot a few coats. If all goes well I am set to paint monday or tues!
