I could not get my hood to close properly without the rollers. My hood has an extreme cup to it and wants to turn inwards. Definitely a necessity to keep the paint from getting destroyed.
My unsolicited advice? Ditch those lines and go Nicopp, cheap, easy to bend by hand in the car and they’ll outlive that car. And perfect flares every time with that tool. I didn’t have a single leak afterwards.
Kbl7td
You're probably right about the Nicopp. Hell, the steel lines from the kit probably would be fine too since this car will never see rain.
I already bought the stainless lines, so I'll keep practicing and see if I can get better. My idol, Mr EdwardB, just makes everything look so easy. Haha
I had the same issue and an old timer told me to use the single flare with the stainless tube sleeves and nuts. They worked out well.
Mike Brake explains it well in this recent post.
https://thefactoryfiveforum.com/show...ht=Brake+lines
burchfieldb
If I can't get my double flares better, the 37 degree single flare and AN fittings is what I plan to do. What's another $150 of fittings at this point anyway?
I forgot to mention, I am using double annealed, 0.028" walled tube from In-line Tube in 6 foot straight lengths
https://www.inlinetube.com/products/ss3166
I used the same, as well as trying multiple different flaring tools. I even purchased preflared lines and one of the ends on each tube had the same cracking issue. At that point, I was so far down the rabbit hole that I went with the 37 degree fittings.
burchfieldb
Dang guys, not giving me much hope here!
Great progress, Jim. Some good ideas--thanks for posting them.
This week I made the decision to back away from my planned 3/8" SS hardlines for my fuel lines (I'll explain in a future post). Not sure if I'll stay with my plan for SS for the brake lines either (Ni-Copp is looking better and better). Unfortunately, I already have a 25' roll of SS 3/16" tubing. Looking forward to seeing how your 37 deg. option comes along.
Coupe complete kit. Index. Delivered: 4/22/24.
Build Thread. Coyote Gen 4X. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
MK4 Complete kit.
Build Thread Index. Delivered: 10/15/2020. Legal: 7/25/23. Coyote Gen3. TKO600 (0.64 OD). IRS w/3.55. PS. Wilwoods. Sway bars. This build is dedicated to my son, Benjamin.
Build Thread.
460.465USMC
I'll be interested to hear why you decided against the stainless fuel hardlines.
I received my AN/37 degree fittings for the brake lines.
I've been reading (or trying to - there is very little info) about using the Eastwood tool for 37 degree flares. I bought the 37 degree die upgrade, but I've been reading some opinions that it doesn't produce very good flares and that I should get a Rigid tool. I really don't want to spend another $150 on another tool
Anyone have experience with the Eastwood tool doing 37 degree flares?
I started with the Eastwood tool and then returned it since I could not get it to produce the double flares. I ended buying the Rigid tool and it works well.
burchfieldb
I wish I had done more research before sinking $300+ into the Eastwood tool and 37 degree die pack. This was an example of "follow the leader" without doing my own research. I would have gotten the Rigid tools straight away if I had.
Lesson learned.
I'll practice some with the Eastwood tool and see how the 37's go
JimStone
Lesson learned.
I never tried to do double flares with stainless, only nicop and they worked great (using my K Tool flaring tool). For my AN flares I used the Rigid tool and have no leaks 5 years later - it works great. I am not sure I even realized I could get the 37 degree dies at the time so maybe ignorance was bliss?
JimStone
Regarding the seats, I actually won't have to modify the cockpit aluminum or cut off the seat belt tab. To make the seats fit back far enough for me (6'2") I was able to trim the reclining mechanism to gain an inch, then bent the seat belt tabs out some. I've been working on some custom seat mounts.
@JimStone,
Ordering these seats today. I was looking at these when I ordered by Coupe due to the reported issues with the Corbeau.
Can you advise what you did to "trim the reclining mechanism"? I have ~6' 1" so I am a little concerned, too.
Justin
wedel456
@JimStone,
Justin
I think you'll be happy with the Braum seats. They look great and seem to be well made.
I used a die grinder with a 3 inch cut off wheel to trim the plastic housing for the reclining mechanism. I did have to get a little into the steel part of the mechanism, but not too much and certainly wouldn't compromise any significant strength.
The trimming allowed the seat to sit back another inch or two. For me, at 6'2", this was necessary.
But with the seat mounted you can't even see the backside of the mechanism, so it does not show.
Interesting. I like the diode pattern on the top one but prefer the size of the bottom one. The middle is a non-starter for me. I am going to be doing the same but haven't gotten that far along, Did you look at edwardB's light he installed? I believe he used a Maxxima light bar.
10-24-2024, 09:46 AM
#100
Choose the one that suits you but do choose one. IMO, these cars sit so low that you need something up high. I agree with PNWTim.
10-24-2024, 11:28 AM
#101
Jim
Here's mine lit up for reference:
Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21, CA SB100 Registered 8/27/24 - BluePrint GM 427 LS T56, IRS, AC, Power Steering.
Album Here
10-25-2024, 07:22 PM
#102
Thanks to Amazon Prime Free overnight delivery, I added a 4th option (2nd from the top)
I think it's your's, Lewma - United Pacific 38947B 12" 14 LED.
So we have the following options:
Top: 17" Trunk Tailgate Light for Trucks from iJDMTOY.com. (Which I now see is probably rebranded United Pacific LED Taillight Bars 37090)
2nd from top: United Pacific 38947B 12" 14 LED
2nd from bottom: United Pacific dual function GLO light bar, 12" 24 LED
Bottom: United Pacific 38943B 9" 10 LED
10-25-2024, 08:08 PM
#103
Album Here
10-26-2024, 07:10 AM
#104
I like the 2nd from bottom. More of a solid across look. I'm not sure it would be the best with whatever brake lenses you choose though.
10-29-2024, 08:55 PM
#105
I am also in the camp of the solid bar look
10-30-2024, 07:05 AM
#106
Out of those options, I like the Glo bar best.
10-30-2024, 01:12 PM
#107
10-31-2024, 09:22 PM
#108
Thanks for the opinions guys.
I think I've settled on doing one of the two 12 inch light bars.
The 17" is too big, and 9 inch maybe not bright enough. I didn't try a 15 inch, which I think is what EdwardB has, but I think I've bought enough brake lights for now!
Completed running the brake lines and nearly finished with the 3/8" SS fuel lines. Much easier now that I have the hang of flaring and bending. Will post pictures when complete.
11-01-2024, 07:15 AM
#109
Have watched this series of comments with interest. I think a third brake light on Coupe builds is important. They are very low and many people have commented to me how much easier it is to see with the higher third light. I don't think the exact one is critical. Whatever your personal tastes dictate. As mentioned, mine is a Maxxima, specifically M63319R, 15" wide, embedded into the spoiler. What I like about this one is that it's partially lit with the running lights. Then fully lights with the brakes. For even more visibility. Maybe others do the same thing. Did this YouTube during my build.
Build Thread and
Video.
Build Thread.
Build 5: 35 Hot Rod Truck #138.
Build Thread. Sold 11/9/2023.
Build 6: Mk5 Roadster 30th Anniversary #11,258.
Build Thread.
Post Thanks / Like - 0 Thanks, 3 Likes
11-22-2024, 09:48 PM
#110
I installed the parking/emergency brake cables, but had two problems:
1) The first cables were way too long.
Factory Five quickly sent me out the correct ones (love their customer service )
2) More concerning.
After just a few times engaging the parking brake, the cable liners have frayed, exposing the bare cable. Look closely at the picture below where the cables enter the sleeve. It's a pinch point due to the hard angle the cable is forced when engaging the lever.
I'm worried there will eventually be binding in the parking brake.
Anyone else have this problem?
11-23-2024, 12:03 AM
#111
I can't speak from personal experience assembling as yet but just looking at those pictures, the bushings need an inside radius to prevent that. Even then a tougher sheath may by in order?
11-23-2024, 12:52 AM
#112
PNWTim
Thanks Tim. I'll try rounding the edges.
Do you think those cables are shot now that the sheath is peeled back? I'm envisioning rust and eventually binding. But maybe I'm overthinking this.
I'd really like to not have to replace them.
11-23-2024, 08:08 AM
#113
Let me take a picture of my cables, I’m not sure why everyone has problems with this. My opinion is that factory five is supply even the wrong cables, I think I ordered like 93 mustang cables or something. BC94840
11-23-2024, 10:30 AM
#114
JimStone
When it comes to motorcycles, a cable like that is shot. Parking brake, maybe not? Maybe the 93 Mustang cables are the way to go. I just looked through Paul B's. thread and his exit the bushing? at some angle as well:
He makes a comment about having to lengthen the mounting point.
11-23-2024, 01:08 PM
#115
Kbl7td
Oh thanks. BC94840 cables are only $17 apiece, free shipping on Amazon. I'll probably end up replacing them then
11-23-2024, 01:10 PM
#116
PNWTim
I didn't lengthen the mounts. Maybe I should have. It was definitely tight the first few pulls until it kind of equilibrated. Now it's okay.
But I didn't realize I was destroying the cables until too late.
11-23-2024, 08:09 PM
#117
11-24-2024, 10:15 AM
#118
I have no experience with that particular brand but I am a fan of AGM batteries. I personally have a yellow top in my 69 Camaro and keep it on a NOCO tender that has an AGM setting. Batteries any more seem to be hit or miss depending on what year it is. I still like Optimas but I had a red one die after just a couple of years. I know others on the forum are using Odyssey which have their own problems so you probably are good to go with whatever you are comfortable.
11-29-2024, 05:13 PM
#119
Jim I have the same geometry on the e-brake cables. I made a tapered shim to go on the aft side of the bracket which now presents the cables at the correct angle. To secure the cable I took the little sheet metal "keeper" with the prongs on it and I cut down the prongs to make the same new angle as created with the shim. this worked well, no more scraping the liner off the cables
11-29-2024, 11:29 PM
#120
JMo
Thanks for the suggestion John. Would you be able to to post a picture of what you did? I'm having trouble visualizing it.
I need to do something or the cable will fray and bind
