Likes Likes:  4
Results 1 to 14 of 14
Thread: Shifter Boot Interference in 1st?
    Dec 2018
    Sherwood Park, AB
    Question Shifter Boot Interference in 1st?
    I have a Forte's Coyote Gen III build with a Tremec TKX. I had this problem with the stock FFR shifter, where the rubber boot would bunch up and not allow the lever to stay engaged in 1st gear. I had to switch to a Hurst lean-back lever. Anyone else have this problem? Any thinner rubber or leather boots out there that would be a straight replacement to the stock round boot supplied by FFR? Has anyone gone with a a more rectangular boot, to provide the extra clearance?
    32J
    Jan 2024
    I had a similar issue with the FFR rubber boot. I replaced it with a Holley three piece unit with a leather boot. The mounting allows you to remove the boot and upper piece without taking up the tunnel cover. Very handy and looks great. I got it from Summit.
    Hundreds to choose from on amazon
    Also had trouble with FFR rubber boot pulling first out of gear. Think I got this one from FFR, soft leather. Uses their mounting ring.
    Kevin
    MKIV #8234
    NITTO NT01 275X40XZR17 - 315X35ZRX17
    I used a Drake Scott Leather Boot and a Stainless Mounting Ring and knob from Lokar.
    https://www.cjponyparts.com/scott-dr...-1993/p/MSB18/
    https://www.summitracing.com/parts/lok-70-sfr
    https://www.summitracing.com/parts/lok-sk-6933
    You can see how it turned out on my ZF 6-Speed Gear Box around 1:50 - 2:03 in the video link below:
    https://youtu.be/9WEe6-wdNtA
    Oct 2020
    Albany, NY
    I made a little adaptor to raise the shifter about an inch. It was simply a piece of steel with 3 holes. 2 holes lined up with the threads on the shift base and a third hole above that. I attached the shifter to the top 2 bolts. It worked pretty well.
  7. Likes Rebostar, BornWestUSA liked this post
    Jan 2021
    Same issue, my fix was a shifter with a little taller tab before the bend same idea as Blitzboy above, I purchased a shift lever from Modern Drive line.
    2022 MKIV BP347, SniperEFI, IRS. Delivered June 22, Engine install Jan 23, first start May 23. https://thefactoryfiveforum.com/show...4-Build-update
    Feb 2022
    Granbury, TX
    I hadn't heard of this before. Is it only a problem with the rear-shift location, or also with mid-shift like mine? I can't see how the boot would interfere.
  10. #9
    Jan 2021
    I hope I explain this well enough. I can only speak for my experience but it seems others have noticed it as well., In my case using a TKX trans, the hole in the top of the tunnel is barely large enough for the throw of the stock shifter lever to 5th gear the rubber boot would gather and have resistance, it appears the stock shifter lever bent forward too close to the mount of the trans shaft. Couple of fixes here have been to extend the shaft where the lever bolts on (as Blitzboy), change the shifter to one what has the bend higher on the stick (my fix) or maybe change to a leather boot. It appears you have already changed shifter so I think you've avoided this all together.
  11. Thanks OB6 thanked for this post
    Likes Rebostar liked this post
  12. #10
    Feb 2022
    Granbury, TX
    Thanks Jeff.
  13. Likes Jeff_J. liked this post
  14. #11
    Dec 2018
    Sherwood Park, AB
    Thanks to all who have replied. The Hurst shifter i have works fine, but it would be nice to have the shift lever a bit closer to the steering wheel. I still have the stock lever from FFR and I was curious if people found a way to make it work with different boot material.
  15. #12
    Oct 2020
    Albany, NY
    Quote Originally Posted by OB6 View Post
    No, you won't have any problems. The issue in this thread is with the forward shifter. When you shift down to 1st or 3rd because of the geometry of the shift handle it bunches up the boot and causes resistance. If you build your tunnel exactly like the manual says to I think everything clears. A lot of builders add upholstery and other things that raise the tunnel a bit and causes interference. Your shifter is straight up and down. You are all set.
  16. #13
    Jan 2024
    About that Hurst boot from Summit. Here is the P/N https://www.summitracing.com/parts/HUU-116500HST Its biggest selling point to me was once you screw the upper and lower base plates on the tunnel top you will not have to mess with removing the 4 nuts on the bottom of the tunnel cover. The boot & retainer comes off with 4 blind screws. Anyone with some sort of attachment on the front of the tunnel know what a pain in the a** it is getting the 4 lower nuts off. This sytem eliminates that. I have a circuit breaker box that drops down from the Carbon Fiber dash and I have an extension on my shifter these made it a pain to remove the boot.
  17. #14
    Dec 2018
    Sherwood Park, AB
    Quote Originally Posted by 32J View Post
    Attached photos illustrates the issue. I had originally requested the TKX in the mid-shift position, but I think Mike Forte realized that it had to go the rear position to clear the tunnel cross member. The forward position would be too close to the dash. I cut the whole in the tin centered on the turret. Had I known the boot would provide so much interference in 1st (and 3rd), I would have cut the hole offset to the front of the car by maybe 1/2" to 1". Interference is only an issue when you use the shift lever in the alternate, forward lean position.
    I think I'll try to source a leather boot and try the stock lever again.
