Thanks Thanks:  6
Likes Likes:  48
Page 1 of 3 123 LastLast
Results 1 to 40 of 94
Thread: 289 USRRC build in Seattle
    Apr 2020
    Bonney Lake, WA
    Renee's 289 and my Coupe-R arrived. Doing inventory now on something like 70 boxes - both kits almost entirely complete. Waiting on the shortened 3 link axle, it drop-ships from Moser, any idea how long that takes?
  2. Likes M22_COBRA, Chainsaw liked this post
    Nov 2022
    Niles, MI
    Wow, two kits at once. Good luck!
    Gen 3 Coupe #576 - "Project Deimos"
    Blueprint LS3 427, T56, IRS
    Received: 5/24/2024
    First Start: 2/7/2026
    Build Thread: https://thefactoryfiveforum.com/show...upe-has-landed!
  4. Likes Jphoenix liked this post
  5. #3
    Apr 2020
    Bonney Lake, WA
    I've been working on the Coupe-R non-stop, but today brought the 289 chassis down from the barn to start on it. Renee will mark the aluminum tomorrow and remove it all, then begin prepping for paint - 2 coats of black POR-15. I had the Coupe-R powdercoated by FFR and I'm glad we decided not to powder coat the 289 because the quality of the powder coat on the Coupe frame is terrible. So bad they even tried touching up the bits that were flaking off with spray paint prior to shipping it to me.
    Jim Phoenix
    Coupe-R delivered 8/10/2024
    289 USRRC, F5R1011063RD - delivered same day
    Coupe-R has a Ford Performance 363 mated to a TKX, 18084.
    Many details on my Coupe-R are different from a typical Coupe build because mine is not street legal, race only.
    289 has a BP 302 mated to a TKX 18084.
    "For a little more, you can do it yourself." - Ed Hollingsworth... 6-Pack forums
  6. #4
    Apr 2020
    Bonney Lake, WA
    The shortened Moser 3 link axle arrived a few days ago, the short LCA's should be here tomorrow from FFR, they were very accommodating in trading my longer arms for the shorter arms I needed for the pin drive Trigo FIA's.
    The plan is Renee builds the car - does all the dirty work like cleaning painting, drilling, riveting, bolting up the suspension bits and installing the engine and trans while I do the bodywork - eventually.
    Power steering
    Stock FFR brakes
    Trigo pin drive FIA's with the same size tires Erik used on his 289, but BF Goodrich T/A's.
    Probably going with a Blueprint 302/TKX combo.
    Renee says white, maybe Wimbledon white with black stripes - or maybe no stripes.
    Jim Phoenix
  7. #5
    Oct 2020
    Albany, NY
    Quote Originally Posted by Jphoenix View Post
    Wow! That is bad. What did FFR have to say about that?
    Build 1 MK4 #10008 - Delivered 03/03/21, Graduated 7/20/22 - Sold 6/6/24 Build Thread #1 https://shorturl.at/K9fuy
    Build 2 MK4 #11061- Delivered 08/24/24 Build Thread #2 https://shorturl.at/OZowi
    Build 3 35 Pickup #329 - Delivered 10/28/25 Build Thread #3 https://shorturl.at/Ty4QQ
  8. #6
    Apr 2020
    Bonney Lake, WA
    I haven't asked them yet, I was going to just keep touching it up with white POR-15 (which is very durable) but seems everything I touch it just flakes off. It's a race car, so going to get abused quite a bit, not sure if I want to strip the entire frame and re-paint it at this point. Just kinda surprised, it appears others are not seeing the same issue with the normal powdercoat by FFR? I've always used POR-15 on my other race cars and it withstands the typical track rash very well, even better than the typical nickel plate on the formula car A-arms.
    Jim Phoenix
  9. #7
    Apr 2020
    Bonney Lake, WA
    Got started on the 289, completely cleaned and metal-prepped the frame, two coats POR-15, now installing the front suspension. The manual I was sent in an email is title the mMK4 base kit Assembly Manual Rev. J and it states to "Use the mount holes that are horizontal on the top of the 2”x 3” tube, not the side vertical ones.".
    The manual I received with the kit is rev. K - it states to "...use the mount holes on the side, not the top horizontal ones". So, K being most recent revision, that's what I did, but with the upper control arm mount arm in the side holes, and the short LCA's for the pin drive wheels, that gives me about 15 degrees of positive camber = not right. So, I moved the mount to the top horizontal holes and it looks better, almost zero camber, but I'm out of adjustment in the upper control arm, may have to shorten the adjustment links, but I'll see when I get it on the ground.
    So, if you're building a 289 with pin drive wheels, use Rev. J version of the manual for the upper control arms.
    Jim Phoenix
  10. Thanks tundra2050 thanked for this post
  11. #8
    Apr 2020
    Bonney Lake, WA
    Front suspension installed, FFR sent me three 350# springs and one 500# spring, so sent them a message. Looks like it's all going to work out OK, I used the pin drive template from Trigo to align the pins, then ran them down with the included hex drive. Found I needed to trim the wheel studs approx. .437" to allow the rotor, hub and pin drives to screw on with some room left for the hex nut wrench. After trimming, it's perfect.
    Should have engine parts from Forte and headers from Georgie next week so can proceed on the Coupe as well.
    Jim Phoenix
  12. Likes StangRacer liked this post
  13. #9
    Apr 2020
    Bonney Lake, WA
    Got the front brakes on and the axle installed. For a 3-link installation, it’s hard to beat the Moser, especially if you go with the shortened axle for pin drives. Effortless axle install.
    Jim Phoenix
  14. Likes StangRacer, Mike_T liked this post
  15. #10
    Apr 2020
    Bonney Lake, WA
    Power steering rack went in, it's a tight fit in the 289. I removed one of the hydraulic lines to let it slip in. The initial measurement of 53.063" is not applicable to the pin drives because of the shorter LCA's. I had to cut about an inch off the end of the tie rod threads to allow for the shorter span between tie-rod arms. Installed pedal box and steering gear and put the wheels on. Looks like a roller!
    Jim Phoenix
  16. #11
    Apr 2020
    Bonney Lake, WA
    Finished up the pedal box and accelerator pedal installation this morning, then put it on the ground for a quick alignment. Centered the rear axle with the panhard bar and checked the front caster. Minor adjustment gave me the 7 degrees recommended for power steering, then on to camber, dialed in half a degree negative, plenty of adjustment available. Finally adjusted the toe to an eight inch total in. Rolls nicely.
    Jim Phoenix
  17. Likes SteveWorth liked this post
  18. #12
    Apr 2020
    Bonney Lake, WA
    Working on cockpit aluminum now. Jumped the gun a bit and installed the handbrake. I fabricated a bracket to hold the right side handbrake cable away from the RH shock absorber. Engine arrives Tuesday, so I can start planning the wiring, brake reservoir location, fuel line plumbing etc.
    Jim Phoenix
  19. Likes StangRacer liked this post
  20. #13
    Apr 2020
    Bonney Lake, WA
    Reading the assembly manual, it says "drill, silicone and install the cockpit panel..." It doesn't say, remove the drilled panel and deburr all the holes I just drilled, both sides. So, that's what I'm doing drilling hundreds of holes, cleaning and deburring all the holes. Also, I decided to shoot solid AD rivets in the panels inside the engine compartment because I have easy access with a bucking bar. I'm using the blind rivets where I can't access the back side or the rivet goes into a tube.
    Some day, this will be done
    Tomorrow, the Blueprint 302 arrives from Summit. They ship fast.IMG_9106.jpgIMG_9111.jpgIMG_9108.jpg
    Jim Phoenix
  21. #14
    Jul 2023
    Jim,
    Your 289 build looks great! I’ve got the same 289 FIA setup as yours (pin-drive, 3-link, Moser etc.) and just wanted to say to check that the wheelbase is the same side to side. I had an issue where the Moser was not parallel to the front axles centerline due to how the Moser brackets were welded on (DS rear hub was about 1/2” further back than the PS). I had to use the Breeze adjustable LCAs to correct the misalignment. Other than that, no issues.
    Rich
  22. #15
    Apr 2020
    Bonney Lake, WA
    Quote Originally Posted by rpard508 View Post
    Jim,
    Rich
    Good point Rich, I'll check the wheelbase.
    Jim Phoenix
  23. #16
    Apr 2020
    Bonney Lake, WA
    I measured my wheelbase, exactly 90.25" both sides, so I got lucky!
    Jim Phoenix
  24. #17
    Apr 2020
    Bonney Lake, WA
    Finished the cockpit aluminum and still waiting for parts from Forte for the Coupe, so decided to rob the accessories off the 363 and install them on the 302 that arrived a couple of days ago. Struggled a bit with the spacers for the mount plates due to the reverse rotation water pump, but finally managed to find a serpentine belt that fits. I think next time (for the Coupe) I'm just ordering everything from Summit since they have good stock, anything I need and ship fast. Engine showed up within four days. Coupe has gone out back in the barn until I get the Cobra running.
    Jim Phoenix
  25. Likes StangRacer liked this post
  26. #18
    Apr 2020
    Bonney Lake, WA
    Flipped the 302 and installed a low-profile pan and dialed in the bell housing under the watchful eye of the garage supervisor. Then installed the SST midshift kit on the TKX and dropped the engine in. I'll have to move one of the tunnel braces an inch or so to clear the midshift position.
    Jim Phoenix
  27. Likes StangRacer liked this post
  28. #19
    Aliso Viejo, CA
    Looking good man. I'll be right behind you.
  29. Likes Jphoenix liked this post
  30. #20
    Apr 2020
    Bonney Lake, WA
    As shown previously, I moved the shifter to the mid shift position on the TKX. After installing the engine/transmission, the typical chassis brace interference issue arises, so I cut the brace out and repositioned it aft a couple of inches and now it's good. I really like the firm crisp shifts of this transmission.
    Jim Phoenix
  31. Likes RR20AC liked this post
  32. #21
    Apr 2020
    Bonney Lake, WA
    I started to run the hard fuel lines this morning and to determine the location of the fuel pressure regulator, I first needed to locate the heater/defroster unit. I printed the template, but it did not print accurately, so I used an airplane sheetmetal repair technique of using a piece of Lexan to find the hole locations on the heater and also the outline of the cutout for the blower.
    Then I located the Lexan template on the firewall, drilled the holes and cut out the rectangular blower hole. Not sure I like the little #6 sheetmetal screws that hold the blower motor to the heater core, seems kinda flimsy, so I will try to find a better way of fastening the two parts together.
    Now I can finish running the fuel supply and return lines and locate the regulator and inline filter.
    Jim Phoenix
  33. Likes StangRacer liked this post
  34. #22
    Apr 2020
    Bonney Lake, WA
    Side pipes are on, engine bay wired, dashboard wired up, need to locate and plumb the remote oil filter and some other minor items, then engine start, maybe early next week.
    Jim Phoenix
  35. #23
    Mar 2024
    born in San Jose, CA and lived mostly in Santa Cruz. Just married again in '22 and in Junction City.
    I got 300# springs for the rear, BUT should have been 400#. They new ones (and a FedEx label quickly)
    They sent two left-hand calipers for the rear (IRS), but just got the new replacement.
    Having 'fun' right now measuring the lateral runout on the discs. Started at rear and it's about 0.003" - 0.004" (generally a good spec number is about 0.002" TIR)
    Also had to increase the bore of this one disc so it would fit to the hub w/o "rocking" a bit. Took about 0.006" off the I.D. Fits nicely now.
    For the rear caliper alignment (the face of the 'puck' being parallel to the face of the disc surface), I'm looking at some additional shimming for how the caliper faces the plane of the disc surface so that pressure (when applied) is even.
  36. Likes Jphoenix liked this post
  37. #24
    Apr 2020
    Bonney Lake, WA
    Put the Cobra on the ground after removing the upper A arm links and shortening them per the manual dimensions. Adjusted the caster to get 7 to 8 degrees, no problem. Dialed in half degree of camber and adjusted the toe-in to about .200" total, then readjusted the camber and readjusted the toe until it all worked out. Still have 7+ degrees of caster, so I'm good with this quickie alignment.
    Poured in a bunch of fluids and primed the oil pump, got pressure up and the engine started right up. Sniper 2 working fine. Just had to adjust the engine idle and the fan on/off temps. Oil leaks on the oil filter remote mount, had to reseal the fittings going into the filter mount. Also forgot to tighten the power steering fittings on the rack, otherwise no leaks noted.
    Drove to the end of the driveway and back, all gears going in the correct direction, but alas no video.
    Caster
    Shortened measurement
    Comparison
    I have the 2 piece spindles and the Trigo pin drives, shortened LCA's, upper mounted in the horizontal holes. Also got the missing 500# spring from FFR and installed.
    Jim Phoenix
  38. #25
    Apr 2020
    Bonney Lake, WA
    Finishing up the aluminum.
    Jim Phoenix
  39. Likes FRM liked this post
  40. #26
    Apr 2020
    Bonney Lake, WA
    Worked on the interior while waiting for exhaust parts. Center console trimmed. thinking I may use some of the industrial velcro to fasten it in place instead of screws or rivets. My Formula Mazda uses 2" velcro to hold the radiator side pods on at the bottom - stuff is very strong. Electrical is all done, everything works, even the wipers park.
    Exhaust bits arrived in Fedex this morning so started fabricating it - not sure how it will all work once the body is on, but I can go back to side pipes if this doesn't pan out. Still thinking about best way to insulate the floorboards from the muffler heat. I have a layer of Thermo-Tec and another layer of heat reflective sheet on the bottom of the floor under the seat. Maybe wrap the muffler and pipes as well.
    Jim Phoenix
  41. #27
    Apr 2020
    Bonney Lake, WA
    Sorted the support bracketry for the muffler. Got a longer extension coming for the exhaust tip to get it out further, at least past the body line.
    The mufflers I'm using are Spin-Tec 3000, 4" thick, not as thin as the 7000 series, but more quiet as a result. Pretty sure I'll have 4" clearance when all done. The lowest part of the exhaust, the muffler, hangs about an inch below the bottom of the main frame tubes.
    I'm going to start on the right side, then paint and bolt it all up.
    Jim Phoenix
  42. Likes StangRacer, FRM liked this post
  43. #28
    Apr 2020
    Bonney Lake, WA
    Painted the exhaust, installed some aluminum-backed fiberglass insulation with wide head pop rivets and installed the exhaust. On the ground, I have 4.5” clearance to the lowest point of the exhaust. The frame rails are at 5” front and 5.5” at the rear. I may lower it more after I get the body on.
    Ran the engine and drove it for a while, no heat coming through the floor, so that’s working - so far. There is 3/8” air gap between the muffler and the insulation. The fiberglass mat is on top of a layer of Thermotec, and there’s the Dynamat on the inside of the floorboard.
    The Spin-tech 3000 mufflers are the quietest of the Spin-tech products (I think) but the exhaust is still pretty loud, not as loud as the side pipes and definitely a lower rumble as well, deep throaty sound.
    Jim Phoenix
  44. #29
    Apr 2024
    Potomac, MD - Near DC
    Cool exhaust idea. Will reduce, if not eliminate, leg burns. I already got a warning on that one. Not a burn, but those side pipes get very warm. Where's Bonney Lake? I lived in the Seattle area long ago. Still have family there. Love those mountains.
  45. Likes Jphoenix liked this post
  46. #30
    Apr 2020
    Bonney Lake, WA
    Quote Originally Posted by FRM View Post
    Bonney Lake is south of Seattle, directly east of Tacoma.
    I'm pleasantly surprised at how the layers of insulation keeps the heat off the floorboard - and surprised again that I have one seat mounting bolt buried under the muffler and all that insulation that I can't reach - not smart! I know what I'll be doing this morning
    Jim Phoenix
  47. #31
    Apr 2024
    I'll bet you have a spectacular view of Mt. Rainier on clear days. Bummer on the seat mounting bolt. I had several challenges where I decided the location of things only to find out later that I had to reconsider. I tried to drill as few holes in the frame that I found out I didn't need later. Live and learn.
  48. #32
    Apr 2020
    Bonney Lake, WA
    Yes, Rainier is only 18 miles away as the crow flies. Today is another nice fall day and I got the body out of the barn, going to get ready for first fit try - probably take a few iterations to get everything trimmed.
    I presume I need to fit the body without the seats installed? Seems like they will be in the way of fitting the rear bulkhead?
    Jim Phoenix
  49. #33
    Apr 2020
    Bonney Lake, WA
    Yeah, I learned not to pre-drill rivet holes in the aluminum until I verified I could get a drill and rivet gun in that location, only had to learn that lesson three times.
    Jim Phoenix
  50. #34
    Apr 2024
    I didn't bolt the seats down until near the end. I left them in loose and they seemed to collect all kinds of dust and metal shavings and fiberglass shavings but I had the basic low back seats and I don't think they would impact fitting the body. My body when it went on was slightly in back of the rear bulkhead and shoving and pushing moved it forward into place.
  51. Likes Jphoenix liked this post
  52. #35
    Apr 2020
    Bonney Lake, WA
    Yes, I plan to leave them out until all the grinding and sanding is done. I've read that we typically must trim firewall, the rear bulkhead, both rear trunk sidewalls and the trunk floor flange - was that your experience as well? Did you leave the dash in? I may remove mine anyhow because I don't like the FFR padding, I'll likely change to a very thin padding and leather-like vinyl.
    Jim Phoenix
  53. #36
    Apr 2024
    I did not trim the firewall and I left the dash in. I trimmed quite a bit from the rear trunk sidewalls and put bulb seal on those, but not across the back cockpit bulkhead. No bulb seal on the rear bulkhead. I also trimmed the rear most trunk floor flange, probably more than I should have, but that was a sticking point for getting the body to settle down. I also had to trim off fiberglass around the fuel tank. For my dash I did not use the FFR supplied padded stuff, but rather this vinyl product https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1. top to bottom it fit well and was just a small bit short left to right, but that part ends up being bent back and tucked out of sight. I had all my gauges in place and wired before the body went on too.
  54. #37
    Apr 2020
    Bonney Lake, WA
    Good info, thanks. I like that vinyl.
    Jim Phoenix
  55. #38
    Apr 2020
    Bonney Lake, WA
    Dropped the body on today. Fits pretty good, have the typical trimming and adjustments.
    Jim Phoenix
  56. #39
    Apr 2020
    Bonney Lake, WA
    The manual shows a front body mounting bracket that goes from the frame mount to the turn signal cutout. I don’t have that bracket - is it used on the 289?
    Jim Phoenix
  57. #40
    Dec 2021
    Flagstaff, AZ
    Jim
    The mounts shown in the manual I did not find in my kit either but there is a cross brace shown in the 289 supplement that goes below the radiator to the body.
