23
522
Originally Posted by
Just 1 More
ANy tips on mounting the McQueen rear fenders to the body?
When I installed mine back in 2009, I had an upholstery shop make up some piping for in between the fender and the body. We then spray painted it to match the body color.
You can see it here in this image just below the pin stripe. It helps to keep crud from building up between the two pieces and is much like what was used for decades back in the "olden days" and on British sports cars through the '70s.
Hope this helps,
Tom
