Thanks Thanks:  48
Likes Likes:  178
Page 21 of 25 FirstFirst ... 111920212223 ... LastLast
Results 801 to 840 of 965
Thread: Making progress on my build...
  1. #801
    Indiana
    Well, my exhaust tips have to exit centrally, I have dual rear trunks with access where the original exhaust exits.
    Any ideas to improve the appearance of the rear fascia with the revised exhaust tip locations? I'll have the spoiler installed as well...
    GTM #304 LPE 525hp LS3
  2. #802
    Indiana
    Had to order some new 3"ss tubing, the Amazon stuff was junk. Getting it tacked together then off to someone who can do prettier welds than I can.
    I don't like how much stress is on the rear body/fiberglass where it mounts to the gearbox subframe so I 8115'd a piece of unused hood to double the thickness. This guy on eBay accepted my $45 offer, cheapest I've seen it. Ordered some more, anticipating more 'bonding' time with the GTM...
    https://www.ebay.com/itm/225585734410
  3. Likes VRaptor SpeedWorks, LLC liked this post
  4. #803
    Indiana
    Shoulder surgery has laid me up, so nothing getting done that requires any significant physical effort.
    Finishing up the headlight buckets, a few revisions for the internal feature that will support the DRL/turn signal LED strip. Each revision improving positioning of the LED strip with regards to visibility from the front as well as positioning relative to the Lexan lens and overlying bodywork. Also avoiding the beam of the projector headlight which requires more effort and packaging creativity. Latest revision on the printer now, only printing enough to index the lens, to speed up the print.
  5. #804
    Jul 2014
    One thing to keep in mind is the flexibility of the LED strips you plan on using for the DRL/Turn Signals. The ones I chose from The Retrofit Source are flexible in one axis (the surface you would stick them to, but not flexible at all trying to bend left to right. Looks like you are putting a bit of a twist on the surface for them, if I'm looking at it correctly.
    Pretty awesome being able to design, print, and iterate on the design until you get it just right. I love my printer.
  6. Thanks beeman thanked for this post
  7. #805
    Indiana
    You are correct, I have confirmed the flexibility of the LED strip in that plane. It may be hard to visualize in the 2D images, the strip will only curve in 1 plane. The iteration (3.0) that is printing now has even more curvature than the previous 2, to better match the contour of the adjacent bodywork. I went with a longer LED strip which has required some massaging to fit, to be clear of the bodywork, and to avoid the projector headlight beam.
  8. #806
    Very cool! I'm going to have to look into investing in a printer down the road here someday......love the possibilities!
    Shane Vacek
    www.vraptorspeedworks.com
  9. Likes rolfer liked this post
  10. #807
    Jul 2014
    Quote Originally Posted by beeman View Post
    Very nice!!!!
    Quote Originally Posted by VRaptor SpeedWorks, LLC View Post
    You totally need a printer Shane. Go look at the air hose that passes through the front wheel wheels on my GTM. I didn't want some cheezy install of zip-tying the air hoses to the A-Arm, so I designed and 3D printed two separate pieces that when assembled and epoxied together would hold the 90 deg air fittings, allow me to rivet them in place, and be the passthrough in the wheel wells. Then the carbon fiber button plate on the tunnel wall on the drivers side was designed and printed in several configurations before I sent the final design to a guy to cut it out of expensive carbon fiber. Possibilities are endless.
  11. Likes VRaptor SpeedWorks, LLC liked this post
  12. #808
    Indiana
  13. #809
    Those turned out nice!!
    Shane Vacek
  14. #810
    Indiana
    Thanks, I think they will work well. I still need to do some post-processing/ smoothing of the ABS to make them look less "printed", but I'm very happy with how they turned out.
  15. Likes VRaptor SpeedWorks, LLC liked this post
  16. #811
    Feb 2019
    Houston, TX
    ABS can be smoothed in an acetone vapor chamber. It's harder to print than PLA/PETG but easier to smooth.
  17. Likes VRaptor SpeedWorks, LLC liked this post
  18. #812
    Indiana
    Post
    I actually found a local shop that can pull moulds and make my new hood and front fascia, less than 10 miles from my home.
    Getting the driver's side matched to the passenger side. Gotta love cutting out previously completed work, but that's happened before on this build.
    1st step was recreating the exact position and angle of the driver's side headlight. Lots of measurements, pencil marks, paper template, etc. Tried weatherstrip instead of clay to create the edge of the new bodywork, first layer of mud done.
    20240216_144447_copy_1280x591.jpg20240216_154024_copy_1280x591.jpg20240217_113137_copy_1280x591.jpg20240217_120507_copy_1280x591.jpg20240217_121605_copy_1280x591.jpg
  19. #813
    Dublin, OH
    dave, do you have a CAD design of what you envision your front to look like?
  20. #814
    Indiana
    The last rendering I did still had the modified Yamaha R1 headlights, these headlights were designed to fit the shape of the front of the car and help address some aerodynamic issues and design issues. I wish I had a 3D scanner though...
  21. #815
    Feb 2019
    Houston, TX
    If you have an oculus, you can use gravity sketch to trace out what you have, then sculpt in the changes you want. That’s how I modeled my 818 nose.
  22. Likes beeman liked this post
  23. #816
    Indiana
    Front of the hood essentially done, final skims/sanding.
    Finishing up the last corner of the hood. Lots of measurements from midline and A-pillars, poster board template. Fiberglass shop owner is ready to receive the hood to make a mould then a part as soon as I get it done.
  24. #817
    San Diego
    Wow. Exciting. Can't wait to see a finished product.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
  25. Thanks beeman thanked for this post
  26. #818
    Indiana
    Thanks, Mike!
    So the plan was to trailer the whole car to the fiberglass shop, this would prevent distortion of the hood that could occur with removal. Instead, I decided to build a frame on the outside of the hood to get it off the vehicle, now I'll build an inner frame to allow for removal of the outer frame. Then off to the fiberglass shop.
    It's been so long since I've seen under the front hood...
  27. Likes VRaptor SpeedWorks, LLC liked this post
  28. #819
    Jul 2014
    This will be a major step for your GTM!!!!
  29. #820
    Indiana
    No kidding, Sean, need to get this thing done. Too many side projects...
  30. #821
    Wow....tons of work and time involved there! Can't wait to see the final result!
    Shane Vacek
  31. #822
    Indiana
    Sometimes you just need to admit defeat and leave it to the pros. Hood might be done next week. They are still blocking it, seems I missed a couple low areas, imagine that.
  32. #823
    Cool! Not many people understand the amount of time and effort that goes into projects like that.
    Shane Vacek
  33. #824
    Indiana
    Got the hood back from the fiberglass shop. Really happy with how the part turned out, nice mould too. Gray buck, orange gel coat mould, black part. Life is busier than ever, need to make time for the GTM.
  34. #825
    Jul 2014
    Now that's impressive!!!
  35. #826
    Indiana
    Been trying to figure out how to tie the leading edge of the roof into the roll hoop behind the targa roof so it doesn't lift at speed. Wanted to keep the rear body removable so bonding it on was not an option. Bolting it on leaves unsightly bolt heads on the roof bodywork. But had to be bolted on, and I didn't trust bonding a bracket to the underside of the roof fiberglass due to the anticipated speeds this car will see. So vortex generators to the rescue. Fabbed up with m8 bolts, replace with low profile button heads, hide under the vortex generators. I did bond squares of fiberglass at the bolt sites to reinforce those areas. Now roof is flush with the targa roof weatherstrip.
  36. Likes VRaptor SpeedWorks, LLC liked this post
  37. #827
    Indiana
    With roof secure, the rear bodywork has found its "forever home". So need to finish up the rear. I never cared for the drop lip on the rear of the Gen 1 hatch, wanted a flush rear. So cut off the rear of the hatch and bonded it to the body. Will make a weatherstrip flange to allow the rear of the hatch to seal.
  38. Likes VRaptor SpeedWorks, LLC liked this post
  39. #828
    Indiana
    Now time to finish the exhaust. Center exit to allow for the rear L/R trunks. Note the easy trunk access. Measured the dual tip oval for a template, cut the oval template to allow cutting the two tiers of the rear bodywork. Final mockup of the Kooks dual exhaust. Love it. Mufflers will be perfectly parallel, not slightly diverging like in the pic.
  40. #829
    Indiana
    All ready to tack. Wait, why is the left Kooks muffler factory weld 1/16" behind the right side one when the exhaust tips are lined up? Pulled everything apart and took another 1/16" off the offending side... Always something...
    Turns out that the weld on the Kooks muffler isn't as accurate as I had hoped. I wanted the Kooks emblem facing up but will have to rotate them instead, so the welds line up when looking into the engine bay...
  41. Likes VRaptor SpeedWorks, LLC liked this post
  42. #830
    Looks like you're making good progress! I had to do a similar mod to the rear lip of the hatch on a GTM here.....the whole rear lip was so crooked that I just couldn't figure out a way to use it as-is, so ended up cutting just the bottom portion off and bonding it to the body. Much cleaner look than the original design IMO.....as is yours. Yours is the way FFR should have done it from the start. Clean look and you can still access everything at the rear of the engine bay, unlike the Gen II hatch.
    Shane Vacek
  43. Likes beeman liked this post
  44. #831
    Indiana
    Finishing up wiring/re-wiring the car, 90% done and much happier with the logistics of the wiring than what I had done previously. Have done a couple of other builds and gained some knowledge...
    Exhaust finalized and tacked up, ready to go to a good TIG welder. The rear support is a single SS rod which is welded to the rear of the resonators, drops down into a thick rubber grommet that sits on the gearbox subframe. Simple, light, robust, and allows movement.
    20240801_172923.jpg20240801_172912.jpg20240801_174729.jpg20240801_174745.jpg20240801_182914.jpg
  45. #832
    Jan 2024
    That looks great Dave! I like seeing your non-traditional build ideas.
    Sal Mennella
    Type 65 Daytona Coupe #692 - in progress!
    GTM #30 - sold
    Roadster #5132 - sold
  46. Thanks beeman thanked for this post
  47. #833
    Indiana
    Finishing up the under hood components so I can get cracking on the body work. Non-traditional wiper setup, single Honda S2000 wiper mount, Toyota Celica wiper arm, Jeep Wrangler wiper motor. The metal mounts on the wiper motor are the perfect size to tap to M8 X 1.25 for custom mounting . Wiper motor found itself in an odd location so that I can store the target top in the frunk. New tool in the shop, this finger sander makes short work of removing powder coat for welding. I should have bought one years ago. Highly recommended and inexpensive.
  48. #834
    Indiana
    A few minor adjustments then it will be perfect
  49. Likes VRaptor SpeedWorks, LLC liked this post
  50. #835
    Quite an assortment of parts there! Looks like it should work nicely!
    Shane Vacek
  51. Thanks beeman thanked for this post
  52. #836
    Indiana
    Center air intake delete. Didn't realize that vinylester bonds pretty aggressively to plexiglass, was fun pulling that off after glassing. Next time I use a plexiglass dam/mould, I'll add masking tape.
    Picked up a hobby mill for the shop. Only weighs about 1000 lbs with the base.
    20240907_104234.jpg20240904_175123.jpg20240904_161601.jpg20240903_195353.jpg20240903_194209.jpg
  53. Likes VRaptor SpeedWorks, LLC liked this post
  54. #837
    Jul 2014
    Ohhhh nice, it's like a mini bridgeport!!!
  55. Likes beeman liked this post
  56. #838
    San Diego
    I use a sheet of wax paper. No seam lines on parts like the size you have there and much quicker to set up and remove when compared to masking tape.
    www.myraceshop.com
    GTM solution kits
  57. Likes beeman liked this post
  58. #839
    Indiana
    Hood permanently mounted and functional. Now addressing the original side GTM body work, other than the door panel, that is currently free floating. Making brackets to tie the side body work into the main chassis taking care to line up perfectly at the gaps. Each body mount will have triangulation for strength at speed. A bit tedious but one step closer.
  59. Likes Jkviper, VRaptor SpeedWorks, LLC liked this post
  60. #840
    San Diego
    Hey, you're making progress. Sometimes it seems like things take awhile(and they do) but if you commit to just keep working on it, things will get checked off the list.
    Just an aside as to how I did things in those lower fender areas. I extended the floor sheet metal out to the bottom of the fenders on all four corners in order to give them some rigidity. They won't move much at all in the vertical direction, so you just need to stop horizontal movement at the lower lip of the fenders. Sheet aluminum has worked well for me in this application.
    www.myraceshop.com
    GTM solution kits
  61. Thanks beeman thanked for this post
