25th Anniversary #9772
Hey Todd. I don't think you can really get any meaningful measurements with the car up on jack stands. It needs to be sitting on level ground to get usable alignment measurements.
MkIV Roadster build: Gen 2 Coyote, IRS, TKO600. Ordered 10/24/18. Delivered 1/29/19. Engine installed 8/8/21. First start 9/12/21. First go-kart 9/17/21. Off to paint 4/11/22. Back from paint 12/30/22.
Build thread here.
yeah, also playing with ride height as well - really wishing I had a lift right about now
in my haste to reply I forgot to mention that, but you are correct that you do need to have ride height set as well before working on a alignment.
Build thread here.
Measurements are useful (maybe...) to get you in the ballpark. But you need actual alignment gauges to get the rear camber angle and toe. And yes they interact. And as already stated, at ride height and sitting on the ground. Roll it back and forth each time you make any adjustments. The IRS is not easy to align mainly because it's hard to reach the adjusters. A bit easier with the body off. But you'll need to check the ride height again when it's all together. If you get it back to the same spot, the alignment should be OK. If you don't have the right tools, you're better off taking it to a shop. They do put it on a lift and can reach the adjusters from underneath. Good luck.
Build Thread and
Video.
Build Thread.
Build 5: 35 Hot Rod Truck #138.
Build Thread. Sold 11/9/2023.
Build 6: Mk5 Roadster 30th Anniversary #11,258.
Build Thread.
as expected the toe arm was about 1/2" short - looks much better now!!!
Thanks guys!
FYI rear camber can be adjusted w/o taking anything apart.
The red arrow is the adjuster. The 2 green arrows are jam nuts. The adjuster has left hand threads inside and right hand threads outside. (or vice versa) If you loosen both jam nuts, you can turn the adjuster which will change the overall length of the UCA.
