Thanks Thanks:  11
Likes Likes:  232
Page 5 of 7 FirstFirst ... 34567 LastLast
Results 161 to 200 of 257
Thread: # 1115 resurrection
  1. #161
    Sep 2022
    Huntington, IN
    The Felpro gaskets didn't have enough meat on them to cover the top of the head ports so had to make a parts run and found some Cometic printoseal that fit perfect. Thread sealant on every bolt, silicone around the water ports and on the front and rear lip seals. Torqued down and walk away.. don't touch it, walk away.. just walk away
  2. #162
    Sep 2022
    Huntington, IN
    She's all back together and running great. No leaks as of yet.
    https://youtu.be/oXPF5lxgv1w
  3. Likes Ltfracing liked this post
  4. #163
    Jul 2020
    Spencer, MA
    Good to hear.
  5. #164
    Sep 2022
    Huntington, IN
    2 steps forward, 3 steps back.. how many times did you guys install and remove everything? Pulled the engine/trans last night so I can permanently install the trans tunnel and figure out what i'm going to do with the firewall, Paint or Polish, what to do ?????
  6. #165
    Jun 2018
    North Vancouver, BC, Canada
    How many times? I'll let you know when I stop.... I don't think it ever stops, it just slows down....
    Gen 1 '33 Hot Rod #1104
  7. Likes Just 1 More liked this post
  8. #166
    Sep 2022
    Huntington, IN
    Got the QA1's installed, Did my headlight wires a little different. Stole the idea from JimLev.
    20231024_193059.jpg20231026_201434.jpg20231021_193243.jpg20231021_123923.jpg20231013_191412.jpg
  9. Likes JimLev liked this post
  10. #167
    Sep 2022
    Huntington, IN
    Today was the day for the firewall insulation. The FFR kit comes with dynamat and foam, I just got foam so I bought a box of Second Skin Damplifier Pro sound matting. I Removed the A/C unit and cut my Second Skin Damplifier Pro to fit all the shapes then put the FFR foam on top of that and then reinstalled the A/C unit, hopefully for the last time.
    Also cut to fit the Second Skin Megablock heat insulator for the trans tunnel. Installed the gas pedal. All little things but things to now check off the list.
  11. #168
    Sep 2022
    Huntington, IN
    I decided to try for a mirror finish on the firewall.. That's a lot of hand polishing but I think i'm close
  12. Likes TxMike64, Ltfracing liked this post
  13. #169
    Consummate Learner
    Kingsland, TX
    Quote Originally Posted by Just 1 More View Post
    I just ordered the same Milwaukee rivet tool. How to you like it and how does it handle the 3/16" firewall rivets?
  14. #170
    Sep 2022
    Huntington, IN
    Handles the rivets effortlessly and has been pretty handy for holding a washer or P clamp on the back side of the rivet and just pulling the trigger, however, mine does not like to cycle the stem all the way back to the catch can.. mine kicks the stems back out the front which can be a little frustrating but not the end of the world.
  15. Likes TxMike64 liked this post
  16. #171
    Sep 2022
    Huntington, IN
    Welded the flanges on the Borlas tonight, maybe get the exhaust finished this weekend.
  17. Likes Ltfracing liked this post
  18. #172
    Sep 2022
    Huntington, IN
    DEI Form a shield
  19. Likes JimLev liked this post
  20. #173
    Sep 2022
    Huntington, IN
    Since i've decided to use a B&M Quick Silver shifter, I didn't need to use the trans mounted set up. So I cut the trans tunnel top mid piece to fit, settled on a shifter location, rivnuts in fiberglass seemed ok but I added some reinforcement to the back side anyway. I'll build a console to encompass the shifter with cup holders behind and a 7" or bigger radio screen in front.
  21. Likes Ltfracing liked this post
  22. #174
    Sep 2022
    Huntington, IN
    Added a panel to hold a bus bar and the vintage air relays and circuit breaker. Added a stud for a common ground. Hooked up the battery and no sparks and no smoke so that's a relief. I clicked on the electric steering and played with the min vs max control and it's a huge difference, I like it. I need to wire in the speed sensor so it can do it's thing automatically. I'm not sure if i'm going to integrate the controller in to the dash or do an under dash mount so it's just temporarily riveted in place.
  23. #175
    Sep 2022
    Huntington, IN
    Bled the masters, got all the air bubbles out
  24. #176
    Sep 2022
    Huntington, IN
    Started my thoughts on the center console, I like where this is headed. Lot's of room for refinements but so far, I like it.
  25. Likes RoadRacer, Mastertech5, Ltfracing liked this post
  26. #177
    Sep 2022
    Huntington, IN
    Got the body back on today, makes for some good inspiration to keep moving forward
  27. Likes Ltfracing, RoadRacer liked this post
  28. #178
    Sep 2022
    Huntington, IN
    Tucking the battery in the lower passenger side trunk area
  29. Likes Ltfracing, TxMike64 liked this post
  30. #179
    Sep 2022
    Huntington, IN
    WHile it's cold in the garage, I can still do some little things in the house. Got the hood hinge brackets back from powdercoat
  31. #180
    Sep 2022
    Huntington, IN
    Did the firewall bolts last night.. man it's stressful knowing you only get one chance to get it right. I made a little spacer gauge to insure I got each hole exactly the same height.
  32. Likes Ltfracing, RoadRacer, TxMike64 liked this post
  33. #181
    Aug 2022
    Looks awesome
    33 hot rod,383 sbc tri power setup ,700 r4 transmission,gen1 body gen2 chassis
  34. #182
    Sep 2022
    Huntington, IN
    Quote Originally Posted by Ltfracing View Post
    Looks awesome
    Thank you, That little gauge tool made it a lot easier than trying to measure each one
  35. #183
    Sep 2022
    Huntington, IN
    Finally got the swaybar from Innovative rodding. Took a few minutes to polish the arms. I'll get it installed this weekend and start getting the frontend completed.
  36. Likes RoadRacer liked this post
  37. #184
    Nice, didnt think they were doing anything any more
  38. #185
    Sep 2022
    Huntington, IN
    Quote Originally Posted by RoadRacer View Post
    He really isn't, I caught him on a good day and he agreed to do one for me.. it wasn't cheap and took almost 10 weeks
  39. Likes RoadRacer liked this post
  40. #186
    Sep 2022
    Huntington, IN
    I got things put back together last night to the point of being able to fire it up again.. so good to be making progress. This is with the Borla Pro XS mufflers
    https://youtu.be/37ee2qb-mzM?si=OvyqCBN9Vhf82gMJ
  41. #187
    Sep 2022
    Huntington, IN
    First of the little gremlins starting to show themselves.. found a micro split in the aluminum tubing in the flare. Had to cut and re-flare it with new fitting and sleeve. Better to find it now than when the body is on complete
  42. Likes Ltfracing, Mastertech5 liked this post
  43. #188
    Sep 2022
    Huntington, IN
    Another Gremlin.. a little brake fluid leak at the rear "T" hose. Pass side fitting wouldn't seal. Took it apart and it looks like someone tried to single flare it and they REALLY SUCKED! Good thing I have a double flare tool.
  44. Likes JimLev liked this post
  45. #189
    Placitas, NM
    With flares like that you may want to check all of them.
  46. Likes Mastertech5 liked this post
  47. #190
    Sep 2022
    Huntington, IN
    Good point... I was just looking at the leaky one.
  48. #191
    Jun 2020
    SoDak
    What I've experienced over the years with bad flares is once you fix one, the next in line will leak, then the next, then the next, it's like dominos.
    Probably because as you resolve one and get it sealed, then the line pressure increases and finds another weak spot to escape.
    Jim
  49. Likes Just 1 More liked this post
  50. #192
    Jul 2020
    Spencer, MA
    Weakest link syndrome.
  51. Likes Just 1 More liked this post
  52. #193
    Sep 2022
    Huntington, IN
    Gettig the dash panel finished up. Cut the holes for the A/C vents and Vintage Air control panel. Always scarey making those cuts because once you cut, you're committed. Playing with colors for the body and figured the dash was good place to try it and see if it's the color I want. It's a factory color called Toreador Red Metallic. The garage lighting is different from the outdoors natural lighting but it gives a good idea of the color.
  53. #194
    Sep 2022
    Huntington, IN
    Reached that milestone we all work so hard to get to...
    https://youtu.be/Ej6cv83RG3c?si=hACxXC3ar2IX_AL-
  54. #195
    Sep 2022
    Huntington, IN
    Schott Accelerators
    Nitto 555 G2's
    18x9 275/40-18
    20x11 315/35-20
  55. Likes RoadRacer, JimLev, Guy G, Mastertech5 liked this post
  56. #196
    Sep 2022
    Huntington, IN
    It was One man door wrastlin today. After a few hours, I got one hung, hinged, opens, closes, doesn't hit the body anywhere and it latches.. that's the most important thing.. latching closed. Duct tape and rubber hoses took the place of a helper for setting gaps.
    Still needs tweeking but that's for another day.
  57. Likes Ltfracing liked this post
  58. #197
    Oct 2023
    Merrimack, NH
    Hey there
    Just started following your posts
    Great stuff so far!
    Started mine about 45 days ago. Picking up some ideas from yours.
    I ended up powder coating my firewall. Thought about polishing it, but I figured it would be a pain keeping up on it once the engine went in.
    About ready to pull the trigger on a Skip White 383. Can’t wait for that fun to start.
    Thanks for the updates.
    Looks real good!
  59. Likes Ltfracing, Just 1 More liked this post
  60. #198
    Sep 2022
    Huntington, IN
    Quote Originally Posted by Guy G View Post
    Great stuff so far!
    Looks real good!
    Yeah, not sure how the polished firewall is going to hold up. the new tires are definitely gravel kickers. My 383 came with the build but I had it re-built at NYE's racing engines. 401hp 437tq. What's your Skip White HP numbers?
  61. #199
    Sep 2022
    Huntington, IN
    driver door bolted up and functional
  62. Likes Ltfracing, Mastertech5 liked this post
  63. #200
    Sep 2022
    Huntington, IN
  64. Likes Ltfracing, Mastertech5 liked this post
