Thanks Thanks:  9
Likes Likes:  61
Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 147
Thread: Restoration/upgrades of FFR3490, MK2 built in 2002.
    Jan 2022
    Seven Hills, OH
    AC Cobra pedals installed. Here is my how to:
    https://youtu.be/LtMVh14eKg8?si=UCkqjJArhibT4NA0
    FFR3490 - MK2 Roadster: Yellow with black stripes, mildly built 5.0 with many upgrades/updates to come.
    See my build here: https://youtube.com/playlist?list=PL...6mVHNS3FsRV76S
  2. Likes jrcuz liked this post
  3. #82
    Jan 2022
    Seven Hills, OH
    Adding defrost vents and more prep for final dash install.
    https://youtu.be/Q66AHhBVSG4?si=igZextf6t4-DEXBx
  4. #83
    Jan 2022
    Seven Hills, OH
    Almost time to put the dash in. Defrost is done, last bits of wiring done, and more cutting/adding clearance with the frame/body.
    https://youtu.be/2BkpXYod_N8?si=T7uZbgFOeUJWmaeK
  5. #84
    Jan 2022
    Seven Hills, OH
    I thought I would have the dash in today. Last minute change for safety/reliability changed that.
    https://youtu.be/HiqUAzKL98s?si=iEgR0q6ZEGHuUAvW
  6. #85
    Jan 2022
    Seven Hills, OH
  7. #86
    Jan 2022
    Seven Hills, OH
    A little setback in getting my car back together.
    https://youtu.be/Wb-O5flIVt0?si=h4Pe-Rku4qNnPhVT
  8. #87
    Jan 2022
    Seven Hills, OH
    Back on track after my setback. Things are coming together.
    https://youtu.be/sB8y5_Snhck?si=uQlpnbBQnuMfUHlD
  9. Likes jrcuz liked this post
  10. #88
    Jan 2022
    Seven Hills, OH
    Finally done with wiring, but now have a new fitment issue with the custom dash.
    https://youtu.be/Tk7izsm3GkM?si=O0v0JrzvbyN47GKP
  11. Likes jrcuz liked this post
  12. #89
    Jan 2022
    Seven Hills, OH
    Finally done with the custom S/C dash install.
    https://youtu.be/6Dp9rbdKLdg?si=gMQtzO-nqEq674qD
  13. #90
    Jan 2022
    Seven Hills, OH
    Took the time to customize the Factory Five dash brace and make it look like a real Cobra. Very happy with the results. Here is what I did.
    https://youtu.be/dS7kNKtj8v0?si=wRsBzUMLlACwIUJC
  14. #91
    Jan 2022
    Seven Hills, OH
    Now that the interior work is done it’s time to tear down the engine and save some weight while gaining some performance by installing new heads.
    https://youtu.be/-Dkju9Gx1Bg?si=Jd5goMglJTskKLR0
  15. Likes jrcuz liked this post
  16. #92
    Jan 2022
    Seven Hills, OH
    Update on the Cobra, starting the prep and cleanup for my new heads that are going in. Full walkthrough of parts being used as well as the weight savings.
    https://youtu.be/3X2azFYSOo0?si=o6-1BV2bdmITfeKw
  17. #93
    Jan 2022
    Seven Hills, OH
    Overview of all of the required prep before installing the new Trick Flow heads.
    https://youtu.be/1uHN2ySR8LU?si=y9AsaRNRRCoOzPBn
  18. Thanks jrcuz thanked for this post
  19. #94
    Jan 2022
    Seven Hills, OH
    The heads are on! More progress on my Cobra.
    https://youtu.be/jT9FzTexRqU?si=yjK5kzkNc8g6mQTL
  20. Thanks jrcuz thanked for this post
  21. #95
    Jan 2022
    Seven Hills, OH
    More ground made, full valvetrain install with lash setup procedures and installed the intake manifold.
    https://youtu.be/szBe5ceOpbk?si=TkyrSq6g3PONOaUB
  22. Thanks jrcuz thanked for this post
  23. #96
    Jan 2022
    Seven Hills, OH
    More ground made on getting the engine back together. That much closer to the first fire with all the upgrades.
    https://youtu.be/hqtFkDn9Kp8?si=fkETvJOcK8LKlRw6
  24. #97
    Jan 2022
    Seven Hills, OH
    Making up more ground with getting this back together. I’d say 1st start is only a week or 2 away. Getting close!
    https://youtu.be/mxYGzfyojg0?si=UDhEeKzYFfqQeWl2
  25. #98
    Jan 2022
    Seven Hills, OH
    The engine assembly is finally done. Next up, first start after I set up the Edelbrock Pro Flo 4 ECU.
    https://youtu.be/eKrdryaEIk8?si=KwFdCjTMtFfsJOO_
  26. #99
    Jan 2022
    Seven Hills, OH
    After well over a year, my Cobra is finally running again after significant re-work.
    https://youtu.be/TcWRJGWxUuQ?si=aY33wzm8Sy71dUCn
  27. #100
    Jan 2022
    Seven Hills, OH
    Time to get things ready to drive this car. Fixed the tune to get it running better and working on making it road-worthy.
    https://youtu.be/IKGpPlTsafE?si=1mBtXIrFrkYA9_Gm
  28. Likes jrcuz liked this post
  29. #101
    Jan 2022
    Seven Hills, OH
    She’s back on the road! Wrapped up the last few things then took it for a test drive included in this video.
    https://youtu.be/NeQ93JklQQk?si=xkgWkhhjPv2ZLsBb
  30. Likes jrcuz liked this post
  31. #102
    Jan 2022
    Seven Hills, OH
    After about 100 miles of break in driving, I had a part failure. Fixed the problem and started some new upgrades.
    https://youtu.be/A7tsOe525Qo?si=vmWyW3SWBX_Z3yA9
  32. #103
    Jan 2022
    Seven Hills, OH
    Starting to be able to really enjoy the car now. New tires, more car shows, and continuing with cleaning things up.
    https://youtu.be/f70vFhkRL-s?si=l0sWiBjPJrX7YnSe
  33. #104
    Jan 2022
    Seven Hills, OH
    More work on the Cobra. Sunvisors, engine bay cleanup, and some show pics.
    https://youtu.be/V0NT2hwReco?si=h6R62QgeTeGXabMF
  34. #105
    Jan 2022
    Seven Hills, OH
    Long overdue update on my MK2 Cobra. Small issues/problems that have popped up and working on tuning the Edelbrock ProFlow 4 EFI.
    https://youtu.be/vuEHCYO5ux8?si=KN502ZoDyt8Oxye2
  35. #106
    Jan 2022
    Seven Hills, OH
    Went to a show and won a trophy.
    https://youtu.be/11dJLSGMa_M
  36. #107
    Jan 2022
    Seven Hills, OH
    End of season updates on the Cobra and upgrade plans for the off season.
    https://youtu.be/xMWD86S0U7o?si=jWMqAA5d_SM0ZXrC
  37. #108
    Jan 2022
    Seven Hills, OH
    Finally time to tackle the suspension updates. Starting in the rear with coilovers and aluminum control arms.
    https://youtu.be/Y9CcTZXT4r0?si=7RoEEXLWxC-u1Zcq
  38. #109
    Sep 2021
    Emmaus, PA
    Hey, just started working through your videos. Great stuff so far!
    I find this type of work really interesting. I’m currently resurrecting a partially started or partially finished or partially built Mk3. Whatever the case, I basically ripped apart and rebuilt it.
    Thanks for documenting your progress.
  39. #110
    Jan 2022
    Seven Hills, OH
    Quote Originally Posted by TTimmy View Post
    Thanks for watching. I'm definitely glad I decided to save one that needed a lot of work, but it's definitely a big project. When I an done it will have had pretty much every system gone through and re-done.
  40. #111
    Jan 2022
    Seven Hills, OH
    Back to work on the Cobra. Replaced the lower arms with Steeda aluminum arms and started the coil over install including adjusting the Koni reds.
    https://youtu.be/SrJWBgsspr4?si=6IHrHkcnz8sfs8Ci
  41. #112
    Jan 2022
    Seven Hills, OH
    More progress made on the rear suspension, and a few more issues popped up in the process.
    https://youtu.be/MlFyHamOYA8?si=xM6mehhdCtnAUHOX
  42. #113
    Jan 2022
    Seven Hills, OH
    I installed the Marlin Enterprises flag kit on my car. If you have a 2” roll bar, you need to make some adjustments to the kit.
    https://youtu.be/AmzzrmxgBus?si=vKXCp5Nz5UC6N5z0
  43. #114
    Jan 2022
    Seven Hills, OH
    Tried to finish up the rear suspension upgrades and things have escalated. Now I’m rebuilding the rear end.
    https://youtu.be/1R723FCWSoc?si=m1ko0O5y7BSTpdUo
  44. #115
    Jan 2022
    Seven Hills, OH
    Back to work. Time to pull the transmission while waiting on the rear end rebuild parts.
    https://youtu.be/XMJ-VDXIRdI?si=cub4a8811j3vXFGE
  45. #116
    Jan 2022
    Seven Hills, OH
    How to rebuild the Ford 8.8 trak loc differential while still in the car.
    https://youtu.be/l7zTuAWNKbM?si=bUvj-yg7yATgzmiL
  46. #117
    Jan 2022
    Seven Hills, OH
    I figured it out. The transmission is out of my MK2 Cobra.
    https://youtu.be/iseEsB0gn7s?si=mcjIdlu2M1clE7oV
  47. #118
    Jan 2022
    Seven Hills, OH
    The rear end work is finally done! The brake calipers have been relocated to the front of the axle for clearance.
    https://youtu.be/mQVOOd_96SI?si=kst0WIUti0imwIcu
  48. #119
    Jan 2022
    Seven Hills, OH
    Time to tear apart the T5 and see if i will rebuild or replace the transmission in my Cobra.
    https://youtu.be/G_spGA1GFPg?si=3cs_s2AAlzNxuVzs
  49. #120
    Jan 2022
    Seven Hills, OH
    Back on the transmission. I had a stripped oil fill plug that i had to get out to see if the case was reusable.
    https://youtu.be/mSjt7sbOCdg?si=7uuOqLnEOTIp2pVA
