Likes Likes:  8
Results 1 to 12 of 12
Thread: interesting phenomenon last night testing electrical
    Folsom, CA
    Question interesting phenomenon last night testing electrical
    we were doing some ground testing around the car- still chasing down Coyote issues...
    my son used a multimeter between the battery ground and the alternator case - it measured ~15v ?!
    we tested the wires to the alternator and the pin read 12v from battery
    we disconnected the battery, even disconnected our extra fuse panel, tripped the 150A breaker between the alternator and the battery - and eventually the 'charge' went away
    we started the car a few more times, but never saw that 'charge' on the alternator case again
    what could cause such a thing to happen?
    Todd
    Sep 2020
    That is strange. One would think the alternator case to be grounded (common) to the battery negative, assuming the battery negative to be connected.
    Your negative cable was connected, engine grounds connected, and the negative battery cable connected to a point on the frame that is bare steel?
    One thing about a DMM, it will detect voltages that have little to no current potential. It can sometimes detect "float" that really isn't there.
    Roadster delivered 8/27/23
    Chevrolet Performance LS3
    Oct 2019
    Erin, Ontario CANADA
    With the metal case of the alternator mounted to the metal alternator bracket which in turn is mounted to the metal engine block which in turn is grounded to the frame via a flexible wire strap then it (the alternator case) has to be grounded (provided there is clean bare metal to metal contact at each juncture of course).
    Earl
    Folsom, CA
    Quote Originally Posted by BRRT View Post
    Quote Originally Posted by narly1 View Post
    Earl
    agreed - it's the M-8600-M50ALTA that most everyone uses on the Coyote, and yes, it's mounted directly to the engine and 4 grounds on my engine to frame...
    really wondering how the casing had voltage... the alternator is putting out 14.3-14.8v according to the ECU monitoring
    Todd
    Oct 2019
    It would be interesting to check the potential to ground at each of the "junctures" I mentioned previously to see if one of those "connections" is poor/faulty.
    Earl
    Folsom, CA
    Earl
    we measured resistance from battery (-) to each of the 4 grounds and got zero ohms
    Todd
    I like to use the continuity check, rather than ohm resistance. I would check continuity on the alt case to engine and grounds with key off, on and engine running.
    Are you Catholic? Just joking. I figure you need a laugh. My liquor bill would be skyrocketing.
  8. Likes toadster liked this post
    Mar 2021
    SE WI Kettle Moraine
    Grounding aside, the most likely sources of 12V to the alt case is the stator and rotor. Induction or an unwanted short? Less likely but possible is an internal circuit board to housing short.
    Trouble shooting would require disassembly.
    jim
  10. #9
    Folsom, CA
    ok I think problem averted, if you guys ever see a little battery light on your multimeter, change the battery LOL
    we were seeing 4.4 volts in mid air nothing connected... I've said it before, I'll say it again - Multimeters are the devil!
    Todd
  11. Likes narly1, BRRT, Alan_C liked this post
  12. #10
    Jul 2020
    Spencer, MA
    Been there, done that!
  13. Likes toadster liked this post
  14. #11
    Aug 2021
    El Dorado Hills, CA
    Maybe there is just too much pent up "energy" in your air over there!
  15. #12
    Folsom, CA
    Quote Originally Posted by Ted G View Post
    yeah we're looking for an aerial dewitcher
    Todd
  16. Likes Ted G, Alan_C, Andrew Davis liked this post
