Likes Likes:  2
Thread: Rubber Heel Mat
    Mar 2018
    Saint Johns, Florida
    Question Rubber Heel Mat
    Hello all,
    Finally got my FFR floor mats. Now I am looking for some sort of rubber or vinyl mat to prevent future wear through by my heels. I did an internet search an came up with nothing suitable. Anyone have a solution. Or...what about full "rubber" floor mats sort of like WeatherTech?
    Have a great day,
    Mk4 Complete kit with IRS, IRS brakes, Power Steering, 302 mounts, 302 headers, TKO, 2 Rollbars, Leather seats,
    vintage gauges, polished stainless sidepipes, front and rear sway bars, all cutouts.
    Blueprint Engines 347 stroker; Tremec TKO 600; 3.55 IRS, 17" Bullitt wheels: 9" front 10.5" rear.
    Delivered Nov. 6, 2018. First start Aug. 11, 2019. First Go-Cart Feb. 21, 2020.
    I've found the FFR floor mats very durable. Multiple seasons of driving with no visible wear where my heel sits by the accelerator. I have, however, found the Factory Supply carpeting quite susceptible to wear in that area. For all of my builds, I've glued and stitched a protective piece on the side of the tunnel. For my 20th Anniversary Roadster, shown here: https://thefactoryfiveforum.com/show...l=1#post267440. I bought several pads from here and has been enough for multiple builds: https://heelpadwarehouse.com/. Lots of other sources.
    If you want to cover the complete floor mat, there are multiple choices for large plastic mats you can cut to fit. Look for truck sizes. I've done that before for DD's.
  3. Likes toadster liked this post
    Stafford Virginia
    I got heel pads from "heel pad warehouse" have not installed them yet. They said to use 3M 90 spray glue to install them.
    JR
  5. Likes Just 1 More liked this post
  6. #4
    Aug 2012
    Ypsilanti, MI
    I used this and screwed it through the carpet and into the floor with stainless sheetmetal screws.
  7. #5
    Mar 2018
    Cool Great build pics
    Thank you for great ideas (as always).
  8. #6
    Jun 2015
    Maumee, OH
    I used polished aluminum diamond plate and bolted it through the carpet. Cut the floor mat in half and secured it on the forward side of the 2” tube. Prevents the floor. At from getting under the pedal.
    Built FFR9457. 351 Windsor, TKO600, 3.73. Fitech EFI. Russ Thompson throttle pedal, turn signal, and trunk pan. Carbon Fiber dash with Speedhut Revolution gauges. Paint by Jeff Kleiner.
  9. #7
    May 2020
    Centerview, MO
    I used these and took them to an upholstery shop and they sewed it to the carpet. Then I just put the floor mat over it.
    https://a1foamandfabrics.com/product...gaAo9GEALw_wcB
    MK IV Base Kit #9370 w/ FFR Lower Control Arms, donor 1996 Cobra 4.6 L DOHC; stage 2 Comp Cams, Manley forged Pistons & Rods, IMRC Delete Plates, T-45 transmission HD extra build w/ single disconnect reverse mod, 3-link w/ Koni Coil Overs 3:73 rear end. Painted and re-assembled Jan 2022.
