Can't officially check since I just stored the 33 this weekend but I think I'm at 6 clicks on the compression and 2 clicks I wanna say (maybe 4) on the rebound. Like you noted Brad, the QA1a are night and day difference over the Konis.
On the rear I only went with single adjustable QA1 and those are set at 6 clicks I believe too. I'm constantly playing with the rears though, the fronts I think I have set where I like them.
Jim
Thanks Jim. I started at 12 on compression and turned it down to 10 today - rebound is at 5. I was thinking I needed to drop both a little more so that helps knowing what yours are. And thanks again for posting your thread on that. Saved me a lot of experimenting for sure!
