Hey y'all,
I've continued go-kart testing the Roadster and after a few laps this morning and once the car was nice and warm, I adjusted the curb idle screw on my Holley 600 CFM (since I was running idle at around 1100 RPM) and brought it down to around 950 ~ 1000. From all the research it seems it should still be lower so went to make another adjustment and test drive this evening, however, when I turned the car on I was at around 2900 RPM right at the start. I turned the screw out but I wasn't seeing any effect. I turned off the car, took off the air filter, and found that the fast idle arm was stuck? (Red arm in the pictures). I moved the choke plate a bit and the linkage "caught" back into the arm. I noticed that if I pulled the throttle cable a bit then the choke plate would respond based on the adjustments of the curb idle screw. I went to start the car again but now it was a no go. 2 pumps of the throttle. Nothing. Tried another start and nothing. Turned the curb idle screw in and tried again but still nothing. Figured I'd stop here before I flooded the engine (which I know is a thing but wouldn't know how to tell if it was flooded).
Any recommendations on what I could do here?
Unrelated, but the test drive this morning was actually with forum member RoadRacer, who was incredibly generous with his time and patience, coming over with his alignment tools and teaching me how to use them for a front alignment. Also, let me borrow them so I can do the rear this week.![]()
