Thanks Thanks:  11
Likes Likes:  72
Page 10 of 11 FirstFirst ... 891011 LastLast
Results 361 to 400 of 416
Thread: Street Rod Jim's 33 Hot Rod V2 #1143 Build - The Journey Begins
  1. #361
    Arizona
    Tim also provided me with the arched trunk supports.
    33 Hot Rod V2 Coupe, Extra Clearance Hood, Bike Fenders, Rear Exhaust, LS Engine
  2. #362
    Jul 2020
    Spencer, MA
    Jim, I was watching your assembly video when you were trying to figure out the heater hose configuration. I ordered 2-45 degree Vintage Air hose fittings from Amazon for the firewall engine bay side and used the 90 degree ones on the inside to attach to the heater core. I had to bend the 90 degree ones slightly more to get them to line up better. Tighten them up on the bulkhead fittings and use a rag on it to protect your hand. Tighten them opposite of the installed position and push until it gets to where you want it. You can eyeball the angle with the heater core pipes that way. It takes some effort to do.
  3. Likes peterh226, Shades liked this post
  4. #363
    Arizona
    Thanks for the info...
  5. #364
    Arizona
    Factory Five 33 Hot Rod V2 - Lizard Skin Sound Control & Ceramic
  6. #365
    Arizona
    Factory Five 33 Hot Rod V2 - Painted Carpet Trim & Heater Hose
  7. Likes Jeff33Ford liked this post
  8. #366
    Arizona
    Factory Five 33 Hot Rod V2 - Painted Body On The Frame
  9. Likes Shades, Jeff33Ford, Salty Chief 35 liked this post
  10. #367
    Arizona
    Factory Five 33 Hot Rod V2 - Paint Inside Trunk - HVAC Heater
  11. #368
    Arizona
    Factory Five 33 Hot Rod V2 - Trunk Floor Panels & Center Console Fitment
  12. #369
    Arizona
    Factory Five 33 Hot Rod V2 - Sealing Console & Buffing Dash
  13. #370
    Arizona
    Factory Five 33 Hot Rod V2 - Building Dash, Black Out Fenders & Buffing Panels
  14. #371
    Arizona
    Factory Five 33 Hot Rod V2 - Valance Installation & Building Doors
  15. #372
    Arizona
    Factory Five 33 Hot Rod V2 - Installing & Aligning Trunk Lid - Carpet
  16. #373
    Arizona
    Factory Five 33 Hot Rod V2 - Custom Center Console Switch Panel
  17. #374
    Arizona
    Factory Five 33 Hot Rod V2 - Program Wireless Remote & Door Panels
  18. #375
    Arizona
    Factory Five 33 Hot Rod V2 - Doors, Fenders, & Side Panels
  19. #376
    Arizona
    Factory Five 33 Hot Rod V2 - HVAC Vents, Paint Parts
  20. #377
    Arizona
    Factory Five 33 Hot Rod V2 - Buffing Critical Areas Before Hard Top
  21. #378
    Arizona
    Factory Five 33 Hot Rod V2 - Carpet & Seat Belts
  22. #379
    Arizona
    Factory Five 33 Hot Rod V2 - Waterfall & Roll Bar
  23. #380
    Arizona
    Factory Five 33 Hot Rod V2 - Installing Hard Top After Paint
  24. Likes Salty Chief 35 liked this post
  25. #381
    Arizona
    Factory Five 33 Hot Rod V2 - Big Issue - Tear Down
  26. #382
    Arizona
    Factory Five 33 Hot Rod V2 - Let's Build It Back Up
  27. #383
    Arizona
    Factory Five 33 Hot Rod V2 - Hard Top, Side Panels, & Cold Drive
  28. #384
    Arizona
    Factory Five 33 Hot Rod V2 - Window Stops & Alignment
  29. #385
    Arizona
    Factory Five 33 Hot Rod V2 - Windshield Modified & Installed
  30. Likes Salty Chief 35 liked this post
  31. #386
    Placitas, NM
    I feel you pain with the tops of the side windows. I’ve got the side to seal pretty well but what I find is the 1/8” gap at the top gets larger the faster you drive.
    The wind pulls the glass out. Maybe I’ll try that double seal you mentioned.
  32. #387
    Jun 2020
    SoDak
    There is an "L-shapped Channel" I've seen that may work for you guys with a sealing issue. I don't have the top or windows so I'm not sure if this would work or not, but I've seen guys use them on other classic car restoration projects and it worked well there.
    Here is what I'm talking about (not saying buy from Amazon, just providing the link as an example --> https://www.amazon.com/52-49Ft-Strip...016256&sr=8-10
    Jim
  33. Likes e36m3 liked this post
  34. #388
    Simi Valley, CA
    My guess is that the wind builds pressure inside the cabin when you drive fast, pushing the windows out. I installed a pressure vent from a Ford pickup to see if I could avoid that problem. I don't know how well it works since I'm not on the road yet, but it seemed worth the $17 investment. https://www.amazon.com/dp/B07RPXQR93...roduct_details
    Keith HR #894
  35. Likes e36m3 liked this post
  36. #389
    Placitas, NM
    I’ll give both of those a try.
  37. Likes e36m3 liked this post
  38. #390
    Sep 2022
    Huntington, IN
    Keith HR #894
    Where and How did you install it?
  39. Likes e36m3 liked this post
  40. #391
    Simi Valley, CA
    I cut a closely sized hole in the aluminum panel that normally provides battery access. The vent just snapped in. I may add a bead of silicone sealer after final assembly.
    Keith HR #894
  41. Likes e36m3 liked this post
  42. #392
    Sep 2019
    Quote Originally Posted by Street Rod Jim View Post
    Hi Jim
    Did you get any video of the the tape and sealant getting added during the windshield final installation?
    Car is looking good!
    Andy
    33 Hot Rod with Deluxe Grill (32) Hood & sides, Bike Fenders, Hard Top, AC, Power Windows, Electric Power Steering, 306 Ford Small Block - roller cam, aluminum heads, Eldenbrock intake & carb, T5, Moser 3 link, Arrived 5/6/20.
  43. #393
    Arizona
    Quote Originally Posted by e36m3 View Post
    Hi Jim
    Andy
    There is nothing special. Put tape in, added windshield, then glued around it and you are seeing him wipe off the excess.
  44. #394
    Arizona
    Factory Five 33 Hot Rod V2 - Royal Purple Ice (Overheating)
  45. #395
    Arizona
    Factory Five 33 Hot Rod V2 - Mud Flaps
  46. #396
    Arizona
    Factory Five 33 Hot Rod V2 - Updates & Upholstered Door Panels
  47. #397
    Arizona
    Factory Five 33 Hot Rod V2 - Paint Correction & Touch Ups
  48. #398
    Arizona
    Factory Five 33 Hot Rod V2 - Window Templates
  49. #399
    Arizona
    Factory Five 33 Hot Rod V2 - Clean Up - Updates
  50. #400
    Arizona
    Factory Five 33 Hot Rod V2 - Weatherstripping
