Koni Shocks not right??
So I was putting my shocks together and read in the manual that the rear shocks are 2.5" longer than the fronts. Measured them and that is the case with mine. front shocks are koni #822610 and the rear # is 822611. The threaded adjustment sleaves and all the other parts, except for the springs (one is 400# and the rear are 250#) are the same. My rear shocks, with the adjuster all the way up, has about a 2" gap between the top of the coil spring and the retaining hat when fully extended. Is this right? That means if I put my truck on the lift that my springs will be loose around the shock. Another person on the forum said that the truck coil overs are supposed to be the same length as the fronts. Did I get the wrong coil overs or just the wrong threaded adjusters?
Well I can’t help about the parts you have, but yes when the suspension is unloaded it’s normal to have a loose spring. Most tie wrap the spring to the top hat to keep it in place.
FFR33 #997 (Gen1 chassis, Gen2 body), license plate DRIVE IT says it all!
build thread
Thanks for the help guys. I guess the thread I was reading that said the shocks should be the same length might have been for the older truck design.
I’d either get longer springs or add a short soft spring on top to make the ride more comfortable. Jmo.
Kit #361, arrived 10/2015, still in progress
818C highly modified, corvette suspension
Estimated completion summer 2023!
1989 turbo Supra 5 sp
2017 Tundra
You can’t add a second spring, both will flop around where the 2 meet.
Here’s a better pic of what I was explaining in post 4 above.
My shocks don't have a 2nd snap ring groove. Factory 5 said that this is the way the new shocks are.
