Tim also provided me with the arched trunk supports.
33 Hot Rod V2 Coupe, Extra Clearance Hood, Bike Fenders, Rear Exhaust, LS Engine
Jim, I was watching your assembly video when you were trying to figure out the heater hose configuration. I ordered 2-45 degree Vintage Air hose fittings from Amazon for the firewall engine bay side and used the 90 degree ones on the inside to attach to the heater core. I had to bend the 90 degree ones slightly more to get them to line up better. Tighten them up on the bulkhead fittings and use a rag on it to protect your hand. Tighten them opposite of the installed position and push until it gets to where you want it. You can eyeball the angle with the heater core pipes that way. It takes some effort to do.
Factory Five 33 Hot Rod V2 - Lizard Skin Sound Control & Ceramic
Factory Five 33 Hot Rod V2 - Painted Carpet Trim & Heater Hose
Jeff33Ford liked this post
Factory Five 33 Hot Rod V2 - Painted Body On The Frame
Factory Five 33 Hot Rod V2 - Paint Inside Trunk - HVAC Heater
Factory Five 33 Hot Rod V2 - Trunk Floor Panels & Center Console Fitment
Factory Five 33 Hot Rod V2 - Sealing Console & Buffing Dash
Factory Five 33 Hot Rod V2 - Building Dash, Black Out Fenders & Buffing Panels
Factory Five 33 Hot Rod V2 - Valance Installation & Building Doors
Factory Five 33 Hot Rod V2 - Installing & Aligning Trunk Lid - Carpet
Factory Five 33 Hot Rod V2 - Custom Center Console Switch Panel
Factory Five 33 Hot Rod V2 - Program Wireless Remote & Door Panels
Factory Five 33 Hot Rod V2 - Doors, Fenders, & Side Panels
Factory Five 33 Hot Rod V2 - HVAC Vents, Paint Parts
Factory Five 33 Hot Rod V2 - Buffing Critical Areas Before Hard Top
Factory Five 33 Hot Rod V2 - Carpet & Seat Belts
Factory Five 33 Hot Rod V2 - Waterfall & Roll Bar
Factory Five 33 Hot Rod V2 - Installing Hard Top After Paint
Salty Chief 35 liked this post
Factory Five 33 Hot Rod V2 - Big Issue - Tear Down
Factory Five 33 Hot Rod V2 - Let's Build It Back Up
Factory Five 33 Hot Rod V2 - Hard Top, Side Panels, & Cold Drive
Factory Five 33 Hot Rod V2 - Window Stops & Alignment
Factory Five 33 Hot Rod V2 - Windshield Modified & Installed
I feel you pain with the tops of the side windows. I’ve got the side to seal pretty well but what I find is the 1/8” gap at the top gets larger the faster you drive.
The wind pulls the glass out. Maybe I’ll try that double seal you mentioned.
There is an "L-shapped Channel" I've seen that may work for you guys with a sealing issue. I don't have the top or windows so I'm not sure if this would work or not, but I've seen guys use them on other classic car restoration projects and it worked well there.
Here is what I'm talking about (not saying buy from Amazon, just providing the link as an example --> https://www.amazon.com/52-49Ft-Strip...016256&sr=8-10
Jim
e36m3 liked this post
My guess is that the wind builds pressure inside the cabin when you drive fast, pushing the windows out. I installed a pressure vent from a Ford pickup to see if I could avoid that problem. I don't know how well it works since I'm not on the road yet, but it seemed worth the $17 investment. https://www.amazon.com/dp/B07RPXQR93...roduct_details
Keith HR #894
I’ll give both of those a try.
I cut a closely sized hole in the aluminum panel that normally provides battery access. The vent just snapped in. I may add a bead of silicone sealer after final assembly.
Keith HR #894
33 Hot Rod with Deluxe Grill (32) Hood & sides, Bike Fenders, Hard Top, AC, Power Windows, Electric Power Steering, 306 Ford Small Block - roller cam, aluminum heads, Eldenbrock intake & carb, T5, Moser 3 link, Arrived 5/6/20.
Factory Five 33 Hot Rod V2 - Royal Purple Ice (Overheating)
Factory Five 33 Hot Rod V2 - Mud Flaps
Factory Five 33 Hot Rod V2 - Updates & Upholstered Door Panels
Factory Five 33 Hot Rod V2 - Paint Correction & Touch Ups
Factory Five 33 Hot Rod V2 - Window Templates
Factory Five 33 Hot Rod V2 - Clean Up - Updates
Factory Five 33 Hot Rod V2 - Weatherstripping
